Old 30th June 2009, 23:28   #661
ultimatechamp's Avatar
Thanked: 95 Times
Originally Posted by ImmortalZ View Post
What pressure? Well, if the ECU had ears, they might bleed...
As long as you use a relay and give the horn it's own circuit from the battery, you'll be fine.
Thanks Immortalz
You lifted a weight from my heart.
Yesterday I took my car to MASS and all the mechanics there said that fitting more than one horn and too many lights may reduce the life of the ECU/ECM abruptly.
ultimatechamp is offline   Reply With Quote
Old 1st July 2009, 11:27   #662
gpa
gpa's Avatar
Thanked: 281 Times
What if one fixed a relay from the stock horn wiring to a set of bigger horns? I suppose that would work as well?
Old 1st July 2009, 12:39   #663
amit_mechengg's Avatar
Thanked: 1,556 Times
Originally Posted by ultimatechamp View Post
Thanks Immortalz
ask them to give it in writing. then mail the same copy to MUL and ask them to verify it. also ask them how does this technically happen
Old 1st July 2009, 12:47   #664
Sportsmind's Avatar
Thanked: 28 Times
Cool
Thanks Immortalz
It took weight off all parts of body mate..and my eyes went, imagine plugging off all my lighting mods that went into my drive. Guess the guys at MASS need a trip to MARS soon.
Sportsmind is offline   Reply With Quote
Old 1st July 2009, 16:26   #665
ImmortalZ's Avatar
Thanked: 164 Times
That's what you do usually. The stock horn wiring goes to the relay. The relay's points are connected to the battery and the new horn. A relay basically shifts the load from the horn pad to the heavy duty plates inside itself.
ImmortalZ is online now   Reply With Quote
Old 4th July 2009, 01:03   #666
Thanked: 110 Times
I have purchased roots vibrosonic along with roots melody maker cum relay today. Horns costed rs 850 and Rs 150 for roots 7 in 1 melody maker. Am i ripped off for the price of horns.
In the website vibrosonic they have mentioned as 4A 425 ad 505 hz 110dBA. But in the carton its mentioned as 3.5A 325 and 400 hz 120dBA. I think its okay for motorcycle. Sound rings right inside the head when i tested it out. My wife didnt close her ears got one shock of her lifetime
Tried for stebel in several shops in gp road but couldnt able to find it.
Initially i planned to use switch been OE horns and with Roots. But in pulsar i cant place 4 horns. It will be the treat for cops to catch me and mint.
I planned to use only one horn for the city and both the horns with the help of toggle switch connected to second relay. Is this setup is fine.
vijaycool is offline   Reply With Quote
Old 4th July 2009, 01:19   #667
bottle's Avatar
Thanked: 137 Times
I purchased the vibrosonic for the same price of Rs.850 on GP road. Initially I wasn't sure about the price since Xenos galleria quoted Rs.675 but didn't have stock.Later when I got it installed at Mylapore I was told that it was the right price and that inside the city it was retailing at Rs.945.
edit : The specs you posted look similar to the Vibromax listed on the roots website. How is the melody maker ?
bottle is offline   Reply With Quote
Old 4th July 2009, 01:37   #668
Thanked: 110 Times
Thanks. I am not bummed then. Yes, it looks like vibromax spec. But the carton mentions 3.5A and so the stampings in the horn. This made me to believe the specs are right. Perhaps they would have changed the frequency for the vibrosonic. The hella red grill used the very same freq 425, 505 hz.
Melody maker is from roots, got for Rs 150. Max current not to exceed 4A for each horn. Just ask for roots 7 in 1 melody maker. I specifically bought roots for highway use. Without melody maker its pretty useless for highway usage.I really loved the way vibro sounds. Its like sound ringing inside my head for 5 mins after some quick short bursts
Edit: I really loved the sheer size of megasonic. Way way bigger than vibrosonic. Really itching to use for my diesel bullet. My bull doesnt need horns just blip the throttle everyone will scare away coz it has free flow exhaust :-) The horn i choose must sound larger than this diesel racket. Megasonic fits the bill. I forgot to enquire the cost. Can anybody tell about the cost of Mega
Old 4th July 2009, 16:49   #669
jeepster's Avatar
Thanked: 1,024 Times
Lightbulb roots MEGASONIC
hi guys,
i have installed a pair of MEGASONIC from roots in our new bolero.
its grand daddy of all the power horns available.
initially my father was against any big/loud horns but after trying to get way trough 150s,180s, passions & splenders (all fitted with M-sonic's).
he fed up & literally ordered me to install loudest horn possible.
so went to local accessories shop & bought them (around 1600 with fitting).
nikhil.
compare with vibro mini
fitted on bolero
jeepster is offline   (1) Thanks Reply With Quote
Old 4th July 2009, 16:55   #670
hillram's Avatar
Thanked: 978 Times
Roots are the always the best and fit well for Indian cars.
hillram is offline   Reply With Quote
Old 4th July 2009, 16:55   #671
You paid more for them. Got them for my Scorpio for around 1200 or 1250.
WanderNomad is offline   Reply With Quote
Old 4th July 2009, 18:29   #672
Here Roots Vibrosonic costs Rs.1050/- a pair. Earlier it used to be Rs.950/-
janitha is offline   Reply With Quote
Old 4th July 2009, 23:19   #673
gpa
gpa's Avatar
Thanked: 281 Times
In BLR they retail from anywhere between Rs. 850 to Rs. 1,000 depending on the outlet.
Old 5th July 2009, 13:36   #674
jeepster's Avatar
Arrow
are you talking about MEGASONIC ?
there are three versions vibromini > vibrosonic > megasonic which are priced around 520 > 900 > 1300 a pair.
jeepster is offline   Reply With Quote
Old 6th July 2009, 10:19   #675
mithun's Avatar
Thanked: 57 Times
vijaycool : You bought the melody maker for your bike or for your 4-wheeler ?
If my memory is correct, I don't think that the melody maker for cars are not available for Rs.150.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
