Old 17th February 2010, 10:31   #841
Wolffe's Avatar
Default Stebel Nautilus Compact Series
Stebel has launched a Compact series of the Nautilus-supposedley 30% reduced in size. Anyone seen it at Accessory shops yet?
I use the Stebel Nautilus for everyday use-had issues with it once-but no problems after that.It's been 2 yrs now and sounds loud enough.
Wolffe is offline   Reply With Quote
Old 19th February 2010, 16:16   #842
Originally Posted by harsha.cs1 View Post
Hi guys,
The melody maker has the option of normal mode (high low simultaneous). That apart it has a fast and a slow and 3 different sound patterns under each. The melody maker cost me Rs. 130.
Hella Red Grills cost me Rs. 985.
Update:
Got Redgrilles fitted with Roots melody maker.
I somehow feel that the Hellas are not loud enough and have a gut feel that the Melody Maker is kinda responsible for the low sound. It says 4 Amps capacity... I havent fit the relay yet.
Do you think fitting a relay down the circuit from the M M (near the horn) should help? How should the relay be connected? My mech said wire will be drawn from battery to horn through relay? I am confused.
Someone gave me the gyaan that the Roots MM itself acts as a relay! not sure though. Any thoughts?
harsha.cs1 is offline   Reply With Quote
Old 19th February 2010, 16:24   #843
ankitahuja's Avatar
Thanked: 46 Times
Yes, the wire will be drawn from battery to horn through the relay!
Get the relay fitted and see. Else, remove the MM and then see again
Old 19th February 2010, 16:55   #844
Yessir. that's now on the agenda. I am to send you a sound recording too soon. Will try and get at least some background noise that you can relate with so that you have get a relative hang of the sound. else the more volume you give, the louder the horn will sound!
the MM is fun and has its effect of urgency - so if i can have the loudness and the melody, it would be too damn good! So relay will give current to the horns directly from the battery - so the horn and the MM will only act as a switch? What if the switch (read MM) does not permit flow of too much electricity - what will the relay do in that case?
The guy has fitted the horns just behind the grill - i know rain will be the first to reach it - you can see it through the grill. I hope the horns are not too sensitive! He said that placing it elsewhere will require removal of the bonnet! Is it ok?
Old 19th February 2010, 17:05   #845
Awaiting Email Confirmation
Newbie question - I have a Manza and definately do not want to tamper electrical wiring which will void(I know it won't but service centre guy insisits) since Manza being new, already has its share of niggles. So can the gurus clarify if I can buy a horn powered by the 12V DC?
Vijay
vjoy3 is offline   Reply With Quote
Old 20th February 2010, 14:07   #846
Thanked: 92,128 Times
Vjoy,
Want the safest route out? Go back to the showroom that you bought your Manza from, check their accessory list for different horn options and have them install. You'll pay a higher price, but will get (hopefully) superior install quality + your warranty remains intact.
Old 20th February 2010, 14:43   #847
akshay4587's Avatar
Thanked: 1,629 Times
Hella red grills are very sensitive to water
Old 25th February 2010, 17:19   #848
Twiny's Avatar
Thanked: 47 Times
I want to get my Roots Vibrasonic horn serviced.
Is there any Authorised/reliable service centre near Marathahalli / IndiraNagar /Whitefield in Bangalore?
Twiny is offline   Reply With Quote
Old 25th February 2010, 20:02   #849
suv100's Avatar
Thanked: 28 Times
Which one is better for my car, Roots megasonic or vibrasonic?
suv100 is offline   Reply With Quote
Old 25th February 2010, 21:56   #850
Twiny's Avatar
Thanked: 47 Times
If I have given choice , will go for Megasonic, its loud and has more bass
Megasonic is big in size and weight (by 0.5kg/pair) compared to Vibrasonic
Old 27th February 2010, 02:07   #851
Thanked: 12 Times
Default Air Horn/Sports Horn in Bangalore
Does anyone know where i can procure one of these in Bangalore?? A pic for reference:
Last edited by aah78 : 27th February 2010 at 02:52. Reason: Moved to existing thread.
CaliAtenza is offline   Reply With Quote
Old 27th February 2010, 10:27   #852
ankitahuja's Avatar
Thanked: 46 Times
It might be the wrong question to ask, but what will you do with this?
I doubt if anyone sells these in India, but since you're an LAX resident as well, you'll get them dime a dozen over there.
Check out Amazon.com as well
Amazon.com: ECOBLAST SPORT HORN W/PUMP 50074068: Sports & Outdoors
Amazon.com: Tempo Air Horn: Sports & Outdoors
Old 8th March 2010, 22:22   #853
triedeverything's Avatar
Thanked: 163 Times
Does anyone here know if Roots make wiring harnesses to fit additional horns?
I know they make kits for headlight wiring (replacement). So do they make harnesses (including I/II/off switches) ?
triedeverything is offline   Reply With Quote
Old 8th March 2010, 23:19   #854
asethi's Avatar
Thanked: 40 Times
Originally Posted by RufRoc View Post
darklord, you didn't have to fit a relay? The Roots Windtones's are 4 A, right?
No need for relay. I've been using Roots Windtone on my Swift for last 1.5yrs without any problem.
asethi is offline   Reply With Quote
Old 9th March 2010, 13:16   #855
Twiny's Avatar
Thanked: 47 Times
Latheesh, I have also noticed the same issue with my TM80 pair. At lower engine RPMs or with AC/stereo running, the sound does change! Do you have the Stebel relay or a Indian relay (Roots/PMP) fitted? I have the Stebel one and am wondering if that is the reason.
In my case fitter not recommended Stebel relay and used some other one.. don't remember the reason though.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
