Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 11th July 2007, 23:57   #196 (permalink)
Originally Posted by Mugen_Power View Post
Vijay..
Who fitted horns like this ?? dont ever go to him for installation.
Both horns fixed wrong, its fitted like it is for your pleasure.
It is better to fit one horn than fit two horns.. go to another installer and get the hella red grill fitted towards bumper. and check the installation guide of stebel.
Thanks Mugen Bhai will do that as soon as possible.
Vijay
vijay_k is offline   Reply With Quote
Old 12th July 2007, 11:00   #197 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Originally Posted by vijay_k View Post
By the way do you know any good garage in bangalore where i can get this job done?? Because i know only MASS in bangalore and i am sure they wont do it.
Vijay
Vijay PM Mclaren he can guide you to a good garage, and yes with a lil bit of work you can fit the hellas properly
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 12th July 2007, 15:10   #198 (permalink)
Thanks you Jaggu bhai will PM Mclaren immediately.
Vijay
Old 12th July 2007, 20:15   #199 (permalink)
hemi's Avatar
found some intresting stuff
HornBlasters Air Horn Products Catalog! Find The Perfect Train Air Horn For Your Car Or Truck!
these guys sell train horns for cars!
hemi is offline   Reply With Quote
Old 13th July 2007, 10:41   #200 (permalink)
mobike008's Avatar
Yes it is better to get Roots than duplicate horns.
Roots Vibrasonic will cost you around 700 and Roots megasonic will cost you around 1200.
Whats the difference between vibrasonic and megasonic?
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 14th July 2007, 00:34   #201 (permalink)
Megasonic are bigger,louder and costly than Vibrasonic.
Mugen_Power is online now   Reply With Quote
Old 14th July 2007, 10:57   #202 (permalink)
mobike008's Avatar
Ok thanks, thought must be something special like a dual sound capability or something
__________________
Old 15th July 2007, 00:05   #203 (permalink)
You cant expect from Roots..
Roots and durable, repairable and reliable cheap horns.
Old 16th July 2007, 11:03   #204 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Stieble nautilus, while it sounds good dont last too much of abuse. The clip that holds the trumpet to the pump came loose and finally broke, so now i am left with a working pump but leaking trumpet. :(
__________________
Old 17th July 2007, 11:57   #205 (permalink)
firingonallfour's Avatar
Thanks for the suggestion dude but the problem is that there is no that much space to turn the Hella facing outwards.
Swift engine bay is too compact there is absolutely no space anywhere so it is very complicated to fit these kind of accessories.
Vijay
I bought Stebel Magnum off eBay.in and installed them in my swift. Its difficult to fit both the units in the place where the stock horn is fitted. The access to the horn is via the mud flap / guard ( i.e just in front of the underbody of the front wheel). Since both did not fit in the same place I installed one in the stock location and ran a wire to the same location but near the other front wheel. A place to fix a nut and bolt is present.
Mind you The passenger side fog lamp has a grill for the horn but the driver side does not . I have installed both facing forward and don't feel that one sounds louder than the other. Stebel mannums are definately better than stock, but I have heard some louder ones.
__________________
__________________________________________
If you don't like the way I drive, stay off the sidewalk!
firingonallfour is offline   Reply With Quote
Old 17th July 2007, 13:25   #206 (permalink)
mobike008's Avatar
how much you got it for on ebay? Was the delivery fast?
__________________
Old 17th July 2007, 15:02   #207 (permalink)
Swift engine bay is too much cramped to fit these additional horns even i have the same problem and i have stebel nautilus which is bigger than Magnums which make things worse.
I will be going to a different mechanic who is suggested by one of the members here to change the location of the horns, let me see how it will sound after changing the location.
Anyhow can you please post a pic of the place where you have installed the horn?? It would make things a lot more clear..
Thanks in advance,
Vijay
Old 17th July 2007, 20:00   #208 (permalink)
I got it for Rs 630 Shipped. I think I might have paid about Rs 150 more for not moving my behind to an actual shop in the market. The seller was from around mumbai and hence I got it within 24 hours. Out of Mumbai locations might take 48 hrs I believe.
__________________
Old 18th July 2007, 22:15   #209 (permalink)
Thanks in advance,
Vijay
Vijay,
the stuff that I am pulling out with my finger comes off when you remove those plastic screws. The first horn goes there. The second horn goes on the other side same place. You need not remove the plastic thingy on the other side since you can reach the location from under the bumper. Its possible to do the operation without removing the bumper. Install time about 15 mins.
I am posting pictures for the first time so guys jump in and tell me if this is right
[img=http://img518.imageshack.us/img518/8385/hornsis4.th.jpg]
[img=http://img518.imageshack.us/img518/3441/grillfu0.th.jpg]
__________________
Old 18th July 2007, 23:15   #210 (permalink)
Vijay,
Thanks a ton man, really appreciate your efforts in helping me find the exact location and making things more clear.
Will go to a good mechanic and get it done as soon as possible.
And you have posted the pics in the correct way not to worry..
Vijay
Thread Tools
Echo horns for SX4 gopinathann Modifications & Accessories 5 4th June 2008 14:53
Horns for my Swift D DieselFan Modifications & Accessories 1 8th April 2008 12:48
The Best & Safe location for Power Horns mithun Modifications & Accessories 3 21st July 2007 07:30
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
