Old 30th July 2012, 23:37   #1231
97_Octane's Avatar
Thanked: 75 Times
Default re: Power Horns!
Replaced the stock Hellas in my Swift with Hella Twin Tone. These sound like the VW OE horns but are loud. I mean LOUD
97_Octane is offline   Reply With Quote
Old 1st August 2012, 00:27   #1232
ankitahuja's Avatar
Thanked: 46 Times
Absolutely right! Congrats.
I had suggested the same few posts back as well. Hella Twin Tones are very loud and I LIKE them!
ankitahuja is offline   (1) Thanks Reply With Quote
Old 1st August 2012, 09:39   #1233
taj
taj's Avatar
Thanked: 18 Times
I have Installed the Hella twin tone 2 years back on my Fiesta, since the tone was excelent and unique, but i have to replace it 6 or 7 times .
The mechanic have tried all permutation combination, with & with out relay but still i run with the faulty horn.
Can any body help me to resolve, or apart from hella tt, which one have the most similar sound/ tone ?
taj is offline   Reply With Quote
Old 1st August 2012, 15:13   #1234
ankitahuja's Avatar
Thanked: 46 Times
Are you serious?
I changed my OE OHC horn as it went bad after many many years. Got the Red Grill about 5-6 years back and Hella TTs. They both work perfect!
Yes, I do admit installing a lot of Stebel Nautilus in between which were horribly short in their life span!
I am not able to suggest you any replacement for Hella TT since I suggest this horn to everyone else. Still, you may try out the Stebel Magnum TM80 or Roots Windtone. Stebel sounds more refined but not as loud as the TT.
Old 1st August 2012, 16:21   #1235
taj
taj's Avatar
Thanked: 18 Times
Are you serious?
Well i fitted mine along with my friend's accent, his piece is working fine till now, we have done it from same shop (carnation) by the same electrician , who gave me 1 year warranty, in the first year i have replaced the set 5 times, later after one year in have payed and replaced 2 times, clear sound comes only once in a while, Something wrong with the fiesta and hella combination. need to check out other options.
Old 4th September 2012, 02:14   #1236
swiftnfurious's Avatar
Thanked: 6,471 Times
Where did you source it from and what was the cost? A friend of mine is looking for it in Bangalore.
swiftnfurious is offline   Reply With Quote
Old 4th September 2012, 22:20   #1237
97_Octane's Avatar
Thanked: 75 Times
Got it from a shop in Frazer Town. Cost me 1200 with fitting IIRC.
Old 10th September 2012, 11:28   #1238
dreamdiesel's Avatar
Thanked: 55 Times
Stock horn on my Swift went dud after 5 years. Got Hella Yellow Panther fitted. Definitely loud than the stock.
dreamdiesel is offline   Reply With Quote
Old 19th September 2012, 19:25   #1239
itwasntme's Avatar
Thanked: 1,419 Times
FIAAM Freeway Blasters for my Cruze. Will replace existing wimpy OEM ones.
itwasntme is offline   Reply With Quote
Old 19th September 2012, 20:16   #1240
cityvic's Avatar
Thanked: 2,573 Times
Got Stebel Nautilus fitted on my Honda City 1.5exi today.
I got it fitted in the 2 tone Horn mode so that I can switch to the OEM Honda Horn with a click on the switch.Got this done because I wanted to keep the car as OEM as possible,but a Loud horn was required for the byepass travelling.
A Brilliant Buy.Thanks to all who suggested me to get it.
Pictures coming up soon.
cityvic is offline   Reply With Quote
Old 20th September 2012, 10:39   #1241
srinath34's Avatar
Thanked: 140 Times
Attachment 988481
Attachment 988482
Aren't these a little low tone compared to the Symphonys and Windtones available here
http://www.fiamm.com/Horns-F-Freeway...7-Prod-956-561
srinath34 is offline   Reply With Quote
Old 20th September 2012, 11:05   #1242
itwasntme's Avatar
Srinath,
Don't want a extremely loud one; just tired of the wimpy stock ones. Have bought the recommended pair and will update once installed:
HIGH:
http://www.fiamm.com/Horns-E-Freeway...7-Prod-957-561
LOW:
Old 20th September 2012, 11:34   #1243
mobike008's Avatar
Thanked: 8,037 Times
Aren't windtone the ones that are there as stock SKODA horns? Or is it called the roots? I think the latter.
Skoda horns are the most popular in aftermarket horn installation space and almost 7/10 folks go for it.
I too have same horn in my Cruze which i got for Rs.700. I like the sound and also the way it scares away the "loitering kinds" from the front of my Cruze
Old 5th October 2012, 11:48   #1244
goandude's Avatar
Thanked: 450 Times
Originally Posted by StrangeWizard View Post
A month back I got this "Seger" brand horn installed in my car. Sounds exactly like the vento/passat etc horns. Costed me Rs 750 and it works pretty good. The sound sure demands some respect. Anyone else tried this?
My swift's horn is on its last legs. Went to an accessory chap in Tippasandra and asked for a Vento / Polo sounding horn and he recommended Seger @ 950/-with fitting. How is your horn working? What model is it? the home page is here
http://en.seger.com/products/electromagnetic-horns/
goandude is offline   Reply With Quote
Old 5th October 2012, 11:56   #1245
StrangeWizard's Avatar
Thanked: 228 Times
Mine cost 900 with relay and wiring. I got it in june and it still works properly.
Only once when I drove my car in a flood, it stopped working for a while but after sometime it started again.
Its quite loud and useful for moving everyone out of the way.
StrangeWizard is offline   (1) Thanks Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
