Old 31st July 2013, 15:16   #7486
Soumyajit9's Avatar
Thanked: 1,686 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Thanks SRK !! Your points were really helpful.
Originally Posted by SRK View Post
These seems to be the CFL angel rings (cannot open the link).
You can expect 2 rings and a Voltage transformer with it.
Since you are getting it done by a professional, they should be having all the required things, so no need to get anything.
Voltage Transformer - Hmm, this sounds interesting. I will re-check with the seller whether they have this included in the package.
The installation guys will have things handy, but want to make sure that they don't ask to buy additional devices to support this installation. Wires, Tapes n Gums will be there with the installation guys.
- Does this require a separate wiring or something to control the load of current ?
Wiring, can be done separately and a switch added to control it but usually they just connect it with the parking lights. Let your installer know how you prefer it.
My plan is to keep it hooked to either the parking light, or fog light. I don't want to have a separate switch, so hopefully the parking light stalk will work for the angel ring.
- Does this replace the existing headlight bulb ? Or will it be a Ring (like a round DRL) on the headlight console ?
You will not have to replace the halogen bulb. This is just an add-on. The rings will be added to the headlamp unit. Something similar to what you see in BMWs.
That's a relief that I don't have to change the bulbs. Yes, it looks like those of BMW and that's why I intend to have it on my Beat.
They do look good.
You might not be able to remove them as these will have to be properly installed using adhesive, so they stay in place.
Also do add the cost of installation, as Rs. 549 is just for the angel rings.
But yes, I'll see what kind of adhesives they use. If one goes kaput, atleast I should be able to remove it, without hurting the headlight console.
I am assuming Rs.500 more for the installation. Equate to ~Rs.1100, which sounds decent.
I will check the price of the product + installation (combined) at a local accessories dealer and see whether online / offline is cheaper.
Thanks once again for the clarification and help.
Soumyajit9 is offline   Reply With Quote
Old 1st August 2013, 10:47   #7487
Thanked: 33 Times
Originally Posted by kosh4u View Post
Hi
Can anybody tell me where I could source good quality replacements in Bangalore (not OEM, as they are around 3700/- & as I plan to continue using the 100/90 W setup).
thanking you in advance
Try Anand Distributors near J C Road - they are distributors for a few reputed automotive light assembly and lens manufacturers. I have bought lens for my car and bike a few times from them. Google for address and phone number.
dish is online now   Reply With Quote
Old 1st August 2013, 14:42   #7488
Shubz's Avatar
Thanked: 989 Times
Time to think of some lighting mods (non-intrusive) on my i20.
Stumbled upon --> http://cgi.ebay.in/ws/eBayISAPI.dll?...X:eRTM:IN:1123
Similar questions as above
Is it a direct fit?
Do I need anything else with this?
Major wiring alterations?
How different is this from the naaptol product costing just R549 vs the above costing R3899?
Thanks in advance.
Shubz
Shubz is offline   Reply With Quote
Old 1st August 2013, 20:06   #7489
mayankk's Avatar
Thanked: 3,560 Times
Is it a direct fit?
Do I need anything else with thvis?
Thanks in advance.
Shubz
It's not 549 since it is a Projector.
It is a bolt in unit, you'll have to open the headlamps and pop it in, that's it.
From the ad it seems that you'll have to buy ballasts and bulbs, which could cost about 4k combined off of dx, probably double if from eBay or branded.
Make sure you find out from the seller what bulbs it takes.
mayankk is online now   Reply With Quote
Old 1st August 2013, 23:34   #7490
Thanks a ton. My apologies for delay in replying, as i am in the middle of a school activation. Will check out the outlet ASAP. Thanks once again.
kosh4u is offline   Reply With Quote
Old 2nd August 2013, 07:13   #7491
nipcarlover's Avatar
Thanked: 307 Times
Hello!
I am considering changing all the front bulbs (headlamp, parking light and fog lamps) on our i10.
I want better than stock lighting, preferably slightly whitish lights and not voiding the warranty.
All light experts, please suggest the good bulbs for this and approx. cost.
Thanks!
nipcarlover is offline   Reply With Quote
Old 2nd August 2013, 11:58   #7492
KALINGA's Avatar
Thanked: 281 Times
I want to change the Head light & the Fog lamp bulb of my Ertiga.
Head Light : 12V ---> 60/55W ---> H4
Front Fog Lamp : 12V ---> 55W ---> H11
OT : which company bulb should I go for?
KALINGA is offline   Reply With Quote
Old 2nd August 2013, 13:45   #7493
sgiitk's Avatar
Thanked: 3,885 Times
@KALINGA; Head Lamps Osram Night Breaker Plus. Drop in replacement and about 30% more liight.
Fog: No idea, NB+ is available, but the slightly cooler colour temperature in my view is not so good.
sgiitk is offline   (1) Thanks Reply With Quote
Old 2nd August 2013, 14:04   #7494
Sommos's Avatar
Thanked: 675 Times
Originally Posted by nipcarlover View Post
Hello!
Thanks!
You both have similar query, so giving a common answer :
Change your stock bulbs with Philips XV or Osram NB+. It should provide some 30% or so more illumination than the stock bulbs. Ensure that the bulbs are 4300K.
Kalinga, the fogs should be 35W and not 55W.
Sommos is offline   (2) Thanks Reply With Quote
Old 2nd August 2013, 14:21   #7495
Thanked: 307 Times
Thanks!
What about the fogs and the parking lights?
Old 2nd August 2013, 15:26   #7496
Sommos's Avatar
Thanked: 675 Times
Thanks!
Why do you want to change the fogs?
The fogs are not meant to illuminate the road like your headlamps.
However, if you still insist, you can try something like the Osram Silverstar (35W) (I hope the name is correct) or even HID bulbs in the fogs. Not sure about the results, though.
Sommos is offline   Reply With Quote
Old 2nd August 2013, 15:28   #7497
Thanked: 307 Times
Well, I think it would look quite odd, with two different colours on the headlamps and fogs.
What about the parking lights?
Old 2nd August 2013, 15:35   #7498
Prodigy07's Avatar
Thanked: 329 Times
The stock H8 fog bulbs in my Ritz were pathetic. So, I replaced them with Osram Cool Blue H11 bulbs assuming the throw would be good. But I seriously don't find them effective at all. I am not able to judge potholes very clearly.
I find the stock fogs in my Fiesta much better than the H11's in my Ritz.
Is this due to the lack of seat height adjustment in the Ritz? Probably I sit a tad lower in the Ritz and Ritz with a large dashboard obstructs the vision?
Can someone guide?
Prodigy07 is offline   Reply With Quote
Old 2nd August 2013, 18:42   #7499
Shubz's Avatar
Thanked: 989 Times
Thanks for the response Mayank - The seller only said I would need to buy ballasts (he did not mention anything about the bulb). Nevertheless I have asked him the same about what bulbs would go in there.
Will update once I have a response.
Shubz
Old 3rd August 2013, 00:47   #7500
Thanked: 25 Times
Can anyone suggest where I can get Fog lamps fitted for 2009 Civic SMT.
I went to Sachin's Autoshop and they did not have stock. They arranged an "imported from Thailand" one - but it was not the right size. They have promised to try to get and is quoting Rs. 6000.
I think it is on the higher side......
Ajith-s is offline   Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
