Old 23rd September 2008, 13:29   #436
suzuki san's Avatar
Thanked: 310 Times
Buy two pairs of Hella horns (approx. Rs. 55o per pair). Use one pair as normal with a relay but additionally connect the high tone horn from the second pair through the relay so you have three horns (two high and one low) on the same horn button. Awesome crisp sound and very effective. Have been using this combination for the last five years and no issues. Clears the ricks, bikes and pedestrians. Only problem is the one unused extra horn which is wasted.
suzuki san is offline   Reply With Quote
Old 23rd September 2008, 22:03   #437
frankmehta's Avatar
Thanked: 2,260 Times
which can be used when one of the three conks out
i have a stebel nautilus and the mico bosch horns that sound like the optra..
also have one pair of the same in my zen and a pair of red grilles too.. i just realized the amount i add to noise pollution..
Old 24th September 2008, 12:53   #438
Modifiedsachin's Avatar
Thanked: 24 Times
After reading this thread I looked under my (car's) hood to see which horn is installed, as the horn has a switch on the dash with which I can disable it. And I was very happy to see these two blow horns & now I understood why the auto & bikers move immidiately when I start to horn.
I normally dont use horn, I normally use headliht blinking, but when the vehicloe ahead dont react I use horn and that works.
See what is installed (i think is a set of blow horns)
Modifiedsachin is offline   Reply With Quote
Old 24th September 2008, 14:34   #439
Thanked: 91,867 Times
You really need to clean your engine bay more often, man!
Old 25th September 2008, 00:14   #440
ultimatechamp's Avatar
Thanked: 93 Times
I genuinely second GTO. Modified Sachin,that engine bay would later on add to days of agony along with low FE (due to clogged air filter),and what not. It really needs thorough cleaning ASAP.
ultimatechamp is offline   Reply With Quote
Old 25th September 2008, 12:09   #441
suzuki san's Avatar
Thanked: 310 Times
hey Guys ...!
Need some inputs in fixing a new horn n a loud one..... will work as secondary horn to the original one with a separate switch...
did some research and found many the one i liked is below...it produces about 139dB...nautillus series
it is for sale on ebay at 900rs+..
IMPORTED COMPACT TWIN TONE NAUTILUS AIR HORNS
* To sample the Nautilus horn visit the stebel website at STEBEL S.p.a.
* Made in Italy.
* Loudest air horns in the world.
* The Nautilus TWIN TONE Air horns features compact space saving engineering that no other twin tone air horn in the world can offer.
* It's very fast and easy to install because it requires only ONE fixing point. No air tubes are required. The product is very practical & easy to install like an electric horn, yet features the power, reliability & uniquely pleasent tone of an air horn.
* The excellent sound output of approx 139 decibels ! Is INSTANT thanks to a perfectly balanced air jet system. The air intake has a patented system that gives a pleasant High and Low tone with surprising power.
* It combines the advantages of a electromagnetic horn with the nostalgia of an air horn.
* The design is ideal for cars trucks and buses and is perfect for openly visible installations on Motorcycles...
* 12Volts
Hi kpzen,
Was checking out horns at Milan Subway yesterday and inquired about the Stebel Nautilus. It is available for Rs.800 + fitting.
However, the shop guy suggested I should NOT fit these as first of all they are banned by the RTO and secondly, being air horns they suck in air (dusty in our country) and get clogged with dirt after 6 months to a year depending on usage. He said he has had quite a few complaints about them and in fact had stopped stocking them. They were available at a day's notice if I wanted.
Would suggest you do a re-think on this - or else fit a filter (K & N ???!!!!!) before the intake of the horn.
SS
Old 29th September 2008, 13:12   #442
suzuki san's Avatar
Thanked: 310 Times
Default Power Horn
Hi KpZen,
I visited another shop at Lokhandwala yesterday to inquire about the Stebel Nautilus. He had it in stock on the shelf but point blank refused to sell it to me as he said he had too many complaints about this horn and knowing how particular I am baout my car, he was sure I would be back in a couple of months.
Price was Rs. 750/=.
SS
Old 4th October 2008, 22:43   #443
there are many varieties in ROOTS . I got one for my swift for Rs 500 . Its awesome. I forgot the model. It is similar to the stock horns of SKODA
jakky88 is offline   Reply With Quote
Old 5th October 2008, 01:12   #444
kaushik_s's Avatar
Thanked: 148 Times
Using Fiam Windtone for a long time and it works very well to get the autos and buses to budge and that too in Bangalore ;-). Good thing is that although it's loud but not that loud to get the cops irritated. And if someone says that horn is a safety device in India then he is very right, saved many time by horn, it's loud enough even for the bus drivers to back off. Stebel Nautilus and hellas are definitely louder then this but they may attract the cops too. It costed me approx 1000 Rs along with the wiring and relay.
kaushik_s is offline   Reply With Quote
Old 13th October 2008, 17:29   #445
anantnehru's Avatar
Where would I get Red Grills in Delhi? Does it make sense to remove the stock horns or should I keep them as an option? Also, would positioning the horns behind the grill make more sense?
anantnehru is offline   Reply With Quote
Old 13th October 2008, 18:36   #446
ankitahuja's Avatar
Thanked: 46 Times
You will get them in Kashmere Gate.
Old 13th October 2008, 19:22   #447
Thanked: 93 Times
Read the thread well anantnehru.There are countless suggestions about how to go about fitting horns.Usual practice is to go for a toggle switch in dash,and retaining the older horn (thats what I have done too,check out 'view my garage' if you want !).Its upto you my friend,but read the thread to get good ideas.
Old 16th October 2008, 19:30   #448
anantnehru's Avatar
Any specific place in Kashmere Gate? Probably heading there tomorrow, otherwise any other place in South Delhi?
Old 17th October 2008, 18:49   #449
Vid6639's Avatar
Thanked: 19,595 Times
I wanted to change my Alto's horn to something like roots windtone or Bosch.
My Lancer already came with OE with Bosch symphony horn which went kaput after i drove into water. I changed these with Roots windtone very easily.
I believe it is not as easy in the Alto as it may need some change in wiring/relay. I do not want the OE horn just the new roots windtone type horn. Do I still need to change some wiring/relay or straightaway just disconnect old and connect new one in.
Old 17th October 2008, 20:30   #450
dinu2506's Avatar
Thanked: 328 Times
I recently installed a Mico Windtone horn ( I guess it is also called the Bosch symphony) in my Civic after my Stebel Nautilus gave up on me after a year of usage.
Liked the horn, its loud but at the same time not very intruding. Cost me Rs 750 including installation.
dinu2506 is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
