Old 8th January 2010, 18:42   #3616
CasperRider's Avatar
I believe you are referring to the low beam of Scorpio. I'm going through the same situation with my Scorpio and I believe for some reason, M&M have not focused both low beam as well as the fog lamps correctly. Even while the beam adjuster is at zero, the beams are set t ~45 degree and the visibility is only a few meters at night. Iím planning to get a headlight leveling/focusing from the service centre, first. Will let you know if it works.
I also heard that the new scoprio has better headlights, may be worth checking.
CasperRider is offline   Reply With Quote
Old 9th January 2010, 09:09   #3617
geeash's Avatar
Thanked: 132 Times
searched everywhere in chennai for phillips xtreme power bulbs
There are no H1 type of philips xtreme power bulb available in chennai including GP road. H4, H7 are readily available
Bnz Jon has enquired in Reliance automart in bombay and seems thay have H1 type in philips xtreme power though their website says there are no make of H1 in xtreme power bulbs. So i have asked him to enquire more
Osram night breaker and philips crystal vision are available readily
Osram nightbreaker a pair of H1 and H7 bulbs costs 2.6k which is bargainable.
If H1 in philips is not available i am thinking of mix and match . Think will go for philips xtreme power H7 and osram nightbreaker H1.
BNZ update me !!
geeash is offline   Reply With Quote
Old 9th January 2010, 20:46   #3618
Soccerfan's Avatar
Thanked: 56 Times
Where can i buy philips xtreme power (H4 , 60/55) in bangalore?? approx cost will also be helpful.
thanks in advance
Soccerfan is offline   Reply With Quote
Old 10th January 2010, 11:40   #3619
abhi3284's Avatar
Thanked: 55 Times
Default Headlight Upgrade & White LED EyeLids
Hi Guys,
I upgraded my Alto Headlights from 60/55 W to 100/90 W Setup.
Also, got the White LED Strips done between the Headlight and Bonnet.
Gives it a very Cool Look. Here are some Pics taken from my Cell Phone.
Auto Lighting thread : Post all queries about automobile lighting here-dsc00010.jpg
Auto Lighting thread : Post all queries about automobile lighting here-dsc00012.jpg
Auto Lighting thread : Post all queries about automobile lighting here-dsc00013.jpg
Auto Lighting thread : Post all queries about automobile lighting here-dsc00014.jpg
abhi3284 is online now   Reply With Quote
Old 11th January 2010, 00:46   #3620
wolfinstein's Avatar
I have 90/100 running on a stock OEM lancer set up, for the intial few weeks it was bright but then the illumanation kept dipping and now its as normal as 60/55 stock.
I do not have any ceramic holder or relay installed, Relay i presume are already installed in the Lancer OEM setup.
By referring to the thread, Please advise, Why would I need an additional relay installed, Will their be 2 relays for each head lamp( LH-RH).
What Relay should I Pick up, specific wattage or control.
wolfinstein is offline   Reply With Quote
Old 11th January 2010, 10:46   #3621
Thanked: 25 Times
Has any one tried Flosser [90/100] bulbs? How are they compared to philips rally 90/100?. I think Flossers are made in Germany.
ALSUDA is offline   Reply With Quote
Old 11th January 2010, 12:10   #3622
ankitahuja's Avatar
Thanked: 46 Times
You must upgrade to a good relay plus wiring kit since OE wiring supports OE specifications only i.e. 55/60W bulbs.
A relay will supply the additional power that the higher wattage bulbs require and make them work at their full potential.
Headlight relay is generally a one piece dual relay. ROOTS and Hella are two good brands. I prefer the former.
Old 11th January 2010, 12:25   #3623
thanks ankit, but like I mentioned I am running the 90/100 on the stock setup only. So I will need to upgrade this.
Any idea on the cost for Roots Relay and I would need ceramic holders correct.
Old 11th January 2010, 15:11   #3624
Originally Posted by funda2max View Post
Thanks Chevy_lover. I will check with Philips 100/90 halogens. I am not interested to install a auxiliary lamps as it will look odd in my car.
I have upgraded to Philips 110/100 H4. Total cost : 1200 (700+350+150). Visibility is good now during night hours. I am happy that other drivers started dipping lights to avoid high beam
funda2max is offline   Reply With Quote
Old 11th January 2010, 15:32   #3625
Originally Posted by Chevy_lover View Post
Hey hey! I put it wrong there. My error. What I meant is that no matter what the power of the bulb, a 12 Volt relay can effectively control the electricity from the battery. I am aware that 130W needs more power, coz I am using it. That is why I insisted on heavy duty wires. Sorry for putting it wrong.
Nope, a 12v relay cannot effectively handle any electricity from the battery.
12v is only the operating voltage for the relay to get acticvated. The contacts current rating is what will determine how much current it can handle. Even if one uses heavy duty wires externally for the wiring, if the relay current rating is less than the required value, the relay is definitely going to burn out.
rkguru is offline   Reply With Quote
Old 11th January 2010, 16:28   #3626
Originally Posted by ankitahuja View Post
Got my hands on this 36 LED block to be used for in-cabin lighting! Yet to install them.
A friend has the same 18 LED block in his Accent and it lights up pretty well. Short LED life is a concern, since 3-4 have now conked off!
Hey buddy how much for this?
WanderNomad is offline   Reply With Quote
Old 13th January 2010, 00:54   #3627
ankitahuja's Avatar
Thanked: 46 Times
Yes, you need to upgrade your wiring and add a relay so that the bulbs don't dim and can work to the full potential; thereby offering you better lighting. Ceramic holders are recommended so that they can withstand the heat.
Roots wiring kit (ceramic holder included) + relay will cost you about Rs 650.
Dude I believe Philips Rally now come in 100/110W right?
I think I paid 250 for this (maybe 150), can't remember but will find out. Btw, the light works brilliantly!
Old 13th January 2010, 02:14   #3628
S.I.N.G.H's Avatar
Thanked: 40 Times
where did u source it from?
S.I.N.G.H is offline   Reply With Quote
Old 13th January 2010, 02:25   #3629
Picked up the same for Rs. 300 from Expert in Karol Bagh (I feel I was charged higher). Its good but 3 / 6 LEDs keep getting on / off. Seems some internal soldering is loose but cant help it.
Old 13th January 2010, 02:29   #3630
S.I.N.G.H's Avatar
Thanked: 40 Times
do get the loose LED's soldered. fluctuating leds affect the whole circuit leading to damaging of some leds which are in series.
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
