Old 13th October 2011, 19:25   #1126
Soccerfan's Avatar
Thanked: 56 Times
Default re: Power Horns!
Originally Posted by amit_mechengg View Post
what was the problem
Some loose contact which resulted in a shorting
Soccerfan is offline   Reply With Quote
Old 13th October 2011, 19:42   #1127
amit_mechengg's Avatar
Thanked: 1,556 Times
i am planning to pull out those punny oem horns and fit the roots windtones. i love these which work great in my alto.
so no relays, no wire cutting. how did you connect the OEM horn connectors to the roots horn pins. they have different types of connectors.
Old 13th October 2011, 20:23   #1128
Ace F355's Avatar
Thanked: 1,752 Times
Have been using Bosch Symphony in my Shark since April. Got them for INR 500 IIRC. No problems so far and they have been thoroughly satisfying on Highways. Pleasing and effective sound I should add.
Ace F355 is offline   Reply With Quote
Old 13th October 2011, 22:45   #1129
blackfire_9's Avatar
Thanked: 187 Times
hey choudhary,
Got it for 700 bucks through an authorized distributor. Couldn't speak to the guy yet due to office, would do that next week & seek a replacement.
hope yours is running fine.
Originally Posted by Schoudhury View Post
How much did you get it for ?
The last pair lasted for many months.
Old 13th October 2011, 22:59   #1130
what brand of horns are fitted on volkswagen jetta??
Old 14th October 2011, 00:10   #1131
motomaverick's Avatar
Thanked: 864 Times
Hi was planning to change the Manza oem horns, since they are already dual would there be a cut out still required?
Old 14th October 2011, 00:16   #1132
Thanked: 187 Times
I believe the horns in Skodas & VWs are either from Hella or FIAMM. Though, I would request others to correct me if some one knows better.
Old 14th October 2011, 13:51   #1133
Finally Installed my Stebel 3 pipe horns...Thanks to ankitahuja....
The Venom is offline   Reply With Quote
Old 14th October 2011, 16:47   #1134
ankitahuja's Avatar
Thanked: 46 Times
You're welcome, Munish. Glad to hear you installed them.
How do you like the horn? Post pictures/sound/video clip to tease the others
ankitahuja is offline   (1) Thanks Reply With Quote
Old 5th November 2011, 19:41   #1135
Sushil.H's Avatar
Question re: Power Horns!
Originally Posted by flyingkolors View Post
Those are the Roots Windtone. Will cost you around 650-750 bucks including installation. You can find them in any car accessory shop. I am just about to install them in my car.
Hi Flyingkolors,
I did a TD of polo once and loved that horn. I have booked ALTO K10, and would love to replace the stock horns with Roots Windtone.
Since replacing any electrical component in a local accessory shop may result in the warranty to get void , Any idea if i can ask directly the Maruti Suzuki dealer to install these?
Thanks,
Sushil.
Sushil.H is offline   Reply With Quote
Old 6th November 2011, 16:27   #1136
ankitahuja's Avatar
Thanked: 46 Times
Just installed the Stebel TM80 Magnums in my wife's Accent.
The sound is great. Feels more bassy than the Hella Twin Tones in my car, but then I feel the Twin Tones are louder and more crisp!
A side by side comparison is scheduled for ASAP. :-)
Old 6th November 2011, 20:02   #1137
flyingkolors's Avatar
Thanked: 57 Times
Originally Posted by Sushil.H View Post
Hi Flyingkolors,
Thanks,
Sushil.
Please check with MASS if that voids the warranty. It may not IMO. When I upgraded in my i20, all we had to do was use the existing relay, attach additional wire (for the second horn since i20 comes with single horn) and replace the horn. Simple work.
flyingkolors is offline   Reply With Quote
Old 10th November 2011, 12:08   #1138
ankitahuja's Avatar
Thanked: 46 Times
Quoting my own comments - the verdict is as suspected.
Stebel TM80 are more bassy, more like the skoda horn (but louderrr).
The Hella Twin Tones are way louder and less bassy - ideal for traffic conditions.
Take your pick!
Old 21st November 2011, 10:45   #1139
Thanked: 864 Times
Take your pick!
I can also vouch for that tm80 is more bassy but not so loud as say the Bosch Symphony, But Hella i found them to be louder than TM80 but does not sound like Symphony horns, but i am not able to find these Bosch I had fixed them on my zen and they were perfect in terms of loudness & bassiness (if there is such a word)
Old 21st November 2011, 12:35   #1140
panky12345's Avatar
Thanked: 147 Times
Same here.. got them installed yesterday!
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
