Old 6th August 2009, 12:11   #706
jav
guys is there any maintenance required for nautilus like adding oil or regular cleaning of the trumpets?
jav is offline   Reply With Quote
Old 6th August 2009, 12:43   #707
gpa
gpa's Avatar
Thanked: 273 Times
Originally Posted by dash View Post
The reason they said was installation needed rewiring and they are not sure of implications of the power draw. This could lead to fire and had few cases where horn fitments have caused the car to burn!! Finally decided not to change the stock horns as they said the warranty will be void if we tamper the wiring.
dash,
Sorry to hear about your sad experience. You can safely fit the Hellas in your i20. All you need is a good relay (to handle the extra electrical load) and good guage wiring from the relay to the horns.
If done well, there won't be any cutting of any wires involved. The installation from the end points that plug into your current horn stock wiring can be done with male jacks that plug in.
This connection is then routed to the relay from which a connection is then drawn to the Hellas.
PM me if you need the name of a good installer. I got a pair of aftermarket horns fitted last year and have had no problems with either the horns or the installation.
Hope this helps.
Cheers,
gpa
Old 6th August 2009, 17:28   #708
greenhorn's Avatar
Thanked: 1,310 Times
Help Needed from Hella Redgrille Owners
can someone check the wiring diagram of the hella redgrilles?
is there a fuse in between the battery and the relay?
The TASC screwed up the connections, and it wasnt working. I made a fuss and they've connected the wires by twisting them around the terminals of a 30A fuse ( the type you see inside the fusebox) - its not pretty.
if anyone can post a shot of how the connection is , and the fuse if there is one, I'd be much obliged
Old 6th August 2009, 18:28   #709
ankitahuja's Avatar
Thanked: 46 Times
I should / could have been able to answer that, but I am running my Red Grill direct in place of stock horns. It's all good!
Old 6th August 2009, 18:30   #710
greenhorn's Avatar
thanks ankit. Not too much faith in the indica electricals
Old 6th August 2009, 18:54   #711
Awaiting Email Confirmation
Has any one installled a Skoda-Horn in his Maruti ( I have a zen)?
How much does it cost in Mumbai?
glenn is offline   Reply With Quote
Old 22nd September 2009, 07:21   #712
josejoseph's Avatar
Thanked: 319 Times
Default Swift OEM horns
Hello,
Can anyone tell me the specification and MRP of OEM Swift double horns? I know the brand is Hella. Also the place where I can get from Cochin. I'm planning to fix this in my M800.
Thanks,
Jose.
josejoseph is offline   Reply With Quote
Old 22nd September 2009, 09:41   #713
DieselFan's Avatar
Thanked: 233 Times
I have skoda horn fitted in my Swift VDI. In Bangalore it costs about 800 Rs. including labour for fitting.
DieselFan is offline   Reply With Quote
Old 22nd September 2009, 09:50   #714
prince_pervez's Avatar
Thanked: 30 Times
^^ There was a horn problem in my zen since last week. I went to this accessories shop near 4th block signal near to Adviat fuel/LPG bunk (Taj accessories I think). My horn used to blare sometimes and sometimes used to bleep like a tame wet cat. Other times I had to stand on the steering with little effect. He showed me 3 horns. The stock ones, a Skoda and Hella red grill. I was impressed with the Hellas but the price he quoted was 1100 but was willing to fit em at 1000. He also said that I had to buy them in a pair and not a single piece. Zen has only one horn. Since they were not finding any place to place the other horn of the pair, and of the many threads on cars catching fire due to faulty/hasty installations I asked them to get me OEM horns and fit only one of them and the other I intended to gift to a fellow BHP-ain on the give away thread Just as he was fitting the horn, I asked him if the stock horn had gone Kaput. He said 'No'. I asked him then what was the problem. He siad the clip was broken. I asked him to replace the clip and the job was over in 10 minutes with 30 bucks. I went home happy.
Do those Hella red ones cost 1100 ??
He also suggested that people will move out of the way with the Hellas but I wasn't going to scare fellow road users. The Stock horn does what it has to perfectly.
prince_pervez is offline   Reply With Quote
Old 27th September 2009, 10:50   #715
josejoseph's Avatar
Thanked: 319 Times
Originally Posted by josejoseph View Post
Hello,
Thanks,
Jose.
Someone to my help
- Jose.
Old 28th September 2009, 11:26   #716
mithun's Avatar
Thanked: 49 Times
Someone to my help
- Jose.
Just buy Roots Vibrasonic. It'll easily fit on M800. Costs about Rs.850(approx).
Old 28th September 2009, 14:37   #717
jkdas's Avatar
Thanked: 1,389 Times
I have it in my Alto. Its loud and sounds very metallic. Would recommend it too.
Old 28th September 2009, 14:49   #718
dr.faramroze's Avatar
Thanked: 13 Times
Octavia horns are great for Maruti 800,zen and swift. They sound polite yet yelling its road prescence. Its for those who check horns' decibel ratings as prescribed by respective RTOs. Like me.
dr.faramroze is offline   Reply With Quote
Old 28th September 2009, 15:02   #719
ElantraGT's Avatar
I installed Stebel Nautilus Series horn in my Zen and Elantra. Its fitted as a secondary horn and it is dedicated for the highway drives only. It costed me Rs.850 each. I have installed them with the horn pointed downwards, to avoid damaged caused during water wash. The sound quality did not reduce with this setup.
A word of advice - we get a lot of Chinese make of this product in GP road. It costs somewhere around 600 - 650 only, but it does not have the effect of the original Nautilus series. So insists on "Made in Italy" mark on the product packaging.
ElantraGT is offline   Reply With Quote
Old 28th September 2009, 15:11   #720
jkdas's Avatar
Guess you are talking about windtones; Bosch ones cost 450-500rs and sound very loud but polite.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
