Old 4th January 2011, 22:36   #1
Default Swift K-series dyno run. Only 55 BHP?
Hello Everyone.
I did a Dyno test for my Swift and was told its only giving 55bhp at wheels.
This was like a shock to me.
Has anyone done a dyno for Swift/Ritz Kseries ?
Need the graph to compare ?
Havent seen any Kseries getting Mods.
Anyone with headers on K Series ?
Does it make any difference? Have heard mixed feedback.
thanks in advance
prasanna_gem is offline   Reply With Quote
Old 4th January 2011, 23:13   #2
sajo's Avatar
Thanked: 1,064 Times
Default re: Swift K-series dyno run. Only 55 BHP?
Just 55 hp at the wheels! Thats about a 35% loss!
PS : Doesnt 'feel' that way though.
sajo is offline   Reply With Quote
Old 4th January 2011, 23:24   #3
nitrous's Avatar
Thanked: 285 Times
You were just told about the peak power?
nitrous is online now   Reply With Quote
Old 4th January 2011, 23:36   #4
CrAzY dRiVeR's Avatar
Thanked: 19,895 Times
At what rpm? And how much has your vehicle run till now? Putting more details will be very helpful here.
Old 5th January 2011, 00:34   #5
lilMonSter's Avatar
Thanked: 28 Times
Could you post a Dyno graph. 55bhp is shocking.
lilMonSter is offline   Reply With Quote
Old 5th January 2011, 02:58   #6
dhanushs's Avatar
Thanked: 4,505 Times
From where did you dyno your car?. And like nitrous said, telling isn't sufficient. Where is the dyno graph/stats?.
Old 5th January 2011, 07:25   #7
Sankar's Avatar
Thanked: 4,654 Times
You got dynoed your K Sereis Swift? Post the dyno graph please. And where did you get it done?
Old 5th January 2011, 13:11   #8
CPH
Thanked: 34 Times
Hello Everyone.
thanks in advance
How many runs did you have?
What dyno was it on?
What were the ambient conditions?
What fuel are you running?
How many kmis has the engine engine done?
Due to constant changes the ECU will alter fueling constantly, which doesn't show full power when doing only one run.
The poor additive quality in our fuels (world wide) piston rings get sticky, which can lead to lasses of up to 12%.
Hi ambient air temp and extreme dry air can lower power too.
CPH is offline   Reply With Quote
Old 5th January 2011, 15:05   #9
Did it at RRP.
Its a New Car barely done some 3k kms
However after checking with Kean he said its normal the its in the same range for 1.3 Swift also.
Havent had a chance to go there today.
Will post the graph and other details on thrusday
Old 5th January 2011, 16:03   #10
Shan2nu's Avatar
Thanked: 89 Times
55whp for a stock Swift at RRP seems ok.
A 106bhp stock VTEC does around 71whp on their dyno.
Shan2nu
Old 5th January 2011, 16:37   #11
srishiva's Avatar
Thanked: 933 Times
Does the RRP dyno have anything against Jap engines? The dyno on Optra looks good and whats with Swift and VTEC?
srishiva is offline   Reply With Quote
Old 5th January 2011, 17:06   #12
Headers should be done my Friday@RRP
Checked the Stock 1.3 swift graph too it looks mariginally better. Will have the pictures once i get the fitting and dyno done after the Headers fitting.
RRP is charging a bomb for the turbo kit. Have already spent more than expected on Headers cost .
How much does the Turbo kit cost and where can i get it done ?
Old 5th January 2011, 18:37   #13
kutlee's Avatar
Thanked: 202 Times
to answer the last question, cost (lots of options from used to brand new or combination of new and used). Where - lot of places. check t-bhp directory.
did rrp recommend turbo kit on the k-series ? or did they include something on the engine side also?
kutlee is offline   Reply With Quote
Old 5th January 2011, 19:34   #14
Yes RRP is very open to Turbo on a car , that where they get to make the most money
However that being said there is definately a hell lot of difference when doing a turbo for Street car Vs Rally Spec Vs Drag .
For example the Rally car with just the Turbo would not even stand a few kms unless it has Rally Suspension / Chasis hardening etc.
Infact before putting a Turbo Suspension needs to be hardened.
Old 7th January 2011, 14:18   #15
Sankar's Avatar
Default Re: Swift K-series dyno run. Only 55 BHP?
Do update us after you get headers installed, eagerly awaiting the results.
Would love to see the 55BHP graph along with the after headers graph. Please post them.
Honda Civic Dyno Run no.2 - With performance exhaust GTO Modifications & Accessories 69 9th October 2014 14:57
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour GTO Modifications & Accessories 108 18th February 2011 07:58
Honda Civic Dyno Run no.1 - Stock GTO Modifications & Accessories 117 17th December 2010 12:06
Monkeys remapped RS on the dyno. Only 144 BHP at the wheels? GTO Modifications & Accessories 91 18th March 2008 02:06
