Old 24th September 2013, 09:06   #7606
Thanked: 106 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Using HIDs in a normal lamp can be tricky. The position of the discharge is different from that of the filament. Also, the light must be aligned again after lamp replacement. A 55 HID in a headlight is like a 150-200W bulb. I will stick to 35W HIDs in headlights, and treat 4300K as the upper limit. Also,mak sure you align properly. My son had HIDs in his Swift but I did not see any additional dazzle/ glare.
So how is the glare for oncoming motorists from your non-projector HID fogs? Sure must be more scattering of light than halogens.
Rgds
VineetG is offline   Reply With Quote
Old 24th September 2013, 10:55   #7607
sushrutha's Avatar
Thanked: 324 Times
Originally Posted by VineetG View Post
Hi, Great output pics. Can you also please put up pics of high beam, both against a wall and also on the road. That would really help.
Great Stuff
Rgds
I don't have any new pics, these are the ones which I took on Highway sometime back.
Kindly excuse for the shaky pics.
Auto Lighting thread : Post all queries about automobile lighting here-dscn4606.jpg
Low beam.
compare the spead of the light with other vehicles at the front
High Beam
Auto Lighting thread : Post all queries about automobile lighting here-dscn4604.jpg
Originally Posted by madhu33 View Post
Please remember 4300K is whitish but not completely white. Theoretically they are supposed to be the most ideal color for headlamps.
Will this situation remain the same even after the projectors ?
Or will the focused beam pattern from projectors help me a great deal even with 4300K HIDs that i have now.
It will improve a lot with projectors.
Checkout my above pics for HID projectors with 4300K bulbs
Also check the below post for comparison of Halogen vs 4300K hid colour
http://www.team-bhp.com/forum/attach...e-dscn4456.jpg
sushrutha is offline   (3) Thanks Reply With Quote
Old 24th September 2013, 11:26   #7608
madhu33's Avatar
Thanked: 293 Times
Thanks Sushrut ! that helps. the question now is . Which projectors to use.
Also yesterday i went to my accessories shop (it is a very big and very well experienced shop - Wheels car customs - Andheri Mumbai) and explained about this problem . They were very sure that installing projectors will not help the highway visibility . However your above pics is completely different and i will show it to them as well. The question now is : Which projectors are you using in your civic. ?
madhu33 is offline   Reply With Quote
Old 24th September 2013, 11:40   #7609
sushrutha's Avatar
Thanked: 324 Times
I'm using FX-R projectors.
These were sourced from THE RETROFIT SOURCE, http://www.theretrofitsource.com/
See it all depends on what kind of projectors and what Hid bulbs you use. Cheap chinese ones are better avoided.
Buy FX-R or Hella Projectors, as they are known for Low beam & high beam performance, you'll not regret buying it all.
They are superb.
You can't expect the beam penetration of high beam when compared with Auxiliary lamps.
Good Projectors will be sufficient for highway driving.
Manza has seperate headlamp reflector for high & low, you can add BI-Xenon projectors in the low beam barrel , which will act as low & high beam.
sushrutha is offline   (1) Thanks Reply With Quote
Old 24th September 2013, 13:20   #7610
madhu33's Avatar
Thanked: 293 Times
They are superb.
From the website you have mentioned The FXR projectors might be around USD 315+ import duty + shipping .
Would you recomend these Xenons from hella .
If you see the bottom of the pic it shows the throw would be around 300 mtrs. And also the beam pattern is pencil beam type (fog lamps beam pattern is exactly opposite to pencil beam)
The other advantage with them would be i can have them fitted in place of existing fog lamp or contemplate installing them inside the head lamps.
Old 24th September 2013, 14:19   #7611
sushrutha's Avatar
Thanked: 324 Times
Do you have any friends coming from USA ? If yes get it from them.
Else $315 will proove to be very costly for the Projectors , add some more amount for the retrofitting cost.
Meanwhile why don't you check from the below.
AES are reliable retailers on Aliexpress. I know some of my friends who brought from AES and they are happy with the products.
http://www.aliexpress.com/wholesale?...20130924002922
You can buy some of the projectors at a very good price.
Talking about the Fog lamps,
They are the famous Hella Micro de projectors. They are fog lamp projectors.
I think they retail for around 5-6K here.
I was suggesting you to buy either FX-r or Hella Evo X projectors from TRS.
Best and Cheapest option is install Hella Rally series auxiliary lamps.
Very good output, I've used them (3003 series) on my brother's Ritz and extremely happy with the light output.
http://www.team-bhp.com/forum/modifi...ce-500-ff.html (The Hella Experience - 500 FF)
Old 24th September 2013, 14:48   #7612
madhu33's Avatar
Thanked: 293 Times
1)No Sushrut, they are not the famous Micro D E fog lamp.
They are MICRO D E premium XENON .
Micro D E FOG have got exactly opposite beam pattern(no beam actually) whereas this Micro D E XENON posted by me has got a beam throw till 300 meters.
2)On the Hella EVOX : yes they are interesting. Will search through Hella site and ascertain the beam pattern .They are around USd150 (however dont know if i can find them in India)
3)Hella Rally series Aux lamp : I have that option at the back of mind. The only problem is to fit them on the car bumper / body which would hamper the aesthetics.
Old 24th September 2013, 14:52   #7613
sgiitk's Avatar
Thanked: 3,814 Times
The beams are pretty low. have a look at the pics - before and after. I will know only in late Dec or so, when the fog starts.
Old 26th September 2013, 11:56   #7614
Thanked: 26 Times
Looking for Philips X-treme vision H7 bulbs for Laura. Looked around a few auto accessories guys in Bangalore South but none seemed to have it. Anybody has a known source that I can try?
DieselDestiny is online now   Reply With Quote
Old 26th September 2013, 12:45   #7615
mayankk's Avatar
Thanked: 3,515 Times
How much of a difference would darkened headlights make for glare in case someone plops in HIDs without projectors? I know without projectors they are horrid. Or some kind of shroud on the inside to create an artificial cutoff?
mayankk is online now   Reply With Quote
Old 26th September 2013, 13:10   #7616
Dodge_Viper's Avatar
Thanked: 471 Times
Guys one question.
Regarding HID foglamps, do you get the normal OEM foglamps and then fit HID bulbs in that? Or the entire assembly is a seperate one?
Dodge_Viper is offline   Reply With Quote
Old 26th September 2013, 13:13   #7617
naveen.raju's Avatar
Thanked: 3,318 Times
Originally Posted by Dodge_Viper View Post
Guys one question.
You can fit HID's onto the OEM foglamps. Need to install a pair of ballast and wiring for it. You also get projector fog lamps.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 26th September 2013, 13:39   #7618
sgiitk's Avatar
Guys one question.
See my post at http://www.team-bhp.com/forum/test-d...ml#post3245112 (Honda Civic V AT Alabaster Silver) (Honda Civic V AT Alabaster Silver)
These were mounted into standard fogs as a bulb replacement. As naveen.raju has stated the Ballasts had to be installed.
sgiitk is offline   (1) Thanks Reply With Quote
Old 26th September 2013, 20:50   #7619
Thanked: 471 Times
Thanks sgiitk and naveen.raju!
If I install normal foglamps and then change the bulbs to 55W HIDs alongwith ballasts, do I still need to add additional relay?
I had installed relay for my upgraded 100/90 headlight bulbs.
Old 26th September 2013, 21:41   #7620
D'Artagnan's Avatar
Thanked: 126 Times
If I install normal foglamps and then change the bulbs to 55W HIDs alongwith ballasts, do I still need to add additional relay? .
HIDs don't need any relay. They draw only 55 watts of power, unless you import a higher spec hid kit then the wattage changes.
D'Artagnan is offline   Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11272 23rd February 2018 19:30
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4013 22nd February 2018 18:12
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
