Old 22nd July 2007, 13:00   #616
ankitahuja's Avatar
Thanked: 46 Times
Which car..?
Did you get a Relay/Wiring upgrade?
If you look at the comparison pics between Narva and Halonix on my Indica, you will see that the Halonix were much brighter than the Narva.
OHC 1st Gen buddy. I have got the Roots Kit with all the upgradations Tsk. What could be the problem?
I desperately need to get back to Philips or try Narva then. How much do Narvas cost?
Old 24th July 2007, 01:33   #617
firingonallfour's Avatar
Originally Posted by PRADEEP KUMAR View Post
Which is the best in the 100/90 category in terms of light intensity and throw.
Experts pls advice.
Hi...Try Philips Rally Eye 100/90 with a good relay ( I have Bosch). Excellent throw and very bright. Rs 350 for pair.
firingonallfour is offline   Reply With Quote
Old 24th July 2007, 12:53   #618
razor4077's Avatar
Thanked: 258 Times
Originally Posted by nkapoor777 View Post
Phew, got the delivery of the much awaited Philips Extreme Power (80%+). Fitted them last night. The difference is visible but whether worth Rs. 1600, only time will tell.
Take some pics... comparison pics would be good.
razor4077 is offline   Reply With Quote
Old 24th July 2007, 14:30   #619
Thanked: 28 Times
Folks,
Based on Expert advice here decided to upgrade my existing Philiphs 100/90 to Halonix + 60 100/90.
Went hunting the entire GP ROAD area.Not a single shop sells this brand.
Any buyers of this in Chennai/Bangalore with price.Pls update.
PRADEEP KUMAR is offline   Reply With Quote
Old 24th July 2007, 14:31   #620
tsk1979's Avatar
Thanked: 16,012 Times
Hella Gold 100/90 works great in an OHC. I guess different bulbs give different light due to reflecter design.
Iraghava has hella gold, but one of his bulbs blew the high beam recently.
Old 24th July 2007, 14:31   #621
ibcool's Avatar
Thanked: 7 Times
does this setup void warranty ?
ibcool is offline   Reply With Quote
Old 24th July 2007, 15:21   #622
tsk1979's Avatar
If you get Relay and wiring done from outside(eg bosch/roots kit) the service center can use that as an excuse to void warranty, though I have not seen this being enforced.
Old 26th July 2007, 00:36   #623
drhari15's Avatar
Lightbulb Upgrade for Indica Xeta
Hey guys, Im a fresher here, from Bangalore.
I'm trying to upgrade the headlights on my year old Xeta GLG thats currently shod with Osram Dela 60/55 H4 - and ofcourse, I'm not happy with it.
After reading through this thread, I'm convnced that Philips Rallye 100/90 is the best bet for an upgrade.
But I want to try out the white light and have narrowed down to the Narva 100/90. I spoke to a dealer (junction) in Jayanagar this morning, got a quote of Rs.1300 for the complete kit - bulbs and wiring, which i though is a bit expensive.
Based on TSK's advice, i decided to try out different ones (Rallye, Vision +, Osram etc.) in the evening and I shall post the pictures of the same.
One query though - when I enquired about the Fogs, the salesguy suggested Narva 85W, but I didnt enquire about the cost. Was told that it does not require any additional wiring - but I'm not sure about this - ADVISE please!!, Also, whether this will make any difference to the lighting/looks?
drhari15 is offline   Reply With Quote
Old 26th July 2007, 09:52   #624
Akshay1234's Avatar
Thanked: 7,212 Times
the narva 100/90 cost me rs1275 with bosch relays. they are certainly very bright. about the fogs i think you should stick to the normal wattage which should be 55w. if you do get 85w i think you should change the wiring.
Old 26th July 2007, 15:04   #625
tsk1979's Avatar
Dhar, good decision to try and then buy.
As for 85W fogs, you are looking at 170W and that means around 15-16A extra current from alternator.
With Fogs/Headlights/AC/Stereo on, the charging current to the batter will not be adequate and long use could leave you stranded. So just get good driving lights, no need to get those extra fogs.
As for the Philips Ralleye, I got duplicate ones from JC road. Philips duplicates are dime a dozen, so its better to go towards Bosch/Osram/Halonix etc., which are not favorite with duplicators.
Old 26th July 2007, 15:10   #626
gopinathann's Avatar
Thanked: 20 Times
what is the kelvin value for Philips Rally. Does it produce white light ?
gopinathann is offline   Reply With Quote
Old 26th July 2007, 15:23   #627
tsk1979's Avatar
No white light, the color is yellowish(around 3000K I presume) similar to stock bulbs.
Old 26th July 2007, 19:15   #628
Awaiting Email Confirmation
i wanted to know, does anyone know how i can make my zen headlights clear instead of the normal hazy glass that is there..i have installed streetglow xenons and want the glass to be clear instead of hazy...will replacing the glass do or do i have to replace the reflector as well?
thanks!
vidvai is offline   Reply With Quote
Old 26th July 2007, 23:30   #629
drhari15's Avatar
Default Upgrade for Indica Xeta
Got the Narva 100/90s for my Xeta this evening. Had to pay Rs 300 for the parking lights. A total of Rs.1600 - expensive??
The first thing I noticed is that the light is not as "sharp" (if i can call it that) as the golden one - there is a lot more spread but i feel that the intensity is slightly less.
This is especially evident with the presence of the yellow light around.
But I must add that the high beam is pretty good!!
I tried the Philips Rallyeye 100/90 on one side and this clearly beats the Narva in terms of usable light, but i wanted white lights, atleast for some time.
Will be driving out of town during the weekend, will share my thoughts about the highway performance when back.
Thanks a lot for all the advice guys!!
Old 27th July 2007, 00:56   #630
nkapoor777's Avatar
Thanked: 91 Times
Will do as soon as I get back to town. Some time next week man.
nkapoor777 is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4093 18th June 2018 11:44
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11302 29th May 2018 12:23
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
