Old 10th July 2009, 11:04   #691
mithun's Avatar
Thanked: 49 Times
Originally Posted by pjbiju View Post
I have got a Hella Red Grill dual horn fitted in my Swift. They did not remove the bumper. They fitted it close to the original horns (which are still there) and turned the wheels completely to one side to access the space. They had to remove the black cover in the wheel well to fit it though.
Congrats for the Hella purchase !
How much did it cost ?
Old 10th July 2009, 12:00   #692
Thanked: 114 Times
Thanks for the information. Actually, I was thinking to replace my car(Swift)Horns myself, and was wondering if I can do it without removing the bumper and by removing the wheel cover. So it will be DIY on saturday.
regards,
-manju
manjubp is offline   Reply With Quote
Old 13th July 2009, 16:33   #693
Thanked: 110 Times
Fitted Vibrosonic on my pulsar. It feels meaty . Electrician used 4mm wire with 10A fuse. Just came from chennai bangy trip. I saw many fitted with Megasonic but honestly it does not has the punch as in Vibrosonic. Strange thing happened when i drive more than 7k rpm the tone often gets out of tune. I doubt higher voltage is generated from the coil causing the screech sound.
vijaycool is offline   Reply With Quote
Old 14th July 2009, 12:07   #694
ImmortalZ's Avatar
Thanked: 141 Times
After three days of solid usage in the pouring rain at high speeds (500KM of it), one tone of the Nautilus has gone weak. No doubt because of water ingestion. Let's see if it comes back when it dries out.
Old 14th July 2009, 16:26   #695
ankitahuja's Avatar
Thanked: 46 Times
I have opened up, cleaned and oiled my older nautilus which had gone bust. Just need to test it now and see if I have been able to infuse life back in it. *fingers crossed*
Old 3rd August 2009, 19:27   #696
mithun's Avatar
Thanked: 49 Times
Got some updated Horn prices(pair).
Roots Vibrasonic : 1100
Megasonic :1300
Vibra Mini : 650
Hella : 1300(having same spec as Vibrasonic)
Roots Melody Maker(7-in-1) : 170
Is these prices too costly ? Is the guy taking me for a ride ?
Old 3rd August 2009, 19:35   #697
gpa
gpa's Avatar
Thanked: 274 Times
It will change back to normal. Had a similar problem with my set after a service and it was back to normal after about 2 days.
Old 3rd August 2009, 19:38   #698
greenhorn's Avatar
Thanked: 1,447 Times
I dont use my hella redgrilles in the rains due to their vulnerable location . In fact, I rarely use them. I only use them if someone else is acting like a jerk , or conversely, I feel like acting like a jerk .
Thankfully, both are rare !
greenhorn is online now   Reply With Quote
Old 3rd August 2009, 21:07   #699
ImmortalZ's Avatar
Thanked: 141 Times
Eh, mine has become 1.25 tone. The second tone has become very weak and it's staying that way. Dunno what to do now. Any tips ankit?
Old 3rd August 2009, 21:53   #700
ankitahuja's Avatar
Thanked: 46 Times
Stuff cloth in one trumpet - Blow the horn.
Repeat with other trumpet.
This makes all the pressure release from one side, clearing/cleaning any dust etc on that side, and just might help in getting the tone back. It helped with my older set quite a number of times.
I still haven't got time to test the Nautilus that I repaired - I think it's high time I did and posted on that!
Old 4th August 2009, 13:49   #701
Thanked: 18 Times
I purchased pair of roots vibrasonic for Rs 950, Relay Rs 70 and fitting Rs 200 last week in Faridabad
mandyrana is offline   Reply With Quote
Old 5th August 2009, 06:33   #702
sanagg1's Avatar
So you keep your horses war ready all the time and your gun cleaned rearing to go
smoking :()
cheers
sanagg1 is offline   Reply With Quote
Old 5th August 2009, 09:25   #703
ImmortalZ's Avatar
Thanked: 141 Times
Ah crappola, my horn has died completely while coming back from the meet. Now it's just like someone with a throat infection -barely no sound and a lot of air.
Old 5th August 2009, 12:19   #704
dash's Avatar
Red face Hyundai service center discourage horn replacement
I bought Hella dual tone horns for my new i20 (Stock horns suck), and took it to service center (I was not comfortable with the electrical abilities of the JC road guys). To my surprise, Hyundai service guys clearly declined to install the new horns. They said if I still wanted, I should write down on their service form that I will be responsible for any damages caused by the installation.
The reason they said was installation needed rewiring and they are not sure of implications of the power draw. This could lead to fire and had few cases where horn fitments have caused the car to burn!!
Finally decided not to change the stock horns as they said the warranty will be void if we tamper the wiring.
Any clues on what the take from other vendors .... Whom to blame?? Hella or Hyndai
dash is offline   Reply With Quote
Old 6th August 2009, 10:21   #705
mithun's Avatar
Thanked: 49 Times
Blame the stupid Hyundai service centre. Nothing will happen to your car. Go & install it from somewhere else..
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
