Old 6th December 2013, 08:39   #7801
sohail99's Avatar
Thanked: 198 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Originally Posted by abir.sharda View Post
Hey guys, I have a question.
The headlights of my 2006 Innova seems to have faded out, I did get the halogens changed about a year ago but the beam is not satisfactory. Should I get new genuine headlights from Toyota or get Aftermarket Projectors installed.?
The projectors are costing about ₹ 18000 and I don't have an idea about the genuine ones.
Can you post a picture?
Seems like a polishing job to me!
sohail99 is offline   Reply With Quote
Old 6th December 2013, 10:41   #7802
Pferdestarke's Avatar
Thanked: 546 Times
Originally Posted by johannskaria View Post
I hope you are meaning like the ones attached below.
We do get it widely in India!
There are many in Vizag and Delhi who are experts in the work.
Well, I thought anarchy was asking just for the DRL strips and not for installation. Most of the mods experts get these from alixpress.
@anarchy: if you are looking for a professional DRL installation, Mr.Srinivas gopal is the person. He is based out at Vizag and does a fabulous job.
Pferdestarke is offline   Reply With Quote
Old 6th December 2013, 12:07   #7803
VinodDevil81's Avatar
Thanked: 344 Times
Originally Posted by anarchy_99 View Post
Can somebody tell me where to get this LED Strips which can be put to any shape and also changes colour from white to amber when required.
Do not go for the chinese strips. They may be cheaper, but will not last more than a few months. I too wanted to do it, but got this answer from most of the shops/technicians to whom I enquired. So I dropped that plan. Majority of those strips which we get here , (either through shops or through ebay) are low quality chinese ones. It would be better to use them as external DRLs rather than fixing them inside the headlamp assembly.So even if it goes off after a few months, replacing/removing it won't be so difficult.
VinodDevil81 is offline   Reply With Quote
Old 6th December 2013, 12:38   #7804
Thanked: 546 Times
I second you on this. They don't last long and moreover they don't serve the purpose of DRLs as they are not bright enough to make your car stand out, they are just meant for decorative purpose. Philips DRLs are best to go and if placed properly they can enhance the looks. And they last really long too.
Old 6th December 2013, 13:36   #7805
abir.sharda's Avatar
I agree.! I used a basic headlight restorer, made the plastic less dull. But I did not explain myself completely. The reflector might also be the issue.
Auto Lighting thread : Post all queries about automobile lighting here-img_1153.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_1154.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_1155.jpg
abir.sharda is offline   Reply With Quote
Old 6th December 2013, 15:00   #7806
sohail99's Avatar
Thanked: 198 Times
Attachment 1175195
Attachment 1175196
Attachment 1175197
Thanks for the pictures. I'd first completely polish the headlamp lenses.
Machine polishing would achieve great results in this case!
Only after the lens is perfect, can we comment on the reflector!
(and you dont specifically need a headlight restorer. Any of the polishes like Meguiars Ultimate compound or polish can achieve better results)
Old 6th December 2013, 16:34   #7807
Thanks for the quick reply sohail.!
So mechanical polishing meaning a buffing machine or something like it.?
I'll use some polish and put in a lot of elbow grease in till then
P.S. If I need thee headlights changed later, are projectors good or new genuine ones.?
Old 7th December 2013, 12:21   #7808
audioholic's Avatar
Thanked: 5,987 Times
I think the reflectors and inner side of the lens has gathered dust. Is the dust cover behind the headlamp assembly open or loose? I think you should open up the assembly and clean the reflectors. However be careful while cleaning the reflector. It is a sensitive surface and can get scratched easily. Use a very soft cloth or cotton to slowly lift the dirt.
audioholic is offline   Reply With Quote
Old 8th December 2013, 17:04   #7809
Thanked: 35 Times
Originally Posted by rbp View Post
Does any OSRAM dealer sell HID D2S bulbs [Not HID KIT]. Please help...
Try AVS Tuning. They are the authorised distributor for The Retrofit Source.
anarchy_99 is offline   (1) Thanks Reply With Quote
Old 9th December 2013, 23:47   #7810
Thanks for the advice, although i have no idea about the dust cover I'll only be able to tinker with it in Jan and get back to you.
Anyway, Searching and looking though other threads, I came across this http://www.team-bhp.com/forum/modifi...my-innova.html (PICS : Installed Bi-Xenon Projectors on my Innova). These are exactly the same projector kit available here, but I'm not a big fan of the DRLs around the Lamp (angel eyes).
Can I install only the HID lamps in the stock reflectors or is the projector lens needed.? (I'm a newbie to auto lighting, sorry)
Old 10th December 2013, 09:03   #7811
naveen.raju's Avatar
Thanked: 3,642 Times
There are different kinds of projector kits available. You can try the one without the DRLs. IMO, HID's on stock reflector is not recommended. Not much focusing and light will be scattered.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 10th December 2013, 09:46   #7812
audioholic's Avatar
Firstly as mentioned by naveen, HIDs in reflectors aren't recommended. You do get H4 HID bulbs with a similar beam cutoff that a halogen will give, but given the enormous output of the light source, a projector will be more efficient as it will make maximum use of the HID source and will not scatter light in unwanted directions.
To add to it, given the current condition of reflectors in your car, plonking HID will do more harm. Since the reflector is not clean or clear, it will cause excessive scattering which will not give you a good light output, at the same time cause a severe glare to the oncoming vehicles. Hence do not make changes until you sort out the reflector problem.
audioholic is offline   (1) Thanks Reply With Quote
Old 10th December 2013, 17:03   #7813
Thanks so much for the info guys.
The last thing I wanna do is cause glare to oncoming traffic. Its the one thing that really irritates me on road (specially in U.P.) I make it a point to use low-beam.
So I'll clean the reflectors first, check out the output from the halogens. If it doesn't seem good enough, like for highways, I should look for bi-xenon projectors. Sounds right.?
Old 11th December 2013, 11:44   #7814
itwasntme's Avatar
Thanked: 1,665 Times
Originally Posted by Sommos View Post
The NB+ has now been replaced by the NB Unlimited, which is even better.
The NB Unlimited (introduced only this month) claims to produce the brightest light, have no idea of the price though.
Bangalore grapevine says the Unlimited will retail for around 2.3k for a H4 pair. Quite a lot extra when the NB+ H4 pairs are going for around 1k
Availability by January' 14.
itwasntme is offline   Reply With Quote
Old 11th December 2013, 11:47   #7815
In case you plan to go for projectors, you need to check out the bi-xenon ones.
naveen.raju is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4093 18th June 2018 11:44
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11302 29th May 2018 12:23
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
