Old 14th September 2015, 21:15   #9286
vin11's Avatar
Thanked: 77 Times
Query - How can one adjust foglamp alignment (vertical)?
Recently I removed my front bumper and saw a rotary knob connected with the foglamp, I twisted it a bit but couldn't make out for what it really was. Now after 2 days, I feel the output of one of my HIDs feels titled upwards. I assume this is because of the adjustment I did with that knob. If yes, I would align both the fogs to the lowest possible setting.
Anyone who has done alignment of the foglamps or has seen the process can confirm.
vin11 is offline   Reply With Quote
Old 14th September 2015, 23:37   #9287
Ushuaia's Avatar
Thanked: 23 Times
Has anyone been able to source genuine Osram 65w Rallye, if yes please share.
Ushuaia is offline   Reply With Quote
Old 15th September 2015, 10:49   #9288
JMaruru's Avatar
Thanked: 107 Times
Question Re: 100/90 Hella for swift VDi in B'lore?
Originally Posted by PMK-MoJo View Post
You may check in Konark accessories shop on jayanagar east end main Road. they have good collection and good staff for installation. Reasonable Pricing.
Would he be carrying genuine spares? I spoke to the guy on the phone, and he has stocks of Hella 130/100 Kit and also Hella 100/90 headlights.
Meanwhile, our Mandovi electrician has offered his services with MICO Super kit(130/100) and Hella 100/90 headlights for 1550/-(Including Installation). Is this a good deal? He does NOT have Hella kit. I had NOT heard of MICO Super. Has anyone here used the same, If so how is the quality of this setup?
Please advise.
JMaruru is offline   Reply With Quote
Old 15th September 2015, 13:05   #9289
Darth Sid's Avatar
Thanked: 114 Times
A small update on my 100/90W bulb installation on my Swift. I hardly get the time to drive and finally drove after about three weeks. Am using Osram Rallye 100/90W with a Philips harness. The bulbs are of good build quality and can be considered as an alternative to Philips Rally provided you buy the German made ones. Performance is as good as Philips but anyone else who has compared the two should also comment. Bought a pair from ebay for Rs 430+40 for shipping. Got a free car mobile charger with it. The seller was really quick to dispatch the bulbs. Keeping the Philips as spare.
On a side note I hope to complete the HID retrofit on my Duke very soon. In the meantime I have zip tied a Hella 60mm low beam module with HID bulb to the fork for illumination duties. Very impressed by its performance. Final product will not be as good because the lens of that projector is only 1.8 to 2 inches in diameter.
Darth Sid is offline   Reply With Quote
Old 15th September 2015, 13:57   #9290
hrbheda's Avatar
Thanked: 42 Times
Hello BHPians, I am interested in doing a fog light upgrade for my i20. The OEM bulbs are 26W H27 Phillips bulbs , made in Germany. I enquired at local shops and they say there is no upgrade for H27 bulbs.
It's going to be a DIY mod. I don't want to use any cut-out harness etc.
I require bulbs that will work with the stock harness. I am attaching the pics of the bulbs after I removed them.
Any help is much appreciated! Thanks!!
Auto Lighting thread : Post all queries about automobile lighting here-1442305589825.jpg
Auto Lighting thread : Post all queries about automobile lighting here-1442305604876.jpg
hrbheda is offline   Reply With Quote
Old 15th September 2015, 14:09   #9291
condor's Avatar
Thanked: 4,851 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
http://www.aliexpress.com/item/High-...1_5_4,201409_5
condor is offline   (1) Thanks Reply With Quote
Old 15th September 2015, 14:22   #9292
PatchyBoy's Avatar
Thanked: 1,396 Times
You should not be touching the glass part of those bulbs. Halogen bulbs are not made from common glass but from a more temperature resistant quartz-type glass. That is because a halogen bulb reaches much higher temperatures than a "common" bulb would. If you touch this quartz type glass, some of the fat and protein from your fingers will stick on it, and start to etch it at this high temperatures. This causes weak spots and eventually a shorter lifetime for the bulb.
PatchyBoy is offline   Reply With Quote
Old 15th September 2015, 15:54   #9293
hrbheda's Avatar
Thanked: 42 Times
I cleaned the surface with alcohol pads before reinserting them back! Although one of the bulbs is burnt out hence the need for the upgrade!
I always knew touching the glass reduced the lifespan of the bulbs but didn't know the technical details! Thanks for the details!
Thanks! I don't want LEDs! I need the regular yellow bulbs since they cut through fog better!
Thanks again for taking the time out to look!
Last edited by Gannu_1 : 15th September 2015 at 15:58. Reason: Back to back posts merged.
Old 16th September 2015, 21:38   #9294
condor's Avatar
You can look to replace the lamp itself so that you can use a H7 or similar bulb. The mounting points would most likely be different, so you would need to figure out how best to mount it.
Old 17th September 2015, 00:21   #9295
hrbheda's Avatar
Thanked: 42 Times
That's a good idea ! Let me hunt around and see what's compatible with the existing wiring and the light housing.
Thanks!!
Old 18th September 2015, 23:24   #9296
JMaruru's Avatar
Thanked: 107 Times
Please advise.
Any help here? I would like to get this done, this weekend. I have NOT heard of MICO Super. I prefer the Mandovi electrician, as he is company trained. But he comes with his own recommended set of harness/kit and headlights.
Also, what would be the recommended upgrade of headlights for Alto. I might get this work also done along with the swift. Can it also hold a 100/90 headlight setup? Please advise.
Old 19th September 2015, 00:04   #9297
Darth Sid's Avatar
Thanked: 114 Times
I am not sure if this is the same Mico that makes spark plugs. If it is, it can't be too bad. Best would be to source a Hella kit or Philips if the former isn't available. I bought and installed a Philips harness myself in my Swift petrol. No problems observed. Quick and easy DIY install. Only locating the points to anchor the harness took time. Main thing is that the wiring quality should be good and the relay should be robust. If you had the time, you could have sourced the Hella harness online. Maybe you could buy the harness elsewhere and ask your electrician to install it.
By the way, many people here have installed these 100/90W kits in their Swift's. That's why I did too.
Darth Sid is offline   (1) Thanks Reply With Quote
Old 19th September 2015, 00:26   #9298
Thanked: 14,352 Times
This is the kit that I am using in my Swift ZDi :
Philips Rally 12V 100/90W P43t
https://www.amazon.in/dp/B00JGN7RRG/..._UYf.vb50YJQKY
Hella - Lighting Harness For H-4 Bulb (upto 130W)
http://m.snapdeal.com/product/Hella+...re&viewinapp=1
This is a DIY and would take 15-20 minutes and is reversible. I am happy with this install and have done more than 15K kms with no issues whatsoever. No headlight fading too.
a4anurag is online now   (2) Thanks Reply With Quote
Old 20th September 2015, 21:27   #9299
Thanked: 186 Times
I searched the forum a lot to figure out a best dealer in Bangalore who sells headlamps and installs the same - want to go for 90/100W with wiring harness for my Punto. Or a DIY will be sufficient? Any suggestions/recommendations on dealers?
vinodvayyat is offline   Reply With Quote
Old 21st September 2015, 19:29   #9300
ant_vas's Avatar
Thanked: 203 Times
Vinay,even i am also looking for upgrading my Punto Evo 1.2 headlamps. Not sure if i need a extra kit to use 90/100w.
I searched around and found this: http://epitstop.in/Rally-Upgrades/Bu...id-205005.html
what do you think?
ant_vas is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4097 23rd June 2018 12:16
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11302 29th May 2018 12:23
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
