Old 18th May 2014, 15:28   #8146
sagarpadaki's Avatar
Thanked: 1,337 Times
Originally Posted by Crazy_Bean View Post
Hi Can someone help me with sourcing a Good HID H7 Kit?
My car has H7 bulbs in the Low beam (Reflector type), so what HID would perfectly replace it? H7? D2S? D2R?
What is the difference between H7 and D2R/S?
Good Indian brand for HID is P8.
You need D2R since you will be putting it on reflectors. But I doubt whether P8 HID make separate kits for reflectors and projectors. In philips you will get separate HID kit for reflectors and projectors.
sagarpadaki is online now   (1) Thanks Reply With Quote
Old 18th May 2014, 19:07   #8147
Mr.Boss's Avatar
Thanked: 2,548 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Query on lighting upgrade (general)
Does HL upgrade (100/90 or 130/100) require a battery upgrade too? We are running with 100/90W HL from 2004 (starting with Alto, Wagon-R, Beat, Sunny) without any issues with Stock battery. But one of my company cab driver complaining that his Logan battery doesn't last for even couple of years after he upgraded the HL to 130/100W (He used to have frequent overnight highway drives)
Some battery shop recommended him to upgrade the battery for higher wattage bulbs.
Is it really required?
Mr.Boss is online now   Reply With Quote
Old 18th May 2014, 19:32   #8148
sgiitk's Avatar
Thanked: 3,885 Times
1. Does HL upgrade (100/90 or 130/100) require a battery upgrade too? We are running with 100/90W HL from 2004 (starting with Alto, Wagon-R, Beat, Sunny) without any issues with Stock battery.
2. But one of my company cab driver complaining that his Logan battery doesn't last for even couple of years after he upgraded the HL to 130/100W (He used to have frequent overnight highway drives)
1. No.
2. Must be some other issue. Get the charging circuit checked. May be improper charging from the Alternator.
sgiitk is offline   (1) Thanks Reply With Quote
Old 18th May 2014, 19:36   #8149
Mr.Boss's Avatar
1. No.
Thank you Sir.
Even I doubt the same for 2 reasons
1) I / we (family) never faced any issues with 100/90 bulbs for more than a decade.
2) His vehicle is almost 7 years old with 2L+ on odo (running with stock alternator)
Old 18th May 2014, 19:42   #8150
Thanked: 14,610 Times
1. No.
For a 100/90 setup the stock battery and alternator will be working fine but what about 130/100?
Any chance of damage to the battery or the alternator or the whole charging circuit? Sorry for the noob doubt.
The damage I see is reflector blackening with the 130/100 setup.
Anurag.
a4anurag is online now   Reply With Quote
Old 18th May 2014, 21:15   #8151
Crazy_Bean's Avatar
Thanked: 198 Times
You need D2R
Thanks SagarPadaki, Really Appreciate your help on this. I was browsing their Ebay Store and they seem to have two options for H7 (One is Premium and one is not with prices 11.5k and 9k respectively). There is no mention of D2S or D2R nor the color temperature of light output. I am basically looking for 4300K.
Anyway, As you said Philips should have H7 D2R in 4300k. Not able to find it online. Anyplace you know?
Crazy_Bean is offline   Reply With Quote
Old 19th May 2014, 00:22   #8152
audioholic's Avatar
Thanked: 6,149 Times
As sir says, No.
130/100 upgrade will be as load intensive as maybe a mid-end audio setup with some amount of amps etc. And the load on the electricals by using 130/100 is again lesser compared to running stock lamps with a pair of 60w aux lamps.
Moreover, the battery is like a tank. Alternator is like a pump which will fill up the tank. Hence if any load in the car is too much, the battery discharge will be higher than charge and hence the issue will be a low battery after a prolonged highway drive. The alternator and RR unit do have the capacity to regulate output and I believe they can prevent overload.
Further down the line, it all boils down to how much the overall electrical load is. Too many electrical accessories will make the alternator work at full force, thus maybe shortening its life in the longrun. But if one upgrades only headlamps and everything else is stock, there wont be a problem IMHO.
audioholic is offline   Reply With Quote
Old 19th May 2014, 00:55   #8153
bread's Avatar
Thanked: 34 Times
I have a honda brio ex mt.
took delivery in oct 2013 .
I wanted to upgrade the headlamp bulbs.
it runs 60/55W H4 bulbs and they are not upto the mark.
1)should i go for philips 60/55 H4 bulbs(crystal vision or other variant)?
2)should i go for 100/90W bulbs.I believe i will need relay for that.I am not sure but i may loose my warranty of i add a relay.
bread is offline   Reply With Quote
Old 19th May 2014, 09:40   #8154
sgiitk's Avatar
I just bought a couple of H11/55W/3000K bulbs and Hyalutek ballasts (AC) and did the installation myself in half a day. No issues whatsoever. I got these from a chap who goes by the handle XenonPro on GH!
@MrBoss; ask him to check his wiring esp if he has a loom!
Modern cars have alternators of a very decent rating so battery should take the load (even the old M800 came with a 38A alternator, and 60/100A is now very common).
Old 19th May 2014, 10:08   #8155
audioholic's Avatar
If your use is limited within the city, then go for the latest Osram Nightbreaker version. Quite a sufficient replacement. However if you do highway drives often, then its better to opt for 100/90w bulbs. You dont have to worry about warranty as if there is an issue you would like to report to the ASC, the whole relay and wiring harness can be removed at home within a short time of 10 minutes and can be rolled back to the OE setup and the mechanics won't have a clue about it
Old 19th May 2014, 10:14   #8156
fusionbang's Avatar
Thanked: 1,097 Times
I am looking for a bulb upgrade on my Santro xing fog lamps. Any suggestions as to what wattage bulbs can go in? I think currently it has H7 bulbs, I am not exactly sure though.
Can anybody please help me on the same?
fusionbang is offline   Reply With Quote
Old 19th May 2014, 10:26   #8157
mayankk's Avatar
Thanked: 3,560 Times
H7 is a single filament bulb, and santro is a single dome headlamp.
I think it is h4 in the santro.
And the accepted norm is, I think, 100/90 for an upgrade.
EDIT: My bad, I missed out on the Fog lamps bit there.
Go for HIDs in the fogs.
That gives some credence to them at least. I spotted a set of HID-projectors for fogs on Aliexpress, and they were really cheap, about 25 usd. Planning to have them shipped over, and plop some quality HIDS instead of the OE that will come with them.
mayankk is online now   Reply With Quote
Old 19th May 2014, 10:28   #8158
fusionbang's Avatar
I am talking about the FOG lamp mayankk. I already have a 100/90 upgrade for my headlamp.
Old 19th May 2014, 11:06   #8159
bread's Avatar
Thanked: 34 Times
thanks audioholic,My longer highway drives are usually a couple of months apart,so i guess a simple replacement of osram NB should be sufficient.How much will a pair cost?you recommend me buying it from a shop for this or order it online?
this is what i found online
http://www.snapdeal.com/product/osra...d=5084&source=
Old 19th May 2014, 11:52   #8160
audioholic's Avatar
Buying depends upon your preference. No harm in ordering online unless there are some issues related to delivery in your area or something on those lines. But if you have the time its better you do some field work and check if the same bulbs are available for a lesser price in any of spare parts shops. Avoid accessory shops unless they are reputed since they may try to sell you older stuff or even fake ones. Spare part shops are much reliable IMO.
audioholic is offline   (1) Thanks Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
