Old 7th February 2014, 11:51   #1381
saadat1992's Avatar
Thanked: 293 Times
The roots windtone horn in my Liva stopped working a few weels back and i was forced to use the stock horn of the Liva which is very meek. So,decided to go in for some durable and striking horn. Fitted the Hella Supertones yesterday & my god it's powerful! The sound is so striking that even bigger vehicles give way! The horns are massive in size when compared to the stock one.
saadat1992 is online now   (1) Thanks Reply With Quote
Old 7th February 2014, 12:08   #1382
pratyush6's Avatar
Thanked: 506 Times
Default re: Power Horns!
And I guess they are banned now, according to the SC order. Why don't you replace them with the stock horns? Have you considered the fact that you might be using these monsters in residential areas as well?
I drive a Figo and everyone complains it has got a very weak horn. I have found them to be sufficient. And anyways, it's not that I would fly over people when I honk at them - You seem to be in Chennai which is far better than the crazy place I am in!
Please do give it a thought.
pratyush6 is offline   (1) Thanks Reply With Quote
Old 23rd February 2014, 18:52   #1383
sudipta's Avatar
Thanked: 32 Times
How much did you pay for the two horn + relay set? I guess it was a box pack.
sudipta is offline   Reply With Quote
Old 4th March 2014, 15:40   #1384
Geo_Ipe's Avatar
Thanked: 318 Times
Originally Posted by Geo_Ipe View Post
...Got new horns for my Santro Xing!
Bosch Symphony (Skoda/VW sounding).
550/- bucks for the horn, 800/- total (for relay + switch + wiring + labour)!
Made in India, with one year warranty.
Sounds decent. Fresh, compared to the OEM horns I've been listening to for almost 7 years now. Not too loud maybe. But I haven't listened to it from outside the car properly...
It has been almost a year n a half since I fitted Bosch Symphony on my Santro, and it has been working flawlessly.
Of late, I'm getting a little bored of the tone. Switching back to OEM horns didn't do any good as they're not working properly.
So I was contemplating replacing the OEM horn with Hella Redgrill. My queries are:
- Is it a good idea to have two sets of 'Power horns' simultaneously?
- If yes, do I need a separate relay?
- I'm assuming that the load on the battery won't be too much, as only one pair will be used at a time.
Geo_Ipe is offline   Reply With Quote
Old 4th March 2014, 15:56   #1385
Sommos's Avatar
Thanked: 673 Times
This is more popular as the Hella Red Grill.
How much did it cost and did you fit the relay.
Any specific reason why you want to keep both the horns.
The Red Grills should require a seperate relay and the relay is provided in the box. You'll require a seperate switch also to alternate between the two.
Sommos is offline   Reply With Quote
Old 4th March 2014, 22:40   #1386
Geo_Ipe's Avatar
Thanked: 318 Times
Just the fun factor! The Bosch Symphony is not shrill enough to shoo away the annoying cyclist/two wheeler, I've always felt. And I don't wanna give up the Symphony which is working so well. As I said, just contemplating...
Old 4th March 2014, 23:41   #1387
saadat1992's Avatar
Thanked: 293 Times
It is indeed the hella red grill supertone horn set. produces 118db , its a monster!
These horns are really loud. People give way when u hold the honk for about 1 second!
The horn and wiring cost me 1600 bucks. I didn't put up a new relay as I had swapped the horns with my old roots Windtone horns that were running with a relay.
saadat1992 is online now   Reply With Quote
Old 11th March 2014, 08:42   #1388
pkk_84's Avatar
Thanked: 42 Times
Originally Posted by Mt.olympus View Post
Can anyone let me know which is the brand and model of the horns which comes stock in polo and skoda Laura ?
Seems Roots Windtone is the one fitted as OEM in VW , Benz etc.,
Check out the below link..
http://www.ebay.in/itm/ROOTS-WINDTON...-/260956725304
Hope it helps..!!
pkk_84 is offline   Reply With Quote
Old 11th March 2014, 09:12   #1389
Sheel's Avatar
Thanked: 4,502 Times
Hope it helps..!!
The one at a Skoda/VW ASC costs close to Rs. 3,000 or more, can't recall the exact figure and has the VW logo stamped.
Don't think a Mercedes will use a VW logo stamped horn. They both might sound same, but brands will be different.
IIRC, the brand which supplies horn to the Germans, is Claxon.
Second observation, as far as horns go, Hella, especially the windtone variety isn't as durable as Roots & can't be repaired. It is a fixed/sealed type. I believe this holds true for Minda trumpets as well. Minda sounds the best among this trio as far as prranp goes.
Sheel is offline   (1) Thanks Reply With Quote
Old 11th March 2014, 09:58   #1390
pkk_84's Avatar
Thanked: 42 Times
Then is it Stebel nautilus being used in VW / Skoda ?
As far as I know these are the once expensive close to around 3K in this type
Old 11th March 2014, 14:32   #1391
Sommos's Avatar
Thanked: 673 Times
I don't think Stebel Nautilus is used by VW and Skoda India any more.
The present OEM supplier is most probably Roots India.
Old 11th March 2014, 20:35   #1392
saadat1992's Avatar
Thanked: 293 Times
Did a Comparison video between my Liva's Stock horn and the Hella Red Grille Supertone horns. The difference is massive. Here's the Video!
Old 12th March 2014, 09:20   #1393
Sheel's Avatar
I myself don't think Stebel supplies horns to the Germans and neither roots.
I mentioned the brand Claxon as someone from forums researched it & had put it up. IIRC, the said member was from Bangalore and had an i20.
I have seen the horn which comes with Skoda/VW and there is no branding. VW logo is stamped on it & that is it.
Old 12th March 2014, 12:18   #1394
Sommos's Avatar
Thanked: 673 Times
I've not seen the horns in VW / Skoda, but the site of Roots Industries India Limited claim to be the OEM supplier of electric horns for both VW and Skoda.
Old 12th March 2014, 13:11   #1395
sudeep.pandya's Avatar
Thanked: 297 Times
Just installed Minda trumphet horns in my i20 and it sounds great!!
Crisp and adequately loud. I personally find it better than roots and Hella but it is quite popular among taxi wallahs also.
sudeep.pandya is online now   Reply With Quote
The Best & Safe location for Power Horns mithun Modifications & Accessories 4 30th July 2013 10:40
Yippie - reverse horns = illegal normally_crazy Shifting gears 68 9th May 2011 13:45
Steble Nautilus Horns sounds great! willy Modifications & Accessories 20 10th August 2006 13:03
Will the Air Horns last as longer as Electric Horns ? mithun Modifications & Accessories 4 15th June 2006 11:05
Stebel Nautilus air horns John Technical Stuff 3 11th April 2006 13:37
