Old 28th November 2015, 16:29   #9436
naveen.raju's Avatar
Thanked: 3,726 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Originally Posted by Turbohead View Post
Planning to upgrade the bulbs in my Vento( single barrel lamps). Yellow light is enough as it is more of a need than a want.
Went through this thread and here is the list
Phillips Rally H4 90/100W.
Phillips relay kit.
Is this correct? Have I missed out on anything? I'm planning to do a DIY so any useful sites with pictures and simple instructions would be nice.
Turbohead
There are two options:
1) Stock wattage but a better brand (philips/osram). This is a straight forward fix but the improvement is only 20-30%.
2) As you had mentioned (90/100w) - The visibility improves in this case but on the other hand a lot of heat will be produced (if you use it a lot at a stretch. Else it's absolutely fine). I think it's better you get this installed from an experienced mechanic. If you think you can DIY, then no issues. Just mentioned so that you can be on the safe side
Originally Posted by nagen_rao View Post
Hello ,
Can someone tell me what bulbs to use to increase the brightness brightness n distance in the the 3rd generation scorpio (2015) as the stock bulbs are very poor the highways.
If you have projectors, go for HID's (Philips/Osram/P8). Make sure you stick to 4300k bulbs. That provides the best visibility. If you dont have projectors, go for the options that I mentioned above.
naveen.raju is offline   Reply With Quote
Old 28th November 2015, 16:52   #9437
Turbohead's Avatar
Thanked: 284 Times
Can you elaborate on how many hours? If at all we use it for long stretch, it will be for 6 hours or so( only on long drives which maybe max 3 or 4 times in a year as far a night driving is concerned)
I want the upgrades done as I find the stock bulbs useless on a rainy night.
Turbohead is offline   Reply With Quote
Old 28th November 2015, 19:15   #9438
That should be fine. I had used 90/100w in my swift with couple of long night runs (5-6 hours) atleast 3-4 times a year and didnt find any issue. Go ahead with this but just make sure that the installation is perfect.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 28th November 2015, 20:22   #9439
Singh09's Avatar
Thanked: 173 Times
What are the stock bulbs that are used in Elite i20 sportz? I am asking it because I feel that the light throw is not sufficient while driving on the highway. So can anyone help me with what is the stock type and what I can do to improve the same. Thanks
Singh09 is offline   Reply With Quote
Old 28th November 2015, 21:44   #9440
vishnurajanme's Avatar
Thanked: 172 Times
Stock bulbs are H4 55/60. Local make. I forgot the name of that company. Haven't heard the name anywhere. I am personally using Osram Coolblue Plus 55/60 bulbs in my elite complimented by Philips crystal vision ultra 37.5W foglamp bulbs and osram cool white T10 leds as pilot lamps. The combo is well and good for night drives except for times when there is rain. During rains, this setup and the factory setup don't have much difference.
You may also upgrade the headlamps to 90/100W bulbs using a relay kit from any reputed brand. Factory wiring cant handle that much wattage requirement.
vishnurajanme is offline   (1) Thanks Reply With Quote
Old 29th November 2015, 03:41   #9441
Zen2001's Avatar
Thanked: 18 Times
Changed the green dashboard illumination of my zen to "reddish"
Zen2001 is offline   Reply With Quote
Old 29th November 2015, 14:39   #9442
Singh09's Avatar
Thanked: 173 Times
So do you recommend upgrading to 90/100W bublbs with relay or upgrading to a HID setup for headlamps and fog lamps or HID with Osram/Philips bulbs in the fog lamps? Which one would be a better combination out of three?
Old 29th November 2015, 20:58   #9443
saadat1992's Avatar
Thanked: 293 Times
90/100 will last longer & are easy on your reflectors. HIDs will be extremely good initially, they'll burn your reflectors & your lens will fade over time. My friend faced such issues in his cars and reverted back to 90/100. Also, 90/100 Halogen has better penetration in fog!
saadat1992 is offline   (1) Thanks Reply With Quote
Old 29th November 2015, 21:14   #9444
Thanked: 14,609 Times
Best suggestion is to upgrade from 60/55W headlamps to 100/90W setup with wiring harness. The harness will contain ceramic harness, 30A fuses, thicker wiring to compensate the load.
OEM bulbs in my Swift were: Jagan H4 60/55W where I insisted for Osram Bilux. Both these were useless.
Upgrade 1: Philips Xtreme Vision (60/55W). It is was a good upgrade but the availability is low for this bulbs so had to go for upgrade 2.
Upgrade 2: Philips Rally 100/90W with a wiring harness by Hella. Love this setup and is completely reversible and safe with no touching the OEM wiring harness. It is a plug and play unit that takes 15 minutes to install.
I'll suggest you to look at 100/90W setup. If you aren't happy, get fog lights upgraded. OEM ones should be 35W where you can change to 55W. I was thinking of getting the fog lights upgraded from H8 (35W) to upgrade to H11 (55W). But have refrained as I hardly use the fog lights.
a4anurag is online now   (2) Thanks Reply With Quote
Old 29th November 2015, 21:45   #9445
Aakarsh's Avatar
Thanked: 159 Times
I have an Alto lxi 2008 at home. It isn't equipped with fog lamps. Some upgrades to the headlight assembly such as high power bulbs and relay has been made and results are better but sometimes I feel there is a need of fog lights too. Is there any solution? Is it possible to get it done in a fuss free manner?
Aakarsh is offline   Reply With Quote
Old 29th November 2015, 23:40   #9446
Option 1 (Costlier one): Get a new bumper of the VXi variant and get the Fog lamp kit installed (MGP).
Option 2: Install auxiliary lamps. Look at the link: Hella 700FF (DIY! Hella 700FF Installation)
IMO, Option 2 is the best and easiest to get satisfactory results.
a4anurag is online now   (1) Thanks Reply With Quote
Old 29th November 2015, 23:49   #9447
ashwin.terminat's Avatar
Thanked: 1,310 Times
Originally Posted by ashwin.terminat View Post
I use an Xtreme Vision on my motorcycle. Have been using it for well over three years now.
Just one real suggestion, in crawling traffic, I find it best to turn off the headlamps and use just the pilot lamps to ensure visibility. When everyone is bunched up in traffic, the lights from the vehicles nearby is good enough and it also lets the bulb cool down for a bit.
I have a query of my own. I saw the thread about the Morimoto D2S being installed on a Polo GT.
Wondered if there was a similar kit for my bike and voila, I found it!
https://www.theretrofitsource.com/co...l#.Vlizj-LLdyU
I am looking to get the 50W version since the bike was already re-coiled to accommodate a 55W halogen. Will the electricals be able to take a 50W HID though?
My question is, is the upgrade really worth the 10k odd it will cost? I am looking for effective lighting solutions that will also be effective during the rain.
Bumping my own post.
Any ideas, guys?
ashwin.terminat is offline   Reply With Quote
Old 30th November 2015, 01:18   #9448
Aakarsh's Avatar
Thanked: 159 Times
Thanks for the input sir.
Actually at the time when we acquired this car, I clearly remember lxi was available as the the top variant. Vxi came into the picture after the launch of facelift. AFAIK Vx and Vxi(not sure) were available in 1.1 L models.
Sir, there is provision for installation of fog lamp kit in the existing bumper also but the problem is that the space provided is sqaure in shape whereas the MGP fog lamp kit for Alto is round. Fog lamps won't be an exact fit. Would it be possible to cut the bumper appropriately in shape? Attaching a picture for reference.
Aakarsh
Old 30th November 2015, 06:40   #9449
Any ideas, guys?
35w is mostly found and used here and I would suggest you to go for it. 35w is more than enough and provides ample lighting.
Old 30th November 2015, 09:20   #9450
silversteed's Avatar
Thanked: 1,669 Times
Any ideas, guys?
HID ballasts come in 55W, not 50W. However, a 35W HID burner+ballast combination is the most logical upgrade over halogens.
For your question regarding the VFM proposition, I feel it is, if you are not experimenting. Else it's a costly experiment.
The set up will be effective even during rains, provided you do not use burners with anything over 4300K colour temperature. Most of the LEDs sold as pilot lamps are 5000K or above and do little to improve illumination during fog and rain.
silversteed is offline   Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
