Old 12th July 2010, 09:49   #3991
naveen.raju's Avatar
Thanked: 3,251 Times
I guess you can upgrade to higher rated bulbs. In HIDs, a lot of light will be wasted.
naveen.raju is offline   Reply With Quote
Old 12th July 2010, 09:59   #3992
kingofmyworld's Avatar
Thanked: 248 Times
Originally Posted by msaudf View Post
is that right?? if thats the case then I'm gonna stick to 100/90 halogens and my original headlamps and maybe go for the hella optilux 1102 as another member is opting for.
cheers mate
Though some light is wasted, The visibility is anyday increased when you get hids. I got 35w bi xenons in my glass lense headlamps and the visibility increased. mine are 35watt. If you want more light, then get 55watt bi-xenons.
kingofmyworld is offline   Reply With Quote
Old 12th July 2010, 16:18   #3993
jkdas's Avatar
Thanked: 1,424 Times
Default Philips Rally now had H3 @ 100W.
Tried searching but failed :(
What's the fog lamp bulb of Safari ? H3? H1?
Philips Rally now has H3 @ 100W. Thinking of getting it for my Safari. Should be ok right?
Old 12th July 2010, 18:45   #3994
tsk1979's Avatar
Thanked: 15,684 Times
I am not sure if its a good idea.
Due to a splash of water, the glass of my fogs got minor cracks. Now imaging a 100W lamp, and rain.
Old 12th July 2010, 20:11   #3995
NiTviN's Avatar
tsk1979, dont we need a rally and wiring kit for fogs as well? The way we do it for the headlamp upgrade?
NiTviN is offline   Reply With Quote
Old 13th July 2010, 16:01   #3996
LionX's Avatar
Thanked: 565 Times
I have already upgraded the fogs to 100W (1 Hella & 1 Philips ) without the relay and wiring. I hope it wont be as issue for fog as the safari wiring is enough to handle that much current. One installer told me that safari has internal relay for fog lamp and extra relay wont be required.
LionX is offline   Reply With Quote
Old 13th July 2010, 17:13   #3997
tsk1979's Avatar
Yes the stock wiring is good. But the problem is not the wiring, its the glass. It sits low, and can easily get water splashes. So if your fogs are on, and you splash through water, the glass will be cracked due to high heat.
Old 14th July 2010, 12:57   #3998
nick17s's Avatar
Thanked: 87 Times
same happened with my zen's fog lamp, btw i have upgraded to 90/100 halonix bulbs with relay in fog and headlight, but now a days i ve been noticing that in night (specially on open roads) the visibility is almost 0.
i mean there is barely any difference if i turn on and off the lights of my car, it will run on street lights only ??
what shall I do? any 1 else facing this kinda issue?
nick17s is offline   Reply With Quote
Old 14th July 2010, 13:12   #3999
jkdas's Avatar
Emm, good and bad news !
Happy that the wiring will take the load but now the glass part is worrying!
LionX;have you driven a lot with fogs on?
Old 14th July 2010, 20:48   #4000
shyamhegde's Avatar
Did you think of HID for this? since it is at very low level, might not glare so much for oncoming eyes . I have seen H3 yellow coated ones sometimes back and they should suit for fog light requirement.
shyamhegde is offline   Reply With Quote
Old 18th July 2010, 17:46   #4001
joshguy's Avatar
Thanked: 92 Times
Originally Posted by joshguy View Post
Hi Guys
can anyone let me know the price of Roolite or light force in chennai?
I also need the details of dealer or variants available in these brands
Hi All ,please let me know which is the best for high way driving ? Roo lite,Light force or Hella.
Let me know the model number and also the approximate price for it
joshguy is offline   Reply With Quote
Old 18th July 2010, 21:22   #4002
Thanked: 19 Times
Hi Joshguy,
I can vouch for the lightforce for the highway driving. I have Lightforce 240 with normal xenopshot 100 watts bulbs. It comes in 3 models based on the size. lightforce 140, lightforce 170 and Light force 240.
Also you have the option of normal xenophot bulbs or the HID's. The HID's cost almost the double. I feel 240 model is a overkill for sedans. I paid around Rs 14k (including wiring harness) and got it from US. Here in Bangalore it costs about 25k.
The second best option is to go for Hella 4000 which costs around 12k in Bangalore.
Here are some of the sites where you can buy online in US.
http://www.truckcustomizers.com/category/driving-fog-lights/lightforce.html
LightForce Lights -
LightForce 240 Blitz Driving Light - Sierra Expeditions.
cheers
Kishore
bkishore_77 is offline   (1) Thanks Reply With Quote
Old 19th July 2010, 23:15   #4003
Thanked: 52 Times
Originally Posted by gaddiwale View Post
Today intentionally started late from office, to check the performance of the Philips Rally H4 100/90 W. Its awesome. Liked the throw as well as the intensity in both low and high beam. Highly recommended bulbs.
Thanks TBHP to help me to choose the right one.
Sofar the performance of the Philips Rally H4 100/90 W was really outstanding. Today while returning from office one bulb is not working! Stopped and checked, actually bulb is working but the intensity is like a 10 W bulb.
Can any body throw some light, why the intensity decreased in both high and low beam of the said bulb, where as the other bulb is working fine.
gaddiwale is offline   Reply With Quote
Old 20th July 2010, 02:05   #4004
Thanked: 248 Times
@Gaddiwale : Same case happened even with me a couple of time, I'm sure your bulb will go kaput soon. My bulb ( both the times ) started looking like a bedlamp. When I opened and checked the bulb's glass wall was whiteish and blueish. Maybe some manufacturing defect. I had 130/100 cutout and I used 100/90 in one headlamp in case of emergency. used 100/90 bulbs twice and they worked for not more than 2 days each. Got 130/100 later and they were working fine. I later switched to HIDs.
Old 20th July 2010, 09:36   #4005
jkdas's Avatar
Any idea from where I can procure and how much it would cost?
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
