Old 2nd January 2008, 18:51   #1246
Default Xenon for NHC
Hi guys,
Can you please let me know if anyone has any experience with changing the stock headlight bulb of NHC with Xenon. If yes, howz the experience and approx how much it costs?
thanks
skydiver is offline   Reply With Quote
Old 2nd January 2008, 19:32   #1247
n_aditya's Avatar
Thanked: 2,782 Times
For the second time my RHS high beam filament has fused (in about 6-8 months). Using Philips Rallye 130W/100W with relay and all. The previous bulb lasted over a year. The LHS however is still going strong for over 2 years and with no change yet. *touchwood*.
Do i need to get the electricals checked? Had got it checked last time and was told its ok. Are these bulbs prone to low operating life? I dont think so cos the LHS bulbs are fine and they are the first set for almost over 2 yrs now.
Old 2nd January 2008, 19:48   #1248
Thanked: 29 Times
@ kartik iyer - i have the pre crde scorpio and have been using the 100/130 headlight bulbs with cutout etc. 'touchwood' no issues till now.
rgds
indianrunner is offline   Reply With Quote
Old 2nd January 2008, 20:01   #1249
arpandiv's Avatar
Thanked: 27 Times
Originally Posted by kARTIK IYER View Post
have fitted standard Lumax lights on my bumpers , It really is not of great help and light thrown is average and is now use as a additional light . Can you suggest a good bulb that i can replace this with current ones and what will be cost
Could you post a pic of the light along with the mounting?
Lighting from such lights depends on
1) reflector
2)Mounting
3)wattage of bulb.
Such bulbs usually take in a H3 bulb.
try putting in a Phillips 100W h3 bulb,make sure your wiring supports this though.
Mount the reflector in such a way that it is able to focus light onto the area where you need it. What kind of illumination are you looking for? a spread ? or a spot?
arpandiv is offline   Reply With Quote
Old 3rd January 2008, 19:32   #1250
kARTIK IYER's Avatar
Thanked: 12 Times
Hi ,
It is fitted in the bumpers where there is space for extra lamps on the bumpers and it is not the refelector ones .
If you can suggest me then i will discard this one and install a reflector one with better visibility as this is showing me area road right below till some distance ahead .
Rgds .. kat
kARTIK IYER is offline   Reply With Quote
Old 4th January 2008, 00:01   #1251
arpandiv's Avatar
Thanked: 27 Times
umm all lamps have a reflector buddy.
Whats the shape of the lamp?
If you want you can try for a "plough lamp" they provide decent spread.
Old 4th January 2008, 11:16   #1252
arif_t01's Avatar
Thanked: 112 Times
I think Kartik is refering to 'Fog Lamps' when he says 'Bumper Lamps'
arif_t01 is offline   Reply With Quote
Old 6th January 2008, 13:21   #1253
Default need help
hi this is soban
looking for zen bumper signal light with fog light combine
and smoked head & tail light
pls help
thank you
soban is offline   Reply With Quote
Old 9th January 2008, 03:55   #1254
aah78's Avatar
Thanked: 1,752 Times
Default 6000k-6500k
Originally Posted by viper316 View Post
The next thing for the low beam i have a xenon 10000k hid light , in the low beam there is a cutter which cuts the light so that it acts as a low beam and the light is not speard all around , i wanted if we can remove that cutter which places the light as low beam.
Can't help you with the high beam. Don't know what you mean by cutter, but as far as your low beam is concerned - your 10000k HID produces a very dark violet coloured light - thats why you probably don't see a beam spread. You should be fine with 6000k to 6500k, which is what OEM's use.
check this:
Originally Posted by tsk1979
2000K would be yellow, around 4000-5000K would be white, 6000K is blue tinge white, 8000K would go towards violet.
aah78 is online now   Reply With Quote
Old 11th January 2008, 07:17   #1255
straight6's Avatar
Thanked: 118 Times
Can I install an Hid Kit on my RX-135 if I upgraded the battery?
What modifications am I looking at if I have to go ahead with this?
straight6 is offline   Reply With Quote
Old 11th January 2008, 14:12   #1256
praJEEP's Avatar
Get an amby round headlamp dome(doom) from the scrap market its a direct fit on the RX, a 9amp battery woulb beenough to handle the HID, but i have adoubt where are you going to fix the ballast box in your rx ??
praJEEP is offline   Reply With Quote
Old 11th January 2008, 18:32   #1257
Thanked: 13 Times
check this:
Yeak 6000k is the ideal colour temp. I think OEM's usually run 4300-6000k if im not mistaken.
Also a guy who worked in a company manufacturer HID kits told me that identical ratings(say 6000k) from 2 differement manufacturers would be a slightly different colour. But in general its like the charts show.
Old 12th January 2008, 16:09   #1258
straight6's Avatar
Thanked: 118 Times
I have already found the headlight of a Hero Honda CD Dawn, it holds an H4. My only concerns are will the battery get charged when the HID is running? Will I have to upgrade the rectifier? Will A relay help?
Old 12th January 2008, 16:58   #1259
Akshay1234's Avatar
Thanked: 7,244 Times
hids only use 35w so it shouldnt be a problem.
Old 12th January 2008, 18:16   #1260
praJEEP's Avatar
No problems then go ahead. but i am again asking where are you going to fix the ballast kit. battery will get charged when hid is on, but make sure you upgrade the battery before.
EDIT: upgrade the rectifier also..
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11304 5th July 2018 12:59
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4100 3rd July 2018 11:24
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
