Old 6th July 2007, 12:09   #526
absynthguzzler's Avatar
Thanked: 223 Times
Default Am I Being Crafty Or Dumb ?
Originally Posted by iraghava View Post
CD is right Ankit, we blow the bulbs (atleast I do quite a few times) primarily due to my habit of using both the beams together! Possible to do when the HL's are on low-beam & you flash simultaneously. Nothing wrong with the bulb there. And there is no set life time for the bulbs, I've seen some working for a few years without any issues & some going bust in a few weeks.
And generally you can buy single pieces of most bulbs apart from a few Philips ones I guess which come pre-packed in sets of two.
would it not make sense to just use a 1mm or 2mm thick drill bit and make a few holes in the outer headlight enclosue so as to improve cooling while driving ???? or does it affect performance and also increase chances of bulb blowing up ?
absynthguzzler is offline   Reply With Quote
Old 6th July 2007, 12:25   #527
RedOne's Avatar
Thanked: 19 Times
Default 130/100 long term use
Originally Posted by CARtik View Post
suren, how long have u used there high power bulbs. Have you had any issues with lens cracking/holder melting?
Am planning to install on my getz as i do a lot of highway. But want to know reliable these lights are. Pl also let me know the brand..
I have been using Phillips 130/100 on my OHC for 4+ years now. No issues with cracking/melting etc but the reflector/cover does look a bit dull. Then again, it's a 6.5 yr old car...
Gears.
Red-One.
RedOne is offline   Reply With Quote
Old 6th July 2007, 14:51   #528
rjstyles69's Avatar
Thanked: 791 Times
Hey folks any idea where in Bangy can I source the Philips 130/100 bulbs ?
Cant find anyone who stocks these bulbs.
Somehow feel that my current 100/90(Hella) aint giving me enough light.
Old 6th July 2007, 15:01   #529
tsk1979's Avatar
Thanked: 15,684 Times
1. I got 130/110W for JC road. If you get them make sure you have roots ceramic holders. My holder slightly melted, but thankfully no permanent damage. I used them for quite some time
2. Now I am on Halonix 100/90W +60 and they give same light as 130/110W.
I suggest you stay away from 130/110W and put in either Hella gold(Yellow light), Philips rallye(if you get originals, almost impossible) or Halonix.
3. Best option seems to be Osram, if you can get 100/90 Osram then nothing like it.
We put 60/55W Osram in a safari and light is same as the 100/90 bulbs
Old 6th July 2007, 15:20   #530
rjstyles69's Avatar
Thanked: 791 Times
Thanks tsk .
I already have ceramic holders with my current 100/90 setup.
Wil have to hunt around for Osram or Halonix in the 100/90 range.
Have found quite a few sellers in India on ebay with Phillips Rallye, but dont know how good these are.
Old 6th July 2007, 16:27   #531
Dragonov's Avatar
Thanked: 30 Times
Came across "Halonix H4 +60 High Perfomance Xenon Head lamps" on Ebay. There is no wattage mentioned on them on the website but seems to be a good option, wanted to know if anyone has used them ?
Dragonov is offline   Reply With Quote
Old 6th July 2007, 16:31   #532
tsk1979's Avatar
Originally Posted by Dragonov View Post
Please read this thread, or use search function.
They are available in Sector 16 Noida at Rs. 90/bulb and I am using them. For review and comparison, just look in the previous posts.
The config is 100/90W
Old 6th July 2007, 16:35   #533
CrAzY dRiVeR's Avatar
Thanked: 17,016 Times
Guys,
How to see if Philips bulbs are original?
Am looking for rally eye lamps.
Old 6th July 2007, 16:44   #534
rjstyles69's Avatar
Thanked: 791 Times
Philips Rally eye bulbs are no longer manufactured is what I got to know.
Old 6th July 2007, 16:45   #535
Dragonov's Avatar
Thanked: 30 Times
Thanks for your reply tsk1979, but I wanted to know whether the one's available on Ebay ( supposedly Halonix +60 Xenon Headlamps) are the same Halonix +60 90/100 W which you bought from sector 16 noida. I mean are they Xenon gas filled bulbs or the normal halogens..?
Old 6th July 2007, 18:21   #536
tsk1979's Avatar
There is only one Halonix +60 100/90W and it is supposed to be Xenon gas filled.
They are nice bulbs, but if you expect white light, you will be disappointed.
Old 6th July 2007, 19:07   #537
Thanked: 11 Times
Is there any way to adapt an h7 kit into an h8 (swift fogs ) ?
Old 6th July 2007, 19:40   #538
Akshay1234's Avatar
Thanked: 6,730 Times
i think youd have to change the bulb holders etc.
Old 6th July 2007, 19:41   #539
Jaggu's Avatar
Thanked: 7,676 Times
replacing the bulb might not really help the swift fog lamp, its more to do with the reflector and the beam adjustment which are nearly impossible to fiddle with.
Old 6th July 2007, 20:02   #540
Sure?
Man! does that mean all the hundreds of bulbs stocked in all the showrooms i checked recently were fakes?
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
