Old 3rd March 2008, 09:33   #316
Question
a basic question..
I want to install nautilus in parallel with the stock horns, and for this i need to cut the wires to add the toggle switch.. Now i dont care about the warrantly issue, as it has already expired for my fusion (3+ years)... All i care about is the safety/security of the vehicle and hence its occupants!!
We have heard lots of instances about car burnouts in recent past (have actually seen couple of them in delhi). Does by any case these modification in the wirings leads to any thing dangerous!! ofcource even if done by a very good electrician using quality wires/relays/condensors!!
I would also like to know which kind of wire, relay and condensor will be required to do this job!!
Thanks..
gauravchawla is offline   Reply With Quote
Old 3rd March 2008, 10:09   #317
rider60's Avatar
Thanked: 47 Times
Originally Posted by gauravchawla View Post
a basic question..
Thanks..
check out the previous posts you should find the answers to most of your questions with pictures!
rider60 is offline   Reply With Quote
Old 3rd March 2008, 11:27   #318
Thad E Ginathom's Avatar
Thanked: 8,340 Times
Sankar says that loud horns will save lives, but Amit tells that his makes people get out of the way.
I don't think that forcing people out of your way is justification for making more noise pollution.
However I find the Swift horn to be particularly puny so I might go for an upgrade myself one day! Of course, if I do, I'll be blasting those autos too, and I just hope I don't make any two-wheelers fall off, as they will definitely be getting full volume.
I also wonder why some Chennai buses have horns that sound more like a squeaking auto is behind you.
Old 3rd March 2008, 11:39   #319
krazydriver84's Avatar
Thanked: 42 Times
If you guys wanna hear truly loud horns. You should hear the horns that GD has installed in his scorpio. Stebels = 5 to 6 horns. man they are ear bursting.
krazydriver84 is offline   Reply With Quote
Old 3rd March 2008, 13:08   #320
amit_mechengg's Avatar
Thanked: 1,556 Times
u didnt get my point it seems. i force the idiot drivers out of my way who are going zip zap and causing traffic threats. i dont simply go and honk at people going with discipline. i have the OE horn for such people to request them to let me go ahead. but for crazy drivers my toggle switch is enough.
u may see many drivers driving in between the roads, moving at very slow speeds to save their petrol and not letting us to overtake. also some drivers have ipod earplugs plugged in and they dont bother about people coming from behind. the rickshawalas feel that "roads unke baap ke hai" and they can cut in whenever they want without signalling.
Old 3rd March 2008, 15:32   #321
abhibh's Avatar
Thanked: 34 Times
This is why i wanna buy a SAFARI!
Old 3rd March 2008, 15:51   #322
cool. dont forget to put the nautilus/ power horns to enjoy the bulky ride in city traffics.
Old 3rd March 2008, 20:15   #323
Point taken, and no offence meant.
I guess I was thinking of some of these SUV drivers that tailgate, flashing the lights, being downright rude. I slow down in front of them!
However, in the normal course of driving I believe that, if one wants to go slowly, one should pull over and let others past.
When I get that horn, I think I'll be using it in just the same circumstances as you do
Old 3rd March 2008, 20:26   #324
Sankar's Avatar
Thanked: 4,562 Times
It's not only the case with Chennai. Even here in Trivandrum and i suppose even in Bangalore city buses are not allowed to use air horns in city limits. Most private buses don't comply with this rule but government buses do.
It's a weird situation when you look into the rear view mirror to see a puny auto or a car but instead you see a huge scary government transport bus breathing down your neck!
Old 4th March 2008, 00:47   #325
Thanks for that!
At least I now know the reason
Old 12th March 2008, 16:19   #326
Aficionado's Avatar
I heard Fiamm horns are not available in market anymore as the company has been shut down. I had to get horns for my father's mercedes but had to settle for bosch instead.
Aficionado is offline   Reply With Quote
Old 12th March 2008, 19:30   #327
gd1418's Avatar
Thanked: 656 Times
Allegations... pure allegations without any basis... Let me correct you KD.
The stock horns in my Scorpio are a pair of Boschs, that have remained with me since my Amby days.
I've installed a pair of Stebel Nautilus Brio just behind the grill operated by a separate switch and that's it. These are never used in the city and are purely meant for the highways.
Old 12th March 2008, 19:32   #328
gd1418's Avatar
Thanked: 656 Times
I'm in total agreement with you about the behaviour of these louts on the road.. Sometimes I feel like owning a Vijayant and sneak behind these morons and lift them with the turret and deposit them on the sideways..
Old 12th March 2008, 20:37   #329
Wolffe's Avatar
Every car needs to have 2 sets of horns.One OE and the other to scare the hell out of people who don't respect the OE horn..Will be fitting the Stebel Nautilus next month on my Fiesta.
Wolffe is offline   Reply With Quote
Old 12th March 2008, 21:04   #330
humyum's Avatar
Thanked: 2,495 Times
True.No more fiamm horns.
humyum is online now   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
