Old 26th January 2012, 13:56   #1171
Thanked: 93 Times
Default Re:Defective Roots windtones
I find the ROOTS Windtones to be suffering from an inherent design flaw.
Firstly, there are no tabs to hold the trumpet in place in case the bolts come loose.This means that the black trumpet can fall off if & when the bolts come off.
Secondly, the bolts come off in a few months due to lack of a washer & leakage of air from the trumpet starts. This leads to a very unpleasant & shrill noise if you sound the horn.
I am currently replacing the bolts for the second time in a year of ownership. It goes without saying that the horns are 100% original.
Will post pics soon.
JustCause is offline   Reply With Quote
Old 27th January 2012, 08:19   #1172
Thanked: 110 Times
Default re: Power Horns!
Yesterday I got Roots windtone in chennai for Rs 500 and he also got Bosch. Roots is definitely shrill than bosch so I picked windtone. I have fixed Roots vibrosonic 3 yrs before in my pulsar still works very good. I disconnected low tone because of its loudness . Planning to shift to my GTX and replace with windtone
vijaycool is offline   Reply With Quote
Old 27th January 2012, 16:57   #1173
Thanked: 93 Times
Default Re: Defective Roots windtones
Here are the pics
Each time I re-tighten the nut, the tone becomes a bit softer, again, progressing towards downright shrill when the nuts become loose.
My post is more of a caution rather than a complaint and I felt the need to inform other BHPians of this periodic problem so that one doesn't lose the trumpet if & when the nuts fall off.
Roots windtones are among the best 'polite' horns that I've used till date. They are loud enough, but not in a nagging kind of way.
Old 29th January 2012, 21:35   #1174
kaushik_s's Avatar
Thanked: 156 Times
I've been using Hella Red-grills and they are marvellous. Seriously, they can move those indi-cabies and autowallas with relative ease. But recently the horns are having some issues and it seems like that at times only one of the horns is working. But the issue is that it doesn't happen all the time and so I'm not sure if I can get them replaced under warranty as when I would take it to dealer they might just work fine. Or can this be just some loose connection? They are installed under the bumper of the Scorpio(replaced the OEM Hellas) and I'm not sure if I can open the bumper and check :(
kaushik_s is online now   Reply With Quote
Old 4th February 2012, 09:22   #1175
srinath34's Avatar
Thanked: 160 Times
Can anyone tell me the price of Bosch FC-4 in Bangalore?
Need them ASAP for my Pulsar220
srinath34 is offline   Reply With Quote
Old 4th February 2012, 17:07   #1176
Surprise's Avatar
Thanked: 269 Times
Originally Posted by kaushik_s View Post
But recently the horns are having some issues and it seems like that at times only one of the horns is working. But the issue is that it doesn't happen all the time and so I'm not sure if I can get them replaced under warranty(
Exactly my problem too. But fortunately for me it completely conked off, so it went to the shop for replacement under warranty. But its more than 2 weeks, yet to get it replaced as the shop guys does not got one from the Company.
Edit: Guess mine is of 3 months warranty & have crossed 60 days. When I get the replacement from the Company, will the warranty start afresh or it will be only for one month?
Surprise is offline   Reply With Quote
Old 6th February 2012, 15:14   #1177
sushrutha's Avatar
Thanked: 325 Times
I lost the count of Hella Red grill horns I have fitted on my cars & bike.
Particulalry the Made in Germany ones, they used to sound awesome.
Now a days you get only Made in India Horns, they don't produce the exact sound as that of Germany made one's, these are slightly harsh.
Reasons for your horns not working properly
1. Loose connection
2. Needs a tuning (there's a black rubber bush at the back, just turn n adjust it)
3. Point set (the inside plates) might have worn out.
4. What relays have you put ? If The hella one, sometimes they(electricians) say that the hella digital one get struck (current doesn't pass properly).
Mostly you issue is either 2 or 3.
sushrutha is offline   (2) Thanks Reply With Quote
Old 15th May 2012, 11:33   #1178
lancersfx's Avatar
Thanked: 27 Times
I had plans of installing Hella Red Grille but being the fan of Skoda's horn i decided otherwise. A local TVS trumpet was the alternative and got it for about INR 600, 2 years ago. Pretty good sound. Sometimes when overtaking, the constant honk from the TVS sounds like as if you're sitting in the engine of a train and listening to the horn. Not harsh but easy on ears and do the job.
lancersfx is offline   Reply With Quote
Old 16th May 2012, 08:29   #1179
prateek_ch's Avatar
Got the Hella Red Grills installed yesterday at Evo! They are scarily loud. Commands immediate respect from unruly autowalas and unsure bikers driving slow in the middle of the road and more than a considerate second thought from the bigger vehicles. :P I am enjoying it!
prateek_ch is offline   Reply With Quote
Old 6th June 2012, 23:37   #1180
cityvic's Avatar
Thanked: 2,584 Times
Guys any idea whats the Price of a Stebel 3 Pipe Horn or Stebel Nautilus and where can I procure them in Calcutta?
cityvic is offline   Reply With Quote
Old 8th June 2012, 23:57   #1181
Dr.Vikas's Avatar
Thanked: 47 Times
Got the Hella Red Grills installed to my Fabia today. Sound much better than that of the stock ones. In all, I am happy with the upgrade.
Bought those from 'Jainam' @ Opera House, Mumbai for 1,080...
BTW, (one my call it as an afterthought but), how to differentiate between the OE & Fake Hella Red Grills? Do share some inputs.
Dr.Vikas is offline   Reply With Quote
Old 9th June 2012, 09:10   #1182
Visaster's Avatar
Thanked: 199 Times
Can you tell me where in Bangalore did you get it from and how much does it cost?
Even I need answers for the same cause I am planning to buy one today. If you have already figured out, please let us know.
Visaster is offline   Reply With Quote
Old 9th June 2012, 09:52   #1183
prateek_ch's Avatar
[quote=Visaster;2803231]Can you tell me where in Bangalore did you get it from and how much does it cost?
PMed the details.
You'll have to call him first so that he procures the horns in advance ☻
He gives you an original Hella warranty card. So np worries on that end. ☻
prateek_ch is offline   (2) Thanks Reply With Quote
Old 9th June 2012, 10:45   #1184
mitrajdeep's Avatar
Thanked: 92 Times
Hey cityvic,
even I am interested in these horns but I will let you try them first.
Some eBay links for you.
Stebel Nautilus Chrome Compact Motorcycle Air Horn | eBay
Nautilus 139db Compact Dual Tone Air Horn Just Plug-n-Blow-Black Finish | eBay
Or go extreme and get one of these
http://www.ebay.in/itm/Assured-Perfo...#ht_1958wt_905
mitrajdeep is offline   Reply With Quote
Old 9th June 2012, 11:05   #1185
cityvic's Avatar
Originally Posted by mitrajdeep View Post
Hey cityvic,
Assured Performance Super Loud Dual Trumpet Train Truck Air Horn 140db-NEW | eBay
LOL.
They are extremely expensive and out of my budget.
They are for 7k,8k & 10k.
Am looking for something really Loud in 1k.
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
