Old 18th October 2012, 20:28   #1246
greenhorn's Avatar
Thanked: 1,423 Times
Default re: Power Horns!
my Hellla redgrille's died after yesterday's rains. Are they serviceable, or will I have to buy a replacement set?
Old 27th October 2012, 15:38   #1247
mithun's Avatar
Thanked: 49 Times
I've seen some roadside guys servicing it. I would recommend you to buy a new pair since horns are like shock absorbers, better replace them.
mithun is offline   (1) Thanks Reply With Quote
Old 28th October 2012, 10:17   #1248
Geo_Ipe's Avatar
Thanked: 361 Times
Was looking for the Skoda/VW type horn for my Santro in Vellore. A prominent accessory shop showed me the Roots Windtone - and quoted 1200 bucks (including relays, fixing et al.)
1. Is the quote genuine or is he trying to fleece me??
2. And he says Roots doesn't come with a warranty card. True?
Geo_Ipe is offline   Reply With Quote
Old 30th October 2012, 12:55   #1249
darklord's Avatar
Thanked: 809 Times
http://www.team-bhp.com/forum/modifi...ml#post1716082 (Power Horns!)
Mine didn't have warranty card either.
darklord is offline   Reply With Quote
Old 30th October 2012, 21:21   #1250
joshguy's Avatar
Thanked: 92 Times
I have been replacing horns every 2 years continuously ,may be I am using it too much.
First one lasted for about 1 year or so and second one for 21/2 to 3 years (till Sept/2012) but i serviced/adjusted is 3 to 4 time before it became non serviceable.
The new one costed me 1250 and thats it, now its fine.
Yes Windtone is the skoda type horn but check and buy it .Also install it in such a way that they are loud and also away from water.Position of the horn will give a great amount of difference.
I am not sure about the warranty but cost was i guess around 600 or 800.
Last edited by joshguy : 30th October 2012 at 21:23. Reason: forgot to add about warranty
joshguy is offline   Reply With Quote
Old 30th October 2012, 21:36   #1251
Geo_Ipe's Avatar
Thanked: 361 Times
You said you got yours for 490 including fitting. So I'm concluding that 1200 bucks was a fleecing attempt I outwitted with some BHPians' help!
And how water proof is the location of those horns in your Santro? It looks kinda vulnerable just behind the grille.
A fellow BHPian from my city PM'ed me the contact of another accessory shop. Will check it out.
Old 30th October 2012, 22:08   #1252
sumeshmani's Avatar
Thanked: 104 Times
Pardon my lack of electrical knowledge. Wont there be a relay in the existing circuit?
Wont the same work when changing the horns? Will the existing relay not be able to manage the electric load of the new horn?
sumeshmani is offline   Reply With Quote
Old 30th October 2012, 22:41   #1253
darklord's Avatar
Thanked: 809 Times
Nearing 3 years/21000 km in Kerala. No problems to date. I guess if it survived 3 years in Kerala rains, it is safe enough and worth enough for Rs.500. Only annoyance is it has become too common; even in autos and bikes.
Old 30th October 2012, 23:31   #1254
greenhorn's Avatar
Kerala & Orissa, they got wet, but never submerged, so lasted 4 years. didnt last 6 months in chennai though. but then again, they get drowned in the OMR everyday, and they're in a very vulnerable location (next to the front fogs)
Old 2nd November 2012, 08:46   #1255
sudeep11787's Avatar
Thanked: 65 Times
Went to Reliance Autozone, Ambience (Gurgaon) yesterday to get a new pair. They don't stock anything except Hella. Red grille were out of stock too.
Took a demo of yellow grille and a red windtone type. Yes they are good , but when i tried my OEM ones, they sounded more or less the same. I have twin Hella some water proof types in my esteem. Didn't feel like spending 1400 bucks for a marginal difference.
Will search for Roots windtone, Bosch, and finally roots megasonic.
The staff at reliance pointed out that as i already have a pair, i won't be needing a relay. Is it correct?
sudeep11787 is offline   Reply With Quote
Old 7th November 2012, 09:23   #1256
deetjohn's Avatar
Thanked: 7,520 Times
I have Hella Black Trumpet Horn on the Swift. These are the compact ones with an open mouth. It has a soft sound and is holding up well.
The bumper needs to come off to fit them on the car though.
I hate shrill horns.
deetjohn is offline   Reply With Quote
Old 7th November 2012, 10:16   #1257
motomaverick's Avatar
Thanked: 864 Times
Since you have OEM dual horns , you will not require a relay. I also replace my OEM horns directly with Bosch Symphony, no relays required as I think it comes from factory.
motomaverick is offline   (1) Thanks Reply With Quote
Old 7th November 2012, 10:57   #1258
Vasuki's Avatar
Thanked: 218 Times
Aren't windtone the ones that are there as stock SKODA horns? Or is it called the roots? I think the latter.
Skoda horns are the most popular in aftermarket horn installation space and almost 7/10 folks go for it.
I too have same horn in my Cruze which i got for Rs.700. I like the sound and also the way it scares away the "loitering kinds" from the front of my Cruze
Do mention the brand of Skoda horns.
When did you purchase?
Is it better than roots megasonic & vibrasonic ?
Vasuki is offline   Reply With Quote
Old 9th November 2012, 13:01   #1259
Geo_Ipe's Avatar
Thanked: 361 Times
Got new horns for my Santro Xing!
Bosch Symphony (Skoda/VW sounding).
550/- bucks for the horn, 800/- total (for relay + switch + wiring + labour)!
Made in India, with one year warranty.
Sounds decent. Fresh, compared to the OEM horns I've been listening to for almost 7 years now. Not too loud maybe. But I haven't listened to it from outside the car properly.
Some pics:
-Both horns mounted on a single clamp bolted on. Looked a little flimsy to me. Repeatedly asked the guy whether it will last. He was damn sure it would!
-Horrible positioning of the switch. It's just wedged into the gap between the panels. The guy says there is no other place on a Santro dash where he can put the switch.
-Box with warranty card
Old 9th November 2012, 20:19   #1260
ankitahuja's Avatar
Thanked: 46 Times
Shouldn't the horns have been positioned the other way around so that the trumpet side was facing outward?
The switch is at a horrible location! Please make changes to this. Use some imagination
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
