Old 31st August 2017, 10:05   #10651
sgiitk's Avatar
Thanked: 3,902 Times
Default Re: Auto Lighting thread : Post all queries about automobile lighting here
Originally Posted by silversteed View Post
2700K is more Yellow, and is better suited for foggy conditions than 4300K which is warm white. The Professor was referring to conditions that necessitate the usage of proper fog lamps, and not just rains where a warm white would do.
And, "colder" is not meant in the literal sense - anything below 3000K is called Warm (white), 3000-4500K (IIRC) is Cool white, and above 4500K as Daylight. Colder than 5200K implies higher colour temperature
Let me add a qualifier. Color temperature is for 'black body radiation', and neither HID nor LED are that. HID uses a phosphor which converts the UV output of the discharge to visible. This will be basically bank spectrum. LEDs would have essentially three light outputs which will blend into what we see.
So it is at best perceived color temperature.
Old 31st August 2017, 12:19   #10652
Thanked: 297 Times
Found this product from PIAA, seems really good, has anyone bought this? Any feedback on performance.
PIAA RF6 6" Ion Yellow Wide-Spread Fog Beam Kit
http://www.piaa.com/store/p/800-PIAA...Compliant.aspx
Also found this comparative study of different auxiliary lamps by different manufacturers, not sure if this is already shared, thought it might be helpful for everyone.
http://www.fourwheeler.com/product-r...tival-of-leds/
It also contains a video followed by the analysis.
Cheers,
Trojan
Trojan is offline   Reply With Quote
Old 1st September 2017, 11:33   #10653
kutoos's Avatar
Thanked: 123 Times
Dear Friends,
Please help me on my quandry. I've a 2016 Ciaz, and the low beams are pitiful. After reading through this forum, decided to go for a bulb upgrade rather than a relay.
I'm considering to purchase Osram H7 P64210 Night Breaker Unlimited NBU Duo Box (12V, 55W) from Amazon.
My confusion is:
1. Change the low beams to Osram NBU, leave the High beam as stock
2. Change both High & Low beams to Osram NBU
Most of my drives are restrictted to the city with occasional highway trips. Now if i choose to go with option 2, will there be any fire risks associated due to over heating? I'm in favor of this option as I'm planning a trip during october.
Kindly suggest the best option for the above.
kutoos is offline   Reply With Quote
Old 1st September 2017, 11:45   #10654
Thanked: 190 Times
Originally Posted by kutoos View Post
Dear Friends,
My confusion is:
You should get Osram Night Breaker Laser bulbs, as NBUs are last gen bulbs now. Philips Racing Vision is another latest gen performance bulb. There should not be any fire risk, as they operate on the same voltage as the stock bulbs.
I am using H4 NBUs for the past year, and I am not totally satisfied with the high beam. As someone, a few posts above, said yellow lights from the oncoming traffic tend to drown out the NBUs whiter output.
H7s are different as they have only a single filament. I would suggest get one pair of the bulbs you like, and try them in the high beam position. If you are satisfied then good, otherwise you can use them as low beam bulbs. Low beam output is good anyways.
halfbytecode is offline   (1) Thanks Reply With Quote
Old 1st September 2017, 11:54   #10655
kutoos's Avatar
Thanked: 123 Times
Thanks halfbytecode for the quick reply. As suggested will go with lasers for the low beam for now.
Old 1st September 2017, 13:20   #10656
T-Rex's Avatar
Thanked: 19 Times
Hi, instead of Amazon, I'd recommend getting it from Powerbulbs.com, as they supply genuine bulbs and offer free shipping. Amazon, eBay and local accessories shops are flooded with fakes or duplicates that can't be easily be identified. The delivery may take around 2-4 weeks, but worth the wait. Also, usually there is a 20% discount on the site.
T-Rex is offline   (1) Thanks Reply With Quote
Old 1st September 2017, 23:04   #10657
Epic's Avatar
Thanked: 457 Times
Originally Posted by harsh79 View Post
The alignment looks slightly better, skewing can be corrected only reopening the headlight assembly and physically realigning the projector.
Do I really need to reopen the headlight and realigning the projector? I was told by the installer that the RHS projector is set fine but the bulb is probably not fitted perfectly. Setting the bulb right will solve the problem. Not sure if this is correct.
Your previous alignment where the right side beam is lower and aligned with the lower part of the left beam is the right way to get rid of this dark spot. And that is how OEM projectors are aligned as well.
My realigned beam cutoff pattern is exactly like it is on my Jetta.
Epic is offline   (1) Thanks Reply With Quote
Old 1st September 2017, 23:10   #10658
harsh79's Avatar
Thanked: 677 Times
Default Auto Lighting thread : Post all queries about automobile lighting here
A friend is looking to upgrade to LED bulbs. Are the following any good?
First two are 6500k bulbs,he plans to add a 4300k tint tube to them.
http://s.aliexpress.com/yuMnIRJ7
http://s.aliexpress.com/i2Y7f6vA
http://s.aliexpress.com/YfQVNNni
http://s.aliexpress.com/7zya6zQV
Also is it worth buying such bulbs at all? Or will he get just marginal gains, compared to Philips Xtreme Vision Plus.
harsh79 is offline   Reply With Quote
Old 1st September 2017, 23:17   #10659
harsh79's Avatar
Thanked: 677 Times
You could reseat the bulb and check, only one way to find out.
Old 1st September 2017, 23:19   #10660
Epic's Avatar
Thanked: 457 Times
So now here is weird problem that I am facing after installing the aftermarket projectors from Xenon Planet.
When all lights are OFF : When trying to flash the hight beam, lights do not come on at all.
When low beam is ON : When trying to flash the high beam, only RHS high beam works.
When low beam is ON : When stalk is moved to high beam position, the RHS hight beam comes on for a split second and headlights shut OFF. If stalk is moved back to low beam position, the low beams come back on.
Everything was initially working fine. I really need help identifying the above issue as it is driving me nuts. The guys from XP believe it is the relay.
Epic is offline   (2) Thanks Reply With Quote
Old 1st September 2017, 23:47   #10661
SunnyBoi's Avatar
Thanked: 2,843 Times
This is a simple case of LHS high beam wiring getting disconnected/component failure.
I assume this is on a car with H4 headlights?
The way H4 headlights work is by having two separate filaments in a single bulb for low and high beams. Which also means either low or high beam is on; never both on at any point of time.
Unfortunately it does not work that way for projector setups. Whenever you put the car on high beam, it only moves a solenoid inside the projector and nothing else. It also means the solenoid has to move AND the bulb should be on. Most relay setups wire the bulb to low beam and solenoids to high beam and have a mechanism in place to force low beam to be on when you switch over to high beam. When this mechanism fails, the bulb will turn off (low beam turns off) when high beam is turned on and thus you see the high beam for only for a split second.
In short, the quality of wiring kit or lack thereof is to be blamed.
This is again as per what I have explained above. Since the bulb does not turn on when the low beam is explicitly off (flashing mode) only the solenoid for high beam moves and you will not see any lights.
How do I know? I hacked a Philips H4 100/90 wiring harness to power six projectors on my car. All it took was a 4 rupee component to force the bulb to be on during high beam, that too reliably.
SunnyBoi is offline   (7) Thanks Reply With Quote
Old 2nd September 2017, 11:52   #10662
graaja's Avatar
Thanked: 3,741 Times
Sunnyboi's explanation is spot on. In H4 setup, only either of the filaments come on. In the BiXenons, high beam is just a shutter lifting off exposing the full light beam. So, even when high beam is turned on, low beam should still be on to power the HID ballasts. A proper H4 wiring kit should have a diode that will power the relay when high beam signal goes high. This will ensure the ballasts are powered and light up the bulb.
As you say everything was working fine initially, this should mostly be some loose contact or component failure in the wiring kit. Talk to XenonPlanet and get the wiring replaced.
For the 2nd problem where you try to flash with low beam on and only RHS high beam gets activated, this could be a shutter failure in the LHS projector.
graaja is offline   (1) Thanks Reply With Quote
Old 2nd September 2017, 13:00   #10663
headers's Avatar
Thanked: 464 Times
I have a projector setup in my 2014 Verna SX (o)
Find the headlights inadequate for speeds over 100 at night.
Any suggestions?
Old 3rd September 2017, 01:21   #10664
Epic's Avatar
Thanked: 457 Times
Thank you SunnyBoi and Graaja for the detailed replies but I am a bit confused. I have understood the working of an H4 bulb when in a halogen set up vs when in a projector set up. Since I have mentioned the symptoms and you guys have replied accordingly; what I do not understand is whether the issue is with the wiring kit or solenoid of the projector?
When you say component failure; is this component (relay) of the wiring kit or component (solenoid) of the projector?
Yes the car has H4 headlights.
Based on your above reply, a defective relay / wiring kit is the cause of Symptom No 1 & 3? Please correct me if I am wrong.
I have already brought up the issue to XenonPlanet and they have asked me to visit again so that it can be sorted out. They usually attend to installs & issues on Monday as the installer is free on that day. For me, it means taking an entire day off from work on the first day of the week which is not possible to do again. I have instead bought a new set of wiring from Morimoto which will replace the wiring from XP.
If this is a shutter failure on the LHS projector then its going to be a disaster as this would mean opening up the headlight again and a confirmation that XP products are not reliable. And I say this because post install the wiring kit has already been changd once and so has the RHS projector for a shutter failure. All this with in 1.5 months post install!!!
Old 3rd September 2017, 01:50   #10665
SunnyBoi's Avatar
This is regarding symptom 2 where high beam is coming on for only one projector - It can be as simple as wire connection for the high beam solenoid coming off/problem in wiring harness or worse case scenario that the solenoid inside the projector gone bad which will require replacement of the projector. We cannot say for sure which one.
By component failure I meant failure of solenoid inside the projector.
Correct. Its purely due to a defective wiring kit.
SunnyBoi is offline   (2) Thanks Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4105 9th August 2018 10:07
Formal dressing and tailoring for all occassions (EDIT: Put all your queries here) manaa45 Shifting gears 85 1st August 2018 11:18
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11316 28th July 2018 12:16
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
