Old 20th November 2009, 22:55   #796
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by ImmortalZ View Post
My second Nautilus died today. Water ingestion no doubt. I can't fix the damn thing in the Civic where it is safe from water and I can't afford two horns a year - it's the fitting charges that kill.
Sad to know that. I'll send you ROOTS or HELLA this time!
Old 24th November 2009, 11:19   #797
theexperthand's Avatar
Thanked: 948 Times
Originally Posted by joshguy View Post
Hi people
i felt that my hella was better and loud.People dont seem to give way if i use steble.where as they shout at me if i use hella
Stebel have a pleasent tone, but hella is harsh. I used to have a pair of hella red grills on my bike, but changed to Stebel TM 80 Magnum - they are loud, but people dont jump when they hear it like they used to do when I was using Hella red grills.
My car have hella red grills, and they are one of the best and effective horns I have come across.
theexperthand is online now   Reply With Quote
Old 1st December 2009, 14:06   #798
josejoseph's Avatar
Thanked: 316 Times
Dear All,
My M800 is fitted with Bosch horns. It was positioned in the engine bay in such a way that while honking, sound inside the cabin was disturbing. Last weekend I tried a DIY to reposition the horns. I placed them near the front grill. The horn now sounds loud and clear . But my concern is if the wires would get heated up . Since the horns are placed near the engine, I fear that the heat generated would melt up the wires and damage the horns. I tested the new set-up for two days after running the car, and the wires seems okay. But my concern is whether I would result in melted wires during a long drive.
Please advice me on this set-up. Am attaching the pictures of old set-up and the new set-up. I'd very much like to place the horns in the new position since the sound is loud and the sound inside the cabin has reduced. What other modifications should I need to continue using this set-up?
Thanks,
Jose.
josejoseph is offline   Reply With Quote
Old 1st December 2009, 14:38   #799
Latheesh's Avatar
Thanked: 1,752 Times
Better to use some sleeves to protect the wire.
Latheesh is online now   Reply With Quote
Old 1st December 2009, 18:09   #800
rakesh_r's Avatar
Thanked: 546 Times
use some double wire sleeves. Should work fine
rakesh_r is offline   Reply With Quote
Old 1st December 2009, 18:21   #801
joshguy's Avatar
Thanked: 85 Times
Hi people
I got steble last week and fitted it too.
Here are the pic as i dont know the model
My steble died some 2/3 days back.I think its waste of money !
Just 2 weeks and it died
joshguy is offline   Reply With Quote
Old 1st December 2009, 18:22   #802
josejoseph's Avatar
Thanked: 316 Times
I believe wire sleeves are a kind of protection material over the wires. Are they available in electrical shops?
Thanks,
Jose.
Old 7th December 2009, 12:28   #803
Thanked: 948 Times
wire sleevs are the way to go, Jose. If not sleeves, then cover the wire with 2-3 coats of insulation wire.
The new position is good, but why dont you try to mount them in front of the radiator or below it?
may be, if you remove your bumper, you can fix the horn and then you can fix the bumper back - just a thought.
Old 7th December 2009, 13:39   #804
josejoseph's Avatar
Thanked: 316 Times
I'll try to find any new position by removing the bumper.
Actually my current problem is not the wires getting melt, but it's the horns that get hot. Will the horns get damaged because of that?
- Jose.
Old 7th December 2009, 21:25   #805
amit_mechengg's Avatar
Thanked: 969 Times
2 weeks is 2 short. god knows why my died after 1.5-2 years. it performed its duty in pride. nothing blows stronger than stebel.
Old 8th December 2009, 19:45   #806
rakesh_r's Avatar
Thanked: 546 Times
- Jose.
You can purchase the sleeves from shops that sell automobile spares,specially that sells electrical spares such as horns and stuff.About the heat,not much but manufacturers recommend to mount the horns away from hot engine parts.
Old 9th December 2009, 01:07   #807
vinaydas's Avatar
Thanked: 81 Times
i had installed Nautilius air horns on my innova few months ago but they died due to water logging. Then my driver got annoyed with the crappy sound coming with the faulty horns and got em replaced with Shrill horns !! haha
Bikers and pedestrians scram when i honk and not to mentions even the auto guys get annoyed??
I have got " the look " from a few bikers and auto guys and they got " the finger" from me
vinaydas is offline   Reply With Quote
Old 12th December 2009, 17:55   #808
bottle's Avatar
Thanked: 130 Times
What are these shrill horns ?
bottle is offline   Reply With Quote
Old 12th December 2009, 18:06   #809
vinaydas's Avatar
Thanked: 81 Times
i think you must have seen those tempo travelers troubling you on the road with their loud horns .
I think so they are also called shrill horns.(im not so sure)
Old 12th December 2009, 18:32   #810
^^They should be ROOTS then.
D.V.R is offline   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
