Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 1st May 2016, 22:09   #46
Mashblue's Avatar
Thanked: 272 Times
Originally Posted by nitinrawatdun View Post
Hi BHPians!!
I need few suggestions for a new add on accessories for Baleno(Zeta) that i am going to buy soon.
I was not happy with the bass range that the standard music system produced, It was giving more vibrations rather than the thump. I am planning to add a SubWoofer and an amplifier. Need suggestions for the same!!
Budget ~ 10K
The vibrations you mention might be due to the crappy oem speakers. Best thing to do will be to change just the speakers to a better quality one and see if you are happy, or else look to upgrade to a subwoofer and amplifier.
For the initial upgrade I suggest you buy a nice component speakers for the front and plan an upgrade if you still feel the thump missing.
Mashblue is offline   (1) Thanks Reply With Quote
Old 1st May 2016, 23:13   #47
Dr.Naren's Avatar
Thanked: 8,193 Times
Default Re: ARTICLE: The Team-BHP Guide to BASIC Car Audio
Hello guys,
I was not happy with OEM speakers in SX4. I changed it to Memphis Components at front and rear coaxial. I am still not happy with output. Should I get an amplifier or change HU?
Dr.Naren is online now   Reply With Quote
Old 2nd May 2016, 23:28   #48
straight6's Avatar
Thanked: 118 Times
Originally Posted by Dr.Naren View Post
Hello guys,
Just by changing the HU you will get much better sound plus you can get more features like Bluetooth streaming and phone calls.
Check out the Blaupunkt New Jersey 220BT and Pioneer FH-X779BT if you're on a tight budget.
straight6 is offline   Reply With Quote
Old 2nd May 2016, 23:32   #49
Dr.Naren's Avatar
My budget is within 20k for now. Would I get a decent HU and amplifier?
Old 3rd May 2016, 15:08   #50
straight6's Avatar
Thanked: 118 Times
In that budget you can get a HU, Front components, rear coaxials and a 4 ch amp.
Old 3rd May 2016, 16:05   #51
Dr.Naren's Avatar
I already upgraded the speakers. Can you suggest a good brand amplifier?
Old 3rd May 2016, 22:34   #52
straight6's Avatar
Thanked: 118 Times
Go for the Blaupunkt EMA 455.
Old 4th May 2016, 14:58   #53
straight6's Avatar
Thanked: 118 Times
Please also get damping done for all doors as all this even without a sub will make things vibrate.
Old 14th May 2016, 11:43   #54
Neil Roy's Avatar
Thanked: 400 Times
Hi BHPians,
I have an audio related issue with my 2016 Cruze LT. The OE setup sound quality was good, way above average sound quality of OE car systems. I replaced the OE audio HU with JVC KW-V41BT( In dash video player with Bluetooth) and the sound quality has dropped drastically. I tried changing the polarity of speakers and the audio setup to no avail. This is the first time in my ownership experience with 6 cars that the OE HU has performed better than after market MNC brands.
My question is, is the Cruze HU that much more advanced than a 27k after market HU? Sound quality is very important to me(as is the budget) hence is speaker upgrade mandatory for JVC if i need better sound? The OE cruze comes with 6.5 Inch speakers for all four doors + tweeters on the pillar. Any advice/ suggestion is welcome.
Neil Roy is offline   Reply With Quote
Old 14th May 2016, 12:20   #55
Thanked: 730 Times
I have a Brio EX MT variant, which came with single din Alpine HU and 2 front speakers, which I don't know the make of.
I wish to upgrade the sound quality of the same, but am on a shoestring budget. Here are 2 options I have.
1. Take current front speakers, move them to rear. Add component speakers in the front
2. Install rear speakers, leave front speakers be as it is.
Please suggest which route should I take and what speakers should I install. I am looking to get this done in around 2-3k range. Is it worth doing this in this budget?
autorahul is online now   Reply With Quote
Old 14th May 2016, 13:43   #56
Jaggu's Avatar
Thanked: 8,858 Times
Instead of swapping polarity, check if all the speakers are powered in the same sequence, + to + and - to -, if they are mixed up will result in cancellation and bad output.
Next would be to check the sound settings.
Definitely option 1, add a pair of component for front. Brand based on your taste of sound, audition few at a store.
Old 21st February 2017, 00:14   #57
Thanked: 372 Times
I drive a polo gt tsi with the stock audio system.
I have an RF r1 sub + enclosure sitting in the storeroom
What would be the suggestions for the amp and speakers.
I see the Blaupunkt EMA 455 is recommended above, it'll cost 6k. There is the Sony XM-N1004 for a couple of hundred bucks more as well.
For the speakers, I am thinking I'll go component for the front, and leave the rears as stock due to monetary constraints, or maybe some good coaxials. I would prefer to spend more on the front speakers.
The budget for speakers is approx 7k, can stretch to 10k or 15k if other options are way better.
Head unit, right now I am planning to stick to the stock one and go the 330+ sometime later on. I shall get the damping done as well and would like to know which brand to go for. Along with that would like to know any place in Bangalore that is recommended for installation since the car is here.
Would prefer suggestions that are available on amazon/flipkart etc since I'll be buying on EMI, and that makes the budget quite flexible.
H_Dogg72 is offline   Reply With Quote
Old 12th October 2017, 17:18   #58
Maverick79's Avatar
Thanked: 568 Times
Guru's
Seeking advice for a basic Audio system with bluetooth compatability, usb slot at least and preferably no CD player for my M800 refurbishing project.
Brand doesn't matter.
Thanks in advance.
Maverick79
Maverick79 is offline   Reply With Quote
A basic guide to traveling into and in Nepal buddha141 Route / Travel Queries 22 17th April 2018 07:33
ARTICLE: The Team-BHP Guide to ADVANCED Car Audio navin On modifying a car 29 16th December 2016 15:28
