Old 26th January 2016, 19:37   #1516
R2D2's Avatar
Thanked: 405 Times
Default re: Power Horns!
Originally Posted by Darth Sid View Post
The stock horns in my '15 Swift were a pair of small sized Hella units. Not sure what their current draw is but when I installed the Hella Supertone (Red Grill) I installed a relay and 6 sq mm wires. Current draw of those is 5.5-6 Amps each. I don't think the stock horns draw that much. Had you bought genuine Megasonic horns you would not have needed a relay since they only draw 4 Amps each. To be safe I suggest you add a relay. My post about this installation is probably on the previous page.
I agree, the stock horns probably draw about 3A each and the relay (if any) is appropriately rated.
But if you install high power horns of 5-6A each it's best to install a separate relay bypassing the original wiring (whose gauge/cross section is also rated as per OEM specs) and taking a direct connection from the battery terminal. 2.5 sq mm or better should do the job.
Do not take risks with electrical fittings as they can cause a fire hazard. Make sure the tech installs a 15A blade or cartridge fuse on the +ve line less than 12" from the terminal.
I purchased a pair of Hella Red grills many years ago and am still to install them. This thread is acting like a catalyst.
R2D2 is offline   (1) Thanks Reply With Quote
Old 26th January 2016, 19:39   #1517
Thanked: 54 Times
Hey guys,
I am looking to change the horn of my Grand i10. Most of you must be knowing that it is not that powerful a horn and I have a few questions.
1. Will it affect the warranty (mine is a 3 month old car)?
2. Will it be as reliable as the stock horns of different cars?
3. I would like a horn that is not irritating but loud enough to move out of the way( have been particularly fond of VW horns)
4. Anywhere in Trivandrum for fitting?
5 . Budget of +/- 2K
6. Good brand
7. Waterproof (Car has to see a lot of water)
Any tips would be nice.
Thanks in advance.
The Dude is offline   Reply With Quote
Old 26th January 2016, 20:41   #1518
swift_guy's Avatar
Thanked: 245 Times
Thank you for the advice. Current horns are 3 Amp
each. Do I still need to get an additional relay? If so, I might switch back to OEM ones instead of this relay and wiring mess.
Yes I went through that post. Current horns are 3 Amp each (and 6 Amp was for set) and I guess I won't need an additional relay. One thing I didn't understand was that you are using stock low tone horn also? Are you running 3 horns at a time?
swift_guy is offline   Reply With Quote
Old 26th January 2016, 22:03   #1519
R2D2's Avatar
Thanked: 405 Times
Yes, you would need an additional after market relay. It's simple, the OEM factory fitted relay is probably designed for constant load of 6A (so it is designed to carry about 9-10A max assuming a margin of about 50% over max load possible) while your Hellas have a 12A total draw requiring a relay of about 15-20A. Keeping a margin is very important unless you want that relay to fail prematurely.
To install or not is your call really. But I'd recommend it because I am careful about potential electrical fire hazards in the car caused by less than sensible wire & relay sizing and haphazard installations.
Avoid cutting into OEM wire harnesses as much as possible. They are expensive to replace.
Old 26th January 2016, 22:30   #1520
swift_guy's Avatar
Thanked: 245 Times
Oops, I think I did not make myself clear. I have not got Hellas but some local-made horns which look similar to Roots Megasonic. They (i.e. the local ones I have) have a total draw of 6 Amps max. (i.e. 3 Amp each horn, 6 Amp for set). So I think the stock relay would be enough, what do you think?
But as you said, that there is a potential fire hazard without a relay, I am thinking of going back to stock horns. Installers here don't know how to add a relay without cutting OEM wires, and doing it as a DIY would be a tedious task. The local horns aren't very loud anyway, they have a heavier "bheep" sound as opposed to the irritating "peenp" of stock.
Old 26th January 2016, 23:55   #1521
Darth Sid's Avatar
Thanked: 74 Times
Oh, yeah... When I was done fitting the new horns and completed the wiring, I realised the stock low tone was still installed and connected. I was too lazy to remove that so I let it be. New pair runs on my wiring and the stock low tone on the stock wiring. Three horns. No cutting was done anywhere. Took me an hour to remove the new horns and their wiring and the 100/90W setup before I took the car for its second service. Then another hour to put all of it back on afterwards.
Darth Sid is offline   (1) Thanks Reply With Quote
Old 27th January 2016, 00:15   #1522
R2D2's Avatar
Thanked: 405 Times
Buddy, can I be honest with you? IF and that's a big IF those locally made horns are accurately rated for current draw then get a relay fitted. Believe me, you do not want a fire hazard in your car. I believe in erring on the side of caution.
Save yourself future inconvenience and get a pair of Hellas/Roots/Bosch/Denso horns. These are OEM suppliers and quality is good. Thing is, they are not very expensive, and these suppliers rate their horns pretty accurately.
OEM wires don't need to be cut if one does this job in a methodical manner. Just use spade connectors of a size that matches those fitted at the factory. No need to splice/solder/twist-and-join wires. Unfortunately most folks in India do not take safety seriously. It's a mind set. If your auto electrician does not know how to do this take it to someone who does.
But if there's absolutely no one who can do a good job with the wiring then stick to your OEM horns.
R2D2 is offline   (2) Thanks Reply With Quote
Old 27th January 2016, 01:12   #1523
swift_guy's Avatar
Thanked: 245 Times
Sure thing sir. I will switch to OEM horns this weekend. In NCR, auto electricians are too lazy to care for our cars and do the wiring as I will direct them to. They will definitely splice somewhere and I will be at loss. Too much wiring (like connection from battery terminal) means raised eyebrows of service advisors. One fellow reminds me everytime that "Saar your warranty is void" seeing the power cable for the amp from battery terminal. Truth is that no wires are cut and I can change back to normal in minutes.
I got tempted and took this local-made set for 500 bucks and the seller gave a demo comparison also, in which these sounded heavier (not louder) than Roots Megasonic. Let's not take chances for these small things when I have spent six big ones on the car.
Old 27th January 2016, 03:44   #1524
Darth Sid's Avatar
Thanked: 74 Times
Even I don't trust electricians to do these simple jobs cleanly. I stay in NOIDA and did the horn installation on my Swift and Duke myself. I even did the whole HID retrofit on my Duke myself. Wiring a set of horns is actually the simplest DIY job you can do since the circuit is so basic. Reverting the wiring before taking the car to a service centre doesn't take much time. It took me one hour because I have to take the bumper off to get to the horns.
Old 27th January 2016, 09:55   #1525
rakesh_r's Avatar
Thanked: 544 Times
Originally Posted by The Dude View Post
Hey guys,
6. Good brand
Thanks in advance.
You can buy the horns that come on the Creta (they come with the VW type). You can ask your HASS to do the installation. In that way,you don't loose on the warranty.
Regarding waterproof,you will have to locate a good place inside the engine bay since the ones that come in the Creta though are certified waterproof do not perform well if water gets inside.
rakesh_r is online now   Reply With Quote
Old 27th January 2016, 10:04   #1526
swift_guy's Avatar
Thanked: 245 Times
Does Creta come with trumpets?
Trumpets aren't the best choice when 'waterproof' word is considered.
Old 27th January 2016, 13:45   #1527
rakesh_r's Avatar
Thanked: 544 Times
The creta comes with nice and loud sounding trumpets and yes,have agree in the water resistant part.
PS-I have been using Seger trumpets on my swift since 3 years.Installed them at the same place where the stock horns were.Still going strong even when the car had seen the worst of the Mumbai Monsoon.
Old 6th February 2016, 10:06   #1528
Sheel's Avatar
Thanked: 3,932 Times
My Hella red grills were acting up and I thought, it is the end of the road for them. Went to my trusted electrician and he opened them up, cleaned the points and it is working as new.
As per him, if next time round it stops working, he will change the points with the ones on roots [they fit and roots is available]. Points are available for [approx] Rs. 200+ for a pair.
I believe once a year, horns too require a visit to its service center
Old 6th February 2016, 17:09   #1529
saadat1992's Avatar
Thanked: 287 Times
I'm not sure about Hyundai, but Toyota refused to install Innova's horns in my car even when I offered to pay them. They said it was against the norms to do so.
saadat1992 is offline   Reply With Quote
Old 7th February 2016, 02:08   #1530
Jag4's Avatar
Thanked: 97 Times
Unhappy Airbag Warning Light on i20
Hello all, I own a 2012 Hyundai i20 Crdi sportz model which has been running on Hella Red grills since Day 1. After about 4 years of usage, the Airbag Warning light came up on the dash recently. The horns run on the stock wiring with the stock relay.
Upon further investigation by the Hyundai Service center folks I was told that due to the usage of 'High Powered' Horns the switch next to the Airbag Sensor has gone kaput so I need to revert to stock Horns and get the sensor replaced for approximately Rs.2000.Red grills are rated @ 55w vs stock horns @35w(Last I checked).
Now I wanted to confirm if anybody else has ever faced a similar issue in their cars since there are a lot of Airbag equipped variants of every vehicle these days.
Jag4 is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
