Old 3rd September 2007, 18:25   #256
BUSA's Avatar
Originally Posted by maddy42 View Post
Hey can anyone help me as i have an esteem and i want to fit it with the horns which are there in th optra or skoda. Can u tell me what is the name and is it banned? Also the name of the company and model name and do i need any modifications to fit them??
They are called Windtone rainbow, Roots makes it, so does bosch and hella.
Old 6th September 2007, 03:25   #257
people!
which horn would you suggest for a tata safari?
something thats guaranteed to clear the roads.
btw i use the horn only when really needed and i dont blare them for fun
doctorkats is offline   Reply With Quote
Old 6th September 2007, 16:45   #258
ankitahuja's Avatar
Thanked: 46 Times
Hey doc, the simplest option is get Hella Red Grill, will work well for your requirement.
Old 6th September 2007, 17:05   #259
dr.abhijeet's Avatar
Thanked: 67 Times
recently, i switched from hells red grill to stebel nautilus.
however i am not very happy with the sound, i think my red grills were louder.
and i feel the nautilus is loosing it sound for last few days. especially after the last highwaytrip.
anu idea if teh nautilus can b adjusted??
dr.abhijeet is offline   Reply With Quote
Old 6th September 2007, 17:10   #260
panky12345's Avatar
Thanked: 127 Times
am also looking for a strong horn.... except nautilius and hella.
Old 14th September 2007, 06:39   #261
nirmalts's Avatar
I have a roots windtone installed and after yesterday's heavy rain in Bangalore it makes only a feeble sound. A truck guy spashed lot of water on to my bonnet and I am sure water has gone inside the horn. Do you think the horn could be damaged and needs repair or will it come alive after water drains/dries?
Nirmal
nirmalts is offline   Reply With Quote
Old 14th September 2007, 13:17   #262
mithun's Avatar
Thanked: 49 Times
Nirmal
Roots horns are repairable. Go to your dealer !
Old 14th September 2007, 16:00   #263
panky12345's Avatar
Thanked: 127 Times
nirmal: remove your horn from the car and place it near 100W tablelamp, it would be fine.
Old 15th September 2007, 10:13   #264
nirmalts's Avatar
Thanks Panky for the tip. I removed the horn and turned it up side down and water poured out. It has started working already, but still slightly feeble. Dont have a 100W bulb. Hence using a hair drier.
The horn was behind the front grill and it was placed with its vent up. I see chances of water going in again in Bangalore rains. I plan to point the vent down when I fix this back? Is this ok? Will it affect the sound of the horn as it will be pointing down?
Nirmal
Old 15th September 2007, 11:39   #265
gd1418's Avatar
Thanked: 656 Times
How about a pair of Stebel Nautilus?
Originally Posted by doctorkats View Post
people!
Old 15th September 2007, 11:59   #266
Thanked: 11 Times
Single Nautilus will be more than enough i think.
Mugen_Power is offline   Reply With Quote
Old 15th September 2007, 12:02   #267
panky12345's Avatar
Thanked: 127 Times
nirmal dont use hair dryer (for moisture issues)....
Old 23rd September 2007, 23:56   #268
i use a pair of roots horns in my swift. they are the OEM for skoda auto, ford, honda, mitsubishi, volvo, toyota in india. they are loud enough and sound great too. they costed me Rs.450 in delhi.
sanchits is offline   Reply With Quote
Old 15th October 2007, 12:15   #269
I bought Stebel Magnum horns from JC Road alongwith relay this Saturday for 900 bucks. But the relay makes a "clicking sound" when horn is used. I got to know that this is because I have amplifier in car for ICE which causes the "clicking" and a solid state electronic relay instead of normal relay should solve this issue.
Has anyone used this solid state electronic relay in car? How much does it cost and where is it available?
Please help.
toretto is offline   Reply With Quote
Old 15th October 2007, 12:45   #270
rkbharat's Avatar
Thanked: 613 Times
I have FIAMM Horn, in Pair , Installed in my Indica, and they sound very loud and Macho, good enough the clear the road. but the typical installation Location is very bad in Indica, that the horn sound inside so high enough to scare away my 5 month old daughter.
So last week I moved them in front, while taking two risk. One, they are very low in position now, more prone for water damage, though pointed down. Second, for loose wire or adjustment, whole bumper has to screwed open, will take lots of time and DIY is tough.
But In cabin sound/noise is reduced to half, or even less, now.
rkbharat is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
