Old 27th April 2009, 21:28   #631
Wolffe's Avatar
Originally Posted by ImmortalZ View Post
The dudes at Honda threw away (into my trunk) the plastic shelled relay that came with the Nautilus. They used a solid metal 3inch wide one in it's place. It looks, feels, and sounds like the relays from old Ambys.
I dropped the bundled one on the floor and it came apart. Looked quite puny, to be honest.
From what I've seen,the guys who install the Nautilus dump the in-box Stebel relay for something they use always-usually a metal PMP make relay or plastic sealed relay which can handle the load(In my case it was a sealed relay usually used on the Sumo-so it will definitely handle the load).
My question-shouldn't we trust the relay supplied in the box-made by the manufacturer?Wouldn't he have done R&D on the relay before supplying it with the horn?
Wolffe is offline   Reply With Quote
Old 27th April 2009, 21:56   #632
ImmortalZ's Avatar
Thanked: 136 Times
Well, these things are made in Italy for Italian conditions (as in, use the horn once a month). Maybe our conditions are too demanding? Would explain why a Nautilus will conk in a year, on average.
Old 27th April 2009, 22:30   #633
Originally Posted by Wolffe View Post
I have PMed you the details.
Thx wolffe.. i guess i'll be going there tomorrow or the day after...
@Rj555 thanks to you too dude..
Cyberpirate is offline   Reply With Quote
Old 28th April 2009, 09:48   #634
Wolffe's Avatar
Makes sense-I was using the Nautilus as my daily horn-now has conked exactly after a year-coincidence?Am taking it to the horn repair guys to have it checked before I buy a new one.
Old 28th April 2009, 10:17   #635
RJ555's Avatar
Thanked: 11 Times
I had fixed my Zen with Stebel GP2 series and the relay that came in the box.One evening in peak hour traffic the relay jammed and the horn went off-full blast.All on the road turned around to see the driver whose horn got jammed-so was the cop.Quickly popped the hood-pulled out the wires to the horn and drove off before the cop could get his hands on me.Later replaced the Stebel relay with a PMP cutout-worked fine after that.
I just realised yesterday that my Fiesta with the Nautilus air horn has been fitted without the relay-so back on OE horns till I get the relay and switch done.
Question for the gurus-with the experience of the stock Stebel relay getting jammed-what do I use for my car now?Bosch relay,PMP cutout or the Stebel relay?
RJ555-have you fixed the Nautilus series on your ride?What fuse was used?Thanks.
the same one that came with he box packing. is that worth to trust?
RJ555 is offline   Reply With Quote
Old 28th April 2009, 11:05   #636
amit_mechengg's Avatar
Thanked: 1,057 Times
Infractions: 0/1 (5)
i had just posted yesterday that my nautilus had gone kaput. i tried to check the horn by pulling it a bit outwards from the front grill to check whether the trumphets are dirty. in this process the wire came out of the horn lugs.
somehow i managed to put the wire back. the horn is installed in such a position behind the front bumper that you can hardly see the wiring.
and voila, the horn came back to its full life . it was such a relief for me.
Old 29th April 2009, 00:01   #637
hey wolffe. i just got the horn form that Victory automobiles for 750/- and it turns out that my dad has the same horn on his Octavia. anyways thanks dude. n by the by i think i saw your car today near gemini by 1.30am, not sure if it was your car though. i saw a grey fiesta with the same kind of DIY wheels that you have done.
Old 29th April 2009, 09:59   #638
Wolffe's Avatar
You are welcome.Please make sure you get the wiring done properly with relay and fuse.Happy honking!
I was at home pretty much yesterday-so it couldn't have been at Gemini.Anyways my signature is a decal on my rear windscreen-so if you see me someplace-honk.
Old 29th April 2009, 10:48   #639
sorry that was a typo. i meant by 10.30 in the morning. i saw this car from a distance and i could see only the side. ok anyways will see you then.
Old 30th April 2009, 00:59   #640
sabret00the's Avatar
Thanked: 43 Times
can anyone tell me which horn is provided as OEM with the ALTO? Does changing the horn impact the battery in anyway?
sabret00the is offline   Reply With Quote
Old 30th April 2009, 19:57   #641
suv100's Avatar
Thanked: 28 Times
Hi guys
My three trumpet air horn motor seems to work but there doesn't seem to be much air coming out. My mechanic says its because of the scratches caused by the mica 'fliers' or what ever you call it inside the air chamber. Could this be a reason? Is there any way to fix this? Another thing is there any way to clean the sealed trumpets of the horn?
suv100 is offline   Reply With Quote
Old 5th May 2009, 19:00   #642
bottle's Avatar
Thanked: 130 Times
joined the club too
bottle is offline   Reply With Quote
Old 6th May 2009, 01:45   #643
kums's Avatar
Thanked: 7 Times
Thumbs up
Fixed the Roots Windtone 90 horn - pair with relay + 2way switch for using oem horns also.It cost me 485 bucks for the horn alone. A great voice upgrade indeed for my i10 for highways,suburbs and even city ( for the dumb autos,buses).
This horn draws 5.0 amps(other windtone horns - 4.0amps) and has a modest 112db output.I found it slightly louder than other horns in this series, so i went for it.
kums is offline   Reply With Quote
Old 6th May 2009, 10:48   #644
Wolffe's Avatar
Default Careful
To all the owners of the Stebel Nautilus horn-please be careful with the plastic clip(refer attachment) which holds the trumpet and the motor together.My horn specialist broke it while adding oil-the horn sounded like a dying moose after that.
Took it to Pudupet to have it checked and then found out that the plastic clip holding the trumpet and the motor is integral in making sure no air leaks out-which is why my horn sounded dead.The guy later fitted an "O" ring making the connection airtight-now my horn is back to blasting at 139db.
IMHO-if it ain't broke,don't try to fix it.
Old 6th May 2009, 12:01   #645
ankitahuja's Avatar
Thanked: 46 Times
This clip WILL break if you try to open the horn, Wolffe. I've seen mine and plenty!
It's made in such a way so that probably no one can open the horn without breaking it.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
