Old 6th July 2009, 11:07   #676
goandude's Avatar
Thanked: 455 Times
Default Additional horns in swift
1. Does the swift come with a single or double horn?
2. Does one have to take off the bumpers to fit additional horns in the swift?
goandude is offline   Reply With Quote
Old 6th July 2009, 12:22   #677
Rocky_Balboa's Avatar
Thanked: 66 Times
1. The new swifts do come with dual horn, appropriate spacing inside and slits in the front fog light.
2. It depends where You would want to place the horn. In older swifts (mine for eg - 2007 model), doesnt even have enough space behind the fog lamp to put one.
Rocky_Balboa is offline   Reply With Quote
Old 6th July 2009, 14:54   #678
Sportsmind's Avatar
Thanked: 28 Times
Wink
You have to remove the bumper if you need a proper wiring. This is a picture of my install of my Stebel power horn.Sorry about image quality as it was taken on my cell phone.
Sportsmind is offline   Reply With Quote
Old 6th July 2009, 14:57   #679
mithun's Avatar
Thanked: 59 Times
2. Fit inside the engine bay.
Old 7th July 2009, 11:44   #680
goandude's Avatar
Thanked: 455 Times
I would prefer this location as have heard elsewhere in this forum that removal of swift bumper is not easy.
Old 7th July 2009, 14:08   #681
There will be too much of horn sound inside the cabin.
janitha is offline   Reply With Quote
Old 7th July 2009, 23:24   #682
ultimatechamp's Avatar
Thanked: 95 Times
Be careful of water as monsoon has set in.Water from spinning tyres might render your Stebel useless in no time dude.
ultimatechamp is offline   Reply With Quote
Old 8th July 2009, 08:01   #683
Thanked: 110 Times
vijaycool : You bought the melody maker for your bike or for your 4-wheeler ?
If my memory is correct, I don't think that the melody maker for cars are not available for Rs.150.
I dont think so there is separate melody maker for bike. I bought along with Roots Vibrosonic, Roots melody maker 7 in 1. Its rated 8 amp. Roots megasonic is rated 8A and vibrosonic rated 7A for pair. Its cost around Rs 175 and i managed to get for Rs150. Also i got PMP relay for high tone with a switch to activate. This is to reduce sound inside the city limit. The reason why i opted is for melody maker is because of the electronic relay used. Its a man effort to place the horns for pulsar bike. Compared with stock minda 2A of the pulsars this is twice huge and thrice the thickness. Both have 90mm metal disc
vijaycool is offline   Reply With Quote
Old 8th July 2009, 08:09   #684
Thanked: 110 Times
Originally Posted by jeepster View Post
are you talking about MEGASONIC ?
there are three versions vibromini > vibrosonic > megasonic which are priced around 520 > 900 > 1300 a pair.
Attachment 154612
Attachment 154613
How Megasonic fares against Stebel Nautilus, Hella clear tone a.k.a Red grill in terms of loudness. IMO it may be louder but can not reach long distances. 325 Hz low tone and 395 Hz high tone compared to 425Hz and 505 Hz for Hella German version.
Old 8th July 2009, 12:17   #685
Sportsmind's Avatar
Thanked: 28 Times
Cool
Thanks for the warning on this. I did one round of heavy rain drive last weekend. The fellow still is loud and clear.
Old 9th July 2009, 10:11   #686
mithun's Avatar
Thanked: 59 Times
For Pulsar, you should've also opted for Spider so that the fitting would've been easy.
Old 9th July 2009, 20:51   #687
joshguy's Avatar
Thanked: 92 Times
Originally Posted by bottle View Post
I purchased the vibrosonic for the same price of Rs.850 on GP road. Initially I wasn't sure about the price since Xenos galleria quoted Rs.675 but didn't have stock.Later when I got it installed at Mylapore I was told that it was the right price and that inside the city it was retailing at Rs.945.
edit : The specs you posted look similar to the Vibromax listed on the roots website. How is the melody maker ?
Hi all,
I guess there are 3 models in roots. Vibrasonic,megasonic and supersonic.
DO you know which is the loudest? Am plannig for roots or steble,which one do u suggest for daily use
joshguy is offline   Reply With Quote
Old 10th July 2009, 00:05   #688
mustang89's Avatar
Originally Posted by joshguy View Post
Hi all,
I came to know that megasonic are the loudest followed by supersonic and then vibrasonic,not sure though.
I will prefer the loudest horn for daily use
@ goandude- the swift type 1 came with one horn (that girly kind of noise) and was fitted behind the left fog lamp,while the type 2 has two horns and are near the two fog lamps.To remove the bumper or not depends upon installer,but doing the work without taking off the bumper is very difficult.I tried so many installers and they sacer away from installing a horn in swift coz the whole bumper has to be removed and it is a really time taking and tiring job.
and guys I really recommend everybody to please get the relay changed appropriately,i had a very bad experience which made the cost of my horn almost double!!
mustang89 is offline   Reply With Quote
Old 10th July 2009, 02:37   #689
ankitahuja's Avatar
Thanked: 46 Times
ROOTS Megasonic is a 'not-so-popular' model. The 3 most popular and loud horns from the ROOTS stable are as follows:
1. ROOTS MEGASONIC
High Tone : 395 Hz
Low Tone : 315 Hz
SPL: 125dB
2. ROOTS VIBROSONIC
High Tone : 505 Hz
Low Tone : 425 Hz
SPL: 110dB
3. ROOTS VIBROMAX
High Tone : 400 Hz
Low Tone : 325 Hz
SPL: 120dB
There are other models such as Vibrosonic Delux(115dB), Supersonic (115dB), Vibro mini (110dB)
Old 10th July 2009, 08:42   #690
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
I have got a Hella Red Grill dual horn fitted in my Swift. They did not remove the bumper. They fitted it close to the original horns (which are still there) and turned the wheels completely to one side to access the space. They had to remove the black cover in the wheel well to fit it though.
pjbiju is online now   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
