Old 22nd August 2013, 22:11   #7531
Guite's Avatar
Thanked: 180 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Originally Posted by jacs View Post
Most of the Hella relays in market are fake products and Super is atleast an Indian company with a proper warranty .
If you can source original Hella relays, its believed to be better than others.
I have posted photograph of original Hella relay kit few pages back. It is double relay, double fuse; one for each headlight. Construction and material quality is very good, you can sense it from touch and feel.
Guite is offline   (1) Thanks Reply With Quote
Old 23rd August 2013, 14:37   #7532
praful's Avatar
Thanked: 436 Times
I'm looking for Philips Essential Power H7 80W bulbs (http://www.lighting.philips.co.in/v2...more%20light#0)
But none of the listed dealers on the Philips website seem to have it in stock.
I know I could roam JC road and find it, but there are so many fakes in the market.
Anyone have any leads on where else I could look for these bulbs ?
PS: Please don't suggest Reliance AutoZone, they keep only bling bling white light bulbs.
praful is offline   Reply With Quote
Old 23rd August 2013, 14:52   #7533
Thanked: 20 Times
Hi Guite; Could you point us to that specific page.
Secondly from where you got this setup fixed. I am from Noida and looking out for similar setup for my spark.
sparkguy is offline   Reply With Quote
Old 23rd August 2013, 16:55   #7534
sagarpadaki's Avatar
Thanked: 1,271 Times
Why roam around JC road when you have a Philips authorised distributer in JC road.
AK Traders
Once you enter JC road from the minerva circle you will encounter a signal just after the multi level car park. Take left over there . This shop is on the 3rd or the 4th left bylane . Google up for exact locations. Its not difficult to find
Old 23rd August 2013, 16:57   #7535
praful's Avatar
Thanked: 436 Times
AK Traders
AK Traders does not have stock! :(
As mentioned in my previous post, I tried the listed authorized dealers for Philips from their website.
AK Traders, Methode Electronics & Chawla were listed.
Old 23rd August 2013, 21:30   #7536
Guite's Avatar
Thanked: 180 Times
It's on page 480. I got it from Karstylo, sector 16 for Rs.900.
Guite is offline   Reply With Quote
Old 26th August 2013, 08:33   #7537
praful's Avatar
Thanked: 436 Times
How do I know if this is genuine Philips or a fake?
Old 26th August 2013, 08:42   #7538
SunnyBoi's Avatar
Thanked: 2,794 Times
Take a close look at the letterings on the bulb. If they appear smudgy, its most definitely a fake.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 26th August 2013, 08:50   #7539
praful's Avatar
Thanked: 436 Times
Definitely not smudgy. Thanks didn't know this
Old 27th August 2013, 00:01   #7540
srinivaspai's Avatar
Thanked: 22 Times
Guys,Through out this thread I read that 100/90 bulbs are not to be prefered to Nb/xv bulbs the reason being people are scared of reflectors,plastic lenses melting , discoloring or warping.But has anyone actually seen it happen in their cars?or is it more of a scare only.I do read a few members say they have used 100/90 or 130/100 etc for a couple of years in their cars without any effect but dont remember reading of anyone with first hand experience of actual damage.
Is it only a scarey thought ,thinking of the thousands of bucks needed to replace the lamps, that keeps people away from the high wattage bulbs?and settle for a lower output beam
any thoughts on this?
srinivaspai is offline   Reply With Quote
Old 27th August 2013, 07:43   #7541
CrAzY dRiVeR's Avatar
Thanked: 16,976 Times
I've been using 100/90 Phillips Rally bulbs in my WagonR- without any negative effects for over 7 years now. No effects seen on the plastics, and I believe Maruti would have used cheaper plastics than any other car maker.
However, we had trouble with the relay once, and lost the headlamps at night, luckily within city limits.
CrAzY dRiVeR is offline   (2) Thanks Reply With Quote
Old 27th August 2013, 08:03   #7542
govigov's Avatar
Thanked: 453 Times
100/130's on my old car created so much heat that it melted the clear plastic. So, it is in fact true.
I am yet to see reports for the 100/90 bulbs, which I am using currently in my current car. Comparing the heat generated with my older bulbs, these are definitely cooler. I had been using 60/55 stock for about 3 years before switching to 100/90 with relay. The heat output I felt with 100/90 is almost the same as stock according to me. If in fact, they do become yellowish after a few years. (I am using the 100/90 for about 3 months now, so too short to judge) and if the reflector has problems, my plan is to buy a new headlamps and then send it to one of the guys for fitting projector headlamps and the works.
govigov is offline   (1) Thanks Reply With Quote
Old 27th August 2013, 08:37   #7543
kash_pegasus's Avatar
Thanked: 28 Times
Apart from the damage to the reflectors as quoted in many cases- there is definitely an effect on the battery life.
More the power, more the current drawn from the battery, which the circuit must handle(precisely why we use the relays).
kash_pegasus is offline   Reply With Quote
Old 27th August 2013, 10:37   #7544
Hi All, After more searches for a "genuine, branded" relay and kit over the weekend, I gave up. As per a couple of feedbacks, I decided to go ahead with the "super" relay and kit. Have installed it with Hella Rallye 100/90 bulbs on my vista (H7/H1). The following were the observations:
1. The throw and the spread of the beam has improved, but not significantly. I asked the tech about it and he says its a design issue with vistas and they dont have the best of reflector/casing design. Not sure if this is true or if he was just washing his hands off.
2. I had the opportunity to take the car out during rains and I must confess that the high-beam's throw was not significantly better when compared with the 55/45bulbs that I had earlier. I wonder if this is expected.
3. The heat from the lamps have definitely gone up by a couple of notches. As noted somewhere in this forum, I am making it a point to not have the lamps on for an extended period of time, especially during bumper-to-bumper traffic within the city (exception being when on highways).
Any expert opinion on these points above is welcome.
Hella Rallye H7 100/90 bulbs - Rs. 600 for a pair
Hella Rallye H1 100/90 bulbs - Rs. 320 for a pair
Super relay and wiring kit - Rs. 850
Labor - Rs. 200
Cheers.
cs.giri is offline   Reply With Quote
Old 27th August 2013, 12:57   #7545
Thanked: 73 Times
Buddies,
I am looking for a rubber stalk mounted beacon for mounting on the rear end of motorcycles at a height of about 1.8m from level ground. The arrangement would be same as found in some police motorcycles in the West.
Any info available?
Atul
ATUL SINGH is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
