Old 22nd October 2009, 16:39   #781
ankitahuja's Avatar
Thanked: 46 Times
Windtone should be a mechanical horn.
ROOTS come with warranty since these are Indian horns.
Old 22nd October 2009, 18:54   #782
Latheesh's Avatar
Thanked: 2,691 Times
I forgot the shop name, its on Hosur road near electronics city immediately after the nandi road intersection
I will go ahead and fix it on monday
Latheesh is offline   Reply With Quote
Old 23rd October 2009, 13:17   #783
Default Hi latheesh
I suggest you look for hella 'SKODA' type horns. There are 3 models. 1st is trumpet horn (red color) whose MRP is Rs.500.00. 2nd is the same type horn premium edition (fit it & forget it) this is very high end horn & normally life span of this horn is more than 2-3 years. 3rd type is trumpet horn new generation (black color) this is made in spain & MRP is Rs.927.00 set. In my experience hella horns are the better than the others.
Good luck
Miten Doshi.
Originally Posted by Latheesh View Post
I would like to have 'SKODA' type horn in my SPARK:-) and shortlisted Roots Windtone/Bosch Symphony fanfare/Stebel Magnum TM80.
I am planning to replace stock horn so TM 80 is out. Heard Roots windtone at an accessory shop and I liked it (Rs.450). But I read that there are 2-3 types of Roots windtone is available, but the horn I checked just had 'windtone' written on the box.
Yet to hear Bosch Symphony fanfare, Where in Bangalore(around Indira Nagar) can I find it?
mitendoshi is offline   Reply With Quote
Old 9th November 2009, 08:22   #784
Latheesh's Avatar
Got STEBEL TM MAGNUM80 for my SPARKY yesterday. It sounds great but does not drive crazy rick and bikers out of the road, but much better than my stock horn. When I asked to fit relay installer told its not required as the Spark already has a relay.
Paid 750 incl installation, its bit on the higher side I know
Old 9th November 2009, 09:54   #785
jkdas's Avatar
Thanked: 1,425 Times
1)Its a pair right?
2)Spark stock one's are pair?
3) You can swap the horns via a switch?
A relay would cost only 150 max ( the Bosch one).
Old 9th November 2009, 10:43   #786
Latheesh's Avatar
Das, see my answers:
1) Yes its a pair
2) Yes Spark's stock ones are pair
3) I replaced stock horn with TM 80
Old 11th November 2009, 00:01   #787
blackfire_9's Avatar
Thanked: 187 Times
Hi everybody,
I am presently using Hella Twintone in my Alto, but wanted to know some genuine place in Delhi or Chandigarh where I can find Stebel products. Please help.
Thanks,
Prakhar
Old 12th November 2009, 13:42   #788
NOTORIOUS's Avatar
Thanked: 87 Times
Originally Posted by blackfire_9 View Post
Hi everybody,
Thanks,
Prakhar
PM ankitahuja for stebel horns
NOTORIOUS is offline   Reply With Quote
Old 17th November 2009, 10:33   #789
Latheesh's Avatar
I do not know its a right question or not. Horn sound great at low speed but felt volume/tone reduce/change at higher speeds.
Old 17th November 2009, 19:07   #790
ankitahuja's Avatar
Thanked: 46 Times
Mostly all horns share the same characteristic. Seems like you experience a lot of difference.
The problem you face is due to the solution given by your installer in above quotes
Old 17th November 2009, 19:18   #791
Latheesh's Avatar
Thanks Ankit, I have the relay which came with TM80. Should I ask the installer to fit the same?
Old 17th November 2009, 19:31   #792
ankitahuja's Avatar
Thanked: 46 Times
Yes, do that right now. And while he does that, get your battery current checked as well.
Old 17th November 2009, 19:48   #793
joshguy's Avatar
Thanked: 92 Times
Default Got Steble !!
Hi people
I got steble last week and fitted it too.
i felt that my hella was better and loud.People dont seem to give way if i use steble.where as they shout at me if i use hella
Here are the pic as i dont know the model
joshguy is offline   Reply With Quote
Old 17th November 2009, 20:22   #794
anachronix's Avatar
Thanked: 1,255 Times
Probably the Stebel tone is much sweeter to their ears compared to the Hella!
Originally Posted by joshguy View Post
Hi people
anachronix is offline   Reply With Quote
Old 20th November 2009, 21:10   #795
ImmortalZ's Avatar
Thanked: 141 Times
My second Nautilus died today. Water ingestion no doubt. I can't fix the damn thing in the Civic where it is safe from water and I can't afford two horns a year - it's the fitting charges that kill.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
