Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 11th August 2009, 12:22   #1936
Jaggu's Avatar
Thanked: 8,860 Times
arre yaar tsk Honda in bangalore sells synthetics these days! As far as honda goes i will completely agree with your thoughts.
Overpriced and over hyped brand in India lol
Old 12th August 2009, 07:54   #1937
sgiitk's Avatar
Thanked: 3,903 Times
Originally Posted by Sawyer View Post
I am surprised, though the Honda recommendation is 8000kms when you convert. Most people in the US would rack that up in 2 months. Maybe a regular car user in the US can shed some light on this. If I did 5000kms a month in the US, with a good synth, I would feel comfortable with an oil change every 15000kms. Let's see if we get any actual user input on this, all I know about the US practice is from casual conversation with my friends when I am there. And reading on the subject.
US Honda has 3000 mile oil change
US is worse. It is 3000 miles !! Here is an excerpt from the Honda Service Schedules:
Minor Service Interval
Mileage: 3,000 - 6,000 - 18,000 - 21,000 - etc.
Engine oil and filter - replace
Fluid levels - top off all
Lube hinges, locks, latches, and hood cable
I had pm'ed @Sawyer but thought others may also wish to know.
Old 12th August 2009, 08:43   #1938
Thanked: 1,499 Times
All I can say is that Honda is being consistent, that translates to 5000kms, give or take. I can't see too many Americans in compliance, but will defer to any actual user comment.
Sawyer is offline   Reply With Quote
Old 12th August 2009, 09:34   #1939
Gansan's Avatar
Thanked: 917 Times
Originally Posted by Gansan View Post
But since the purity of the oil is the responsibility of the customer, it is prudent to double check the source, and preserve the sale invoice of the oil carefully for future use.
Originally Posted by gpa View Post
He was clear in stating that the purity of the oil will have to be checked by the customer.
A query related to this point. If the oil happens to be spurious despite all precautions, can it be found out during usage? I mean, will there be any odd symptoms like engine overheating etc., so that we can at least flush it from the engine immediately?
Old 12th August 2009, 10:00   #1940
DieselFan's Avatar
Thanked: 234 Times
There are various Symptoms of wrong/spurious oil in Engine. Some commonly noticeable ones are -
1. Low power/Torque output from engine. Driving is painful because of repeated down shifting.
2. High engine noise
3. Smokey exhaust especially in Diesels
4. In severe cases Check engine light glows. May lead to seizure of engine.
Engine normally doesn't get overheated as radiators are over designed in a car and can handle much higher capacities to cool of the engine.
DieselFan is offline   Reply With Quote
Old 12th August 2009, 10:26   #1941
I feel we have to be very careful regarding recycled/spurious engine oil. Even two decades earlier, recycled oil was commonly sold mostly branded as the then costliest Castrol. (at least in Kerala)
janitha is offline   Reply With Quote
Old 12th August 2009, 10:35   #1942
sgiitk's Avatar
This was (and is) a consistent problem. Castrol was (and presumably still is) the most popular brand with the fakers. One must go to a reliable source. I therefore get my oils from Gwalior where we have a source we are sure of. I have a feeling that this is a bigger problem in the smaller cities that in the metros.
Old 12th August 2009, 11:49   #1943
csateesh's Avatar
Thanked: 122 Times
Default Question to oil Guru's
Hi Folks,
I use a Mobil 1 fully synthetic 5w50 for my Accent CRDi. I hope this isn't an issue.
Thanks and Regards
Sateesh
csateesh is offline   Reply With Quote
Old 12th August 2009, 12:04   #1944
DieselFan's Avatar
Thanked: 234 Times
Originally Posted by csateesh View Post
Hi Folks,
Thanks and Regards
Sateesh
If you source it from a reputed dealer or better company stockist then it would be guaranteed genuine. Hence I go for dealers or stockists and buy from them even if it means travelling 10+ kms to source it.
Old 12th August 2009, 12:10   #1945
Jaggu's Avatar
Shouldnt be a big issue but stick to 5-7k changes since its not a diesel specific synthetic and will not have much of detergent in it, which modern diesel engines would ideally need.
Old 12th August 2009, 12:51   #1946
csateesh's Avatar
Thanked: 122 Times
Yes I pick it up from the Dealer itself.
But is 5w50 the ideal one for CRDi engines?
Sateesh
Hi Jaggu,
What do you recommend for the modern diesel engines? Mobil1 Delvac? But it is very difficult to source the Mobil1 Delvac in 4 ltr cans.
Thanks and Regards
Sateesh
Last edited by Jaggu : 12th August 2009 at 12:58. Reason: back to back posts, please use multi quotes. Thanks
Old 12th August 2009, 12:59   #1947
Jaggu's Avatar
Yup Mobil Delvac 1 ideally but i havent seen one can in my life, it exists only in cyberspace or something. Atleast here in India.
This is the primary reason why am sticking to mineral delvac, unless a good source is identified i dont want to shift and then wonder what to do at next change
Old 12th August 2009, 13:42   #1948
greenhorn's Avatar
Thanked: 1,541 Times
even mercedes can't source it to pour in their diesels and use regular synth, the stuff they use for petrols ( I think I read it in GTO's ownership thread)
Think the only dude I know who has a diesel running on synth is rippergeo, who got hold of some OWS turboracing via petes
Old 12th August 2009, 14:18   #1949
DieselFan's Avatar
Thanked: 234 Times
Mobil 1 is not an oil recommended for Diesels but people on this forum have used it on Diesels without any issues. Having said that would I go and use it on my car - I will not. I would rather buy Mobil Delvac 1 and use the same or use Mobil Delvac MX (A Good Mineral oil).
Old 12th August 2009, 14:19   #1950
csateesh's Avatar
Thanked: 122 Times
I am talking to distributor / dealer to see if they can help.
@greenhorn
I understand Merc is unable to source it but talking to the dealer gives me a very different impression. No committed business and hence he doesn't want to source it as it isn't an Hot product with others because of its price.
Just my opinion
I don't have a lot of complaints by using 5w50 but if I can use the Delvac Synthetic and use the recommended why not is the question.
Sateesh
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
