Old 29th March 2016, 15:01   #1546
straight6's Avatar
Thanked: 115 Times
Default re: Power Horns!
Stebel Nautilus is available on ebay. in for 1750 and I'm going to get one soon. Anyone else that may have got one recently please give your feedback.
straight6 is offline   Reply With Quote
Old 3rd April 2016, 15:24   #1547
stanjohn123's Avatar
Thanked: 421 Times
Guy's I'm getting the Bosch Symphony Fanfare horn for my Verna.
I just wanted to know if it's necessary to install a relay for these horns ?
On the website some guy's told it was not necessary to install the relay, but even if I do install the relay will it enhance the sound of the horn or help improve it's life ?
stanjohn123 is offline   Reply With Quote
Old 3rd April 2016, 15:28   #1548
RocketRaccoon's Avatar
Thanked: 138 Times
I recently went for Hella Red Grill Supertones and the accessories shop guy told me that a relay is required to max out the horn else it would not work at full capacity. The product came with a relay in the box.
RocketRaccoon is offline   Reply With Quote
Old 3rd April 2016, 18:03   #1549
Grr7's Avatar
Thanked: 190 Times
The current drawn by Hellas is much more than the stock horns.
While most accessories guys would fool customers by saying that new cars comes with inbuilt relay for horns(which is true), but they won't tell/know themselves that the stock relay is selected wrt requirements of stock horn.
You MUST always install an additional relay for power horns. The good part with Hella Red Grills is that they come with a relay in the box.
I had to purchase a separate Hella relay(sourced from another Hella Red Grill's box by the shopkeeper) for installing my Roots Megasonics.
The shopkeeper sold it to me at a price of Rs.150. So, if the shopkeeper dissuades another buyer in installing Red Grills w/o relay, he is going to save on his manpower and make some additional moolah by selling the relay to other aware customers.
Grr7 is offline   Reply With Quote
Old 3rd April 2016, 18:32   #1550
Thanked: 421 Times
Red Grill Super tones is more powerful, so it definitely needs a relay. The symphony fanfare is Bosch's basic model so it's much less powerful hence not sure still about the relay for it.
Old 3rd April 2016, 23:15   #1551
Sheel's Avatar
Thanked: 5,097 Times
I am thinking to add a megasonic in my S10. Would it require a relay? The electrician told me it has a relay but will a separate relay be required for an additional horn?
This is to be used on highways where dumb (deaf) won't hear you coming & flashing too doesn't help.
Old 4th April 2016, 11:49   #1552
greenhorn's Avatar
Thanked: 1,492 Times
any aftermarket horn deserves a relay. usually the roots dealer will sell a relay along with it which should be enough.
When you say "it has a relay" - What has ? The car has a stock relay, but thats enough only for the stock horn.
also, I am not sure it will fit internally - didnt fit my indica, so had to downgrade to a vibrosonic - else you'll have to fit brackets and fit them like foglights
Old 6th April 2016, 18:39   #1553
Sheel's Avatar
Yes, the Scorpio's OE relay and as per few electricians, it is good enough for Red Grills, even the shop keeper said so [he would earn something or the other selling me a relay, no..?]
I will have to see on that as I don't want megasonics to be visible outside, will surely have to check on that.
Old 6th April 2016, 19:19   #1554
greenhorn's Avatar
it can be made to fit on the firewall, but that will compromise its sound output - you'll be the one hearing the majority of its output, not the intended audience. Ideally it should go somewhere behind the bumper
Old 20th April 2016, 12:27   #1555
I own Verna too and I have had the same question in my mind. A friend of mine who is a technician as well suggested me to go along with relay, it is always safe to install the horns along with relay, let the stock units remain untouched.
To add to that, avoid switch that helps to swap between stock and aftermarket horn, because you may have to cut the factory wire for such installation.
I'll be installing one in a week time.
Hprmodern is offline   Reply With Quote
Old 1st May 2016, 07:39   #1556
Thanked: 421 Times
I installed mine last week. It was simple DIY, only issue was removing the bumpers last screw under the wheel well.
I found that I already had a relay installed for my old horn so it was simple plug and play job.
Bosch say's that this horn works without the relay but on research I found that there is no harm in installing a relay and might sometime be better too.
The horn sound's good and it costed only 500 bucks
stanjohn123 is offline   (1) Thanks Reply With Quote
Old 1st May 2016, 10:02   #1557
R2D2's Avatar
Thanked: 1,332 Times
I am afraid it is not that simple. Each factory fitted relay (and wiring) is sized for the OEM horns. If your horn instructions specify using a relay then you must fit one.
Powerful after market horns like the Red Grills draw around 2x more (at approx 5.5A/66W each) than the power of the originals. Don't take this lightly. Red Grills come with a relay in the box and it must be used along with the correct wire size (2.5 or better still 4 sq. mm should be fine). Keep in mind shop keepers aren't really interested in your car's electrical safety.
Old 3rd May 2016, 00:59   #1558
BB311's Avatar
Thanked: 151 Times
Installed the Hella Supertones (Red Grill) in my ecosport. The original dual horn OEM setup also had the relay, however their rated power was 33W and Hella runs at twice that power. Even my trusted shopkeeper told me that relay is not required, but when I said that I have read it on Team-BHP that its required, he installed the original Hella supplied one's without making a fuss, citing that folks here know more.
Its one heck of a horn, very sharp and loud, is loud even inside
BB311 is offline   Reply With Quote
Old 23rd May 2016, 20:20   #1559
bhandary's Avatar
Thanked: 80 Times
What are the legal limitations in terms of decibels for a horn in Bangalore city? Has anyone been pulled up by the authorities for a loud sounding horn?
If I recall it correctly, all types of Air Horns were banned in Coimbatore wayback in 2005 which was a boon since all the private moffusil buses were equipped with all kinds of loud sounding air horns to push away any motorists who came in their path.
bhandary is offline   Reply With Quote
Old 24th May 2016, 17:44   #1560
What is the ampere rating of horns in Honda Brio? Is there any better horns with same ampere rating for Brio? I do not want relay setup, so do not prefer high ampere horns.
sibitg is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
