Old 5th May 2011, 15:30   #4981
naveen.raju's Avatar
Thanked: 3,726 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Originally Posted by mtnrajdeep View Post
Is it possible to fit a projector lamp for the foglamps in the swift? Without HID's and running higher power halogens with relay, will these be effective? And what would be the reliability since these will be placed low and can possibly be hit by small stones?
It is possible to attach projectors for the fog lamps. See pic.
Auto Lighting thread : Post all queries about automobile lighting here-l8.jpg
Since these are really low to the ground, these will be prone to damages very easily and there will be water seepage. The best bet would be to go for higher rated bulbs on the existing assembly or go for a new assembly. My friends got Volvo headlight unit fixed onto his swift fog lights. It's expensive though.
naveen.raju is offline   Reply With Quote
Old 5th May 2011, 15:42   #4982
mayankk's Avatar
Thanked: 3,559 Times
My fiesta's headlights are really dusty on the reflector part of it.
One mechanic spotted it in a car park in khan market ans said he could clean them up(after opening them) and would cost about 2500 bucks.
now, this sounded a bit steep to me.
howver, if this is usual, then i can go ahead?
also, the throw on my low beam is quite low.
The focussed beam i can spot is just about 10-15 metres ahead.
However, visibility is much much beyond.
just the point where it feels the majority of the light is ending is quite near.
Has anyone retro fitted Projectors in the fiesta?
or some other solution?
mayankk is offline   Reply With Quote
Old 5th May 2011, 15:45   #4983
Thanked: 219 Times
Originally Posted by nkapoor777 View Post
Here you go:
Krishna Sales
Sultan Singh Building, Balaji Market,
Kashmiri Gate, Delhi
09582199000
This is walking distance (<250m) from the Kashmiri Gate metro station and is located near Bata showroom and Central Bank of India branch.
HI Nitin
Did you bought these to upgrade your punto;s headlight's . I am looking to improve the visibility on my punto without addition of relays and other electricals. some body has recommended me philips extreme 90 w i guess as well. which one are better between these two.
.sushilkumar is offline   Reply With Quote
Old 5th May 2011, 16:20   #4984
Thanked: 84 Times
Is this a projector unit or reflector based unit? How much is the cost and would appreciate the source and datasheet/spec sheet/web link if available.
Digital Vampire is offline   Reply With Quote
Old 5th May 2011, 16:50   #4985
mtnrajdeep's Avatar
Thanked: 101 Times
Attachment 540418
Thanks Naveen. This is exactly the setup I was looking for. How fragile are these setups? Shouldnt it be possible to seal the bulbs using sealants like anabond and avoid water seepage? How much would such a setup cost (2 projector's with angel eyes)?
mtnrajdeep is offline   Reply With Quote
Old 5th May 2011, 17:05   #4986
2500 bucks? That's way too much just for cleaning. My local mechanic has cleaned my headlights for free. The tricky part is installing them back. Apply silicon gel to make sure there wont be any water seepage. I did it for my ride.
I have seen one Fiesta with projector headlights in the forum but havent personally seen one.
This is a reflector setup. He use 80/80w Philips halogens. Total cost came around 7k.
Anytime. You can use silicon gel to avoid water seepage but to avoid stones, well am clueless. This is the problem when going for projectors in the fogs. The entire kit (excluding the HIDs) would come around 6k depending upon the brand.
naveen.raju is offline   (3) Thanks Reply With Quote
Old 5th May 2011, 17:22   #4987
sohail99's Avatar
Thanked: 200 Times
I was looking at these projectors for my foglamps! - Fog Light: Blazers - HID Projectors from The Retrofit Source Inc
My foglamps use 27W H-27 or 880 bulbs which barely even light up the road and seem effective only in pitch dark environments!
I was looking at either a bulb replacement with a better one or projectors! but kinda
sohail99 is offline   Reply With Quote
Old 5th May 2011, 17:40   #4988
Shubz's Avatar
Thanked: 989 Times
Originally Posted by Akhil@Bengaluru View Post
I Wanted to change the headlight bulb to Osram Night breaker Plus but they are quoting 1300. Can anyone please confirm what was the latest price for Osram Night breaker Plus in Bangalore? I am looking for H7 for My Manza.
Akhil sir - Try Sachins Auto shop in Koramangala. Next to Sai baba temple on the Bosch road. I guess it is 1150 or 1200 for H7.
Shubz is offline   Reply With Quote
Old 5th May 2011, 17:46   #4989
nkapoor777's Avatar
Thanked: 91 Times
Originally Posted by .sushilkumar View Post
HI Nitin
Yupp the Osram NB+ went into the punto headlights (H4) and fogs (H7). I was using Philips Extreme Power earlier but these a shade better than them in terms of throw and spread of light. You don't need relays or anything extra for these since these bulbs conform to stock specs (60/55W).
nkapoor777 is offline   (1) Thanks Reply With Quote
Old 5th May 2011, 20:05   #4990
There are many different kind of projector setups for fog lamps. I would definitely recommend a bulb replacement since projectors fogs are not suited for our road conditions. If you willing to shell out some money, then this is an option.
Old 5th May 2011, 20:26   #4991
sohail99's Avatar
Thanked: 200 Times
I'm ok with just a bulb replacement. Projectors, maybe some yrs down the line
Any recommendations?
Old 5th May 2011, 20:52   #4992
swiftnfurious's Avatar
Thanked: 6,581 Times
I never bought NB+, So I cant comment on the prices. But I bought Osram NB for 1300/- couple of years back - So the price looks fine. More than that I heard the NBs now cost 900/-
By the way does Manza have H7 bulbs ?? I read that Corolla has H7 !
I recently bought Osram NB+ direct from a distributor in Delhi. The MRP on the pack was 1150/- for H4 and 1050/- for H1 60/55W bulbs. Not sure about the H7 price though. I got them for a total of 1500/- (800/- for H4 and 700/- for H1) with tax-paid bill.
How could the price be so low for tax-paid bill ? Something fishy ?
swiftnfurious is offline   Reply With Quote
Old 5th May 2011, 22:42   #4993
nkapoor777's Avatar
Thanked: 91 Times
This guy is an authorised Osram distributor so chances of fakes is seriously remote. Remember this is a distributor and not a retailer who sources his supply from him and then adds his margin to it to bring the price equal or closer to MRP.
nkapoor777 is offline   Reply With Quote
Old 6th May 2011, 00:50   #4994
Thanked: 84 Times
Nothing fishy here. If you can deal with the distributor, the prices has always been much lower than MRP. But not all distributors entertain low volume retail sales. The only issue here is just that we are so used to paying MRP (or more) for anything and everything without even batting an eyelid.
Old 6th May 2011, 09:39   #4995
For bulb replacements, you can check out Philips. Go for higher rated ones.
naveen.raju is offline   (1) Thanks Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
