Old 11th July 2011, 22:16   #32
noidaboy's Avatar
Thanked: 260 Times
Default Re: H&R Lowering springs from Germany for my Maruti AStar!
I had put EIBACH's on my swift and ruined the stock shock's with in 2days OIL had leaked.
Does your car bounce off at high speed in a bump?
noidaboy is offline   Reply With Quote
Old 10th August 2011, 12:40   #33
Sankar's Avatar
Thanked: 4,651 Times
No haven't tried any of that. Don't believe it'll do much as in all probability its a box that tricks ECU with a wrong IAT sensor reading.
I had these on for few weeks and took it off after that. It did make the car more bouncy since the stock damper couldn't control the rebound. No the dampers didn't leak.
Old 25th March 2012, 20:46   #34
Sankar's Avatar
Its lowered again and after an year. This time i didn't put the spacers at the rear and put spring as it should. The ride is now better than how it was when i had these on with the rear spacer, with the spacer the springs were more preloaded and made it much bumpy. So far i'm enjoying the vast increase in handling, i can take corners much faster and without a hint of body roll. The lowered stance goes well with these deepdish model alloys.
Sankar is offline   (3) Thanks Reply With Quote
Old 7th August 2014, 11:08   #35
Hi Sankar, are these springs available for the 2004 Alto 800 cc ?
could you share some info .
max_911 is offline   Reply With Quote
BMC Carbon Dynamic Airbox install in Maruti AStar! Sankar Modifications & Accessories 18 3rd March 2015 14:41
Why Isn't The Maruti AStar Selling Well? anjan_c2007 The Indian Car Scene 249 16th July 2012 00:48
SKODA VRS lowering springs any problems Frank Zappa Technical Stuff 1 25th June 2010 16:32
Maruti Wagor R Duo or Astar Vxi ? EDIT - Booked i10 Era sb1 Hatchbacks 33 20th July 2009 11:47
Lowering Springs for Baleno crazydiablo Modifications & Accessories 17 9th July 2009 08:31
