Old 17th October 2009, 14:21   #766
motomaverick's Avatar
Thanked: 864 Times
Originally Posted by Latheesh View Post
As I mentioned in my previous post, planning to replace stock horn with Roots Windtone in my Spark. Do I need a relay or any other mod to do the same?
Hi Latheesh, did you fix those roots? i am also planning for a change. I guess you should put a cut-out or relay as the windtones if I am not wrong are dual speakers with hi & low pass.
Old 18th October 2009, 14:40   #767
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by joshguy View Post
Hi Ankit,
I have a red grill in my swift and plan to add another one.The red grill has already started giving me trouble (mistake is mine,i use it a lot when i get irritated with the senseless people)
Which would u suggest in steble ? i dont know the series but heard nalitus comes for around 500-600 Rs in chennai.
is there anyother model at this price range?
Thanks for the help
Red Grills are repairable! And I have till date, never heard of Hella Red Grills going bad, are you sure you purchased a genuine?
Stebel TM80 Magnum is the option for you.
P.S. - If Chennai sells genuine Stebel Nautilus for Rs500-600, I'd be interested in a bulk deal Can you please find out and arrange?
Old 18th October 2009, 17:05   #768
akshay4587's Avatar
Thanked: 1,629 Times
i have genuine Hella red grills
they are repairable
they are most allergic to water,and are a little high on maintainence
Old 20th October 2009, 06:33   #769
mithun's Avatar
Thanked: 49 Times
Get a horn relay or a melody maker. That's it.
Old 20th October 2009, 09:32   #770
Latheesh's Avatar
Thanked: 2,690 Times
Thanks Mithun, I'll get it fixed
Latheesh is online now   Reply With Quote
Old 20th October 2009, 15:16   #771
ankitahuja's Avatar
Thanked: 46 Times
What?
This is the first time I'm hearing this about the Red Grill. I've had them since the past 3 years without any issue.
I have them installed in my OHC in the stock location and not in line with the front bumper.
Old 20th October 2009, 15:24   #772
beejay's Avatar
Thanked: 109 Times
I have had a Red Grill for almost 7 years now. I usually remove then when I sell my car and fix it on the next car. Doing duty on my CJ340 now. These are very much repairable and needs to be tuned for clarity though.
My friend has a Red grill high and a roots low. Must say it does sound good.
beejay is offline   Reply With Quote
Old 20th October 2009, 15:47   #773
nkapoor777's Avatar
Thanked: 88 Times
My stebel nautilus went bad a few days ago. It seems like it is choking on something. Any shops in Delhi I can take it to for repair?
nkapoor777 is offline   Reply With Quote
Old 20th October 2009, 16:46   #774
ankitahuja's Avatar
Thanked: 46 Times
Horns ਵੀ Horns in Karol Bagh (near DB Gupta Road).
The guy claimed that he can repair my Nautilus over a year ago, but I didn't believe him, so never gave him the horn.
Old 20th October 2009, 17:03   #775
nkapoor777's Avatar
Thanked: 88 Times
That doesn't inspire much confidence. But thanks for the info Ankit.
BTW, did you manage to get the nautilus repaired?
Old 20th October 2009, 19:28   #776
ankitahuja's Avatar
Thanked: 46 Times
I was not confident myself since the Nautilus can not be repaired. But no harm in trying I feel.
I tried to repair my Nautilus myself. Opened it completely and oiled what had to be. Never got the time to test it after that
Old 20th October 2009, 23:07   #777
taj
taj's Avatar
Thanked: 18 Times
Here is Roots Megasonic on TBTS, so loud that i am using it with great caution, same time you can push those pvt buses aside when required.
taj is offline   Reply With Quote
Old 20th October 2009, 23:18   #778
Edsel Rulez!'s Avatar
Thanked: 9 Times
I recall having a pair of Roots that looked like these on my 6v Yamaha RX100 in the early 90s. Only, they were black powder-coated, not chromed. They were pretty loud, though I don't know how they would match up with these monsters.
Edsel Rulez! is offline   Reply With Quote
Old 22nd October 2009, 07:37   #779
Latheesh's Avatar
I have a question, Whether Roots Windtone horn have any warranty or not? Accessory shop guy says Roots horn does not have any warranty. Is it true? I checked 3 boxes and found no papers/instructions inside, just have 2 horns. Since I am replacing my stock horns I am bit worried about this.
He quoted Rs.600 for Horn+Relay(PMP)+fitment, I think the price is good.
Old 22nd October 2009, 15:43   #780
Thanked: 864 Times
This windtone is it mechanical or air horn? and 600 bucks seems a good price. Which shop?
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
