Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 23rd August 2009, 22:48   #1981
archat68's Avatar
Thanked: 290 Times
Originally Posted by PatienceWins View Post
Hows the experience after shifting to Castrol Magnatec? I have heard many good reviews about it.
I shifted to Castrol Magnatec in my Zen after using mineral oil for 83K KM. The improvement is very noticeable. I'm happy with the oil.
archat68 is offline   Reply With Quote
Old 23rd August 2009, 23:00   #1982
Thanked: 1,498 Times
Originally Posted by emkay456 View Post
Today I had taken the vehicle to Lavasa from Panvel. Frankly speaking nothing much to report on the difference. But then I feel that my vehicle having only clocked around 15000 kms the difference cannot be much to feel.
Hope I am correct.
You are. A lot of the perceived difference is in people's heads.
Sawyer is offline   Reply With Quote
Old 25th August 2009, 11:24   #1983
Thanked: 49 Times
Where can I get Petronas oils in Bangalore ? I need mineral oil for a brand new (<500Kms) engine
CrackedHead is offline   Reply With Quote
Old 25th August 2009, 11:51   #1984
funkydude's Avatar
Originally Posted by Jaggu View Post
Good refresher though.
A related good news thanks to the relentless follow up by a fellow Tbhp'ian, i came to know that we might be getting Mobil Delvac 1 (Diesel specific oil), in couple of months here in India (4 Liter packs).
Don't know if this has already been answered in this thread.
Can I use the Mobil Delvac1 in my all new Ikon tdci? Will this oil make any change to the engine performance.
Mine has just done 5k, so I beleive a flush ain't required. As informed earlier in this post, flush is no required before 20k. So should I go with this oil change without a flush?
Few bhpian's have been using this oil. From where did you manage to get it?
Last, from where can I get Mobil Delvac1 in Delhi?
funkydude is offline   Reply With Quote
Old 25th August 2009, 12:06   #1985
mithun's Avatar
Thanked: 58 Times
Which brand of Mineral Oil is best for Alto BS II ?
I don't need a synthetic since I drain the oil every 5K.
Old 25th August 2009, 12:16   #1986
Jaggu's Avatar
Thanked: 8,680 Times
Yes you can use Delvac 1 on iKON tdci and no need for flush, ensure they drain the old oil completely and replace the oil filter.
Though i would suggest you wait till 10k kms, since diesel engines require some more running in and 10k km mark is a good point to shift, but thats just me
I would suggest Castrol Magantec, bang for bucks oil.
Old 25th August 2009, 12:24   #1987
mithun's Avatar
Thanked: 58 Times
Thanks for the advice. But it's Viscosity is SAE 10W-40. For Alto 20W-40 is needed, Right ?
What's the price ?
Old 25th August 2009, 12:33   #1988
sgiitk's Avatar
Thanked: 3,883 Times
Try to get Petronas Mach5. I am using 20W50 in one of my cars. It is API-SM, is cheaper than Magnatec, and is a pure mineral oil.
Old 25th August 2009, 13:04   #1989
Thanked: 49 Times
^^^ anyone know where I can find Petronas in Bangalore ? Thanks
Old 25th August 2009, 13:17   #1990
gpa
gpa's Avatar
Thanked: 282 Times
+1 to that. My Santro is nearing its 60k service and since I run on Mobil 1, I'm planning to shift to Petronas' Syntium.
Will appreciate it if someone shed light on the same.
Thanks,
gpa
Old 25th August 2009, 15:15   #1991
Raccoon's Avatar
Thanked: 105 Times
What's the price ?
Magnatec is supposed to be a semi-synth. For mineral, consider Petronas/Mobil/Valvoline/etc... many options! 10W40 should be ok... don't you have a chart in the manual?
Old 25th August 2009, 15:23   #1992
Gansan's Avatar
Thanked: 913 Times
The lower number should be equal to or less than 20W, while the upper one should be equal to or higher than 40. This is what I understand after reading up on this subject.
The owners' manual has a chart which shows that 15W40, 20W40 and 20W50 are all OK. I am using the Shell Helix Super mineral oil (15W40, API SL) for my two month old Alto. Costs Rs 915.00 for a 4 litre can. I intend to change the oil every six months, so no synth for me.
Old 25th August 2009, 15:57   #1993
Jumping in to clarify again that this semi synth thing is marketing humbug, Magnatec is a mineral oil. Magnatec is better than Shell Helix because of a one step better API spec, and a wider grade of 10w40. Which by the way is fine for the Alto.
But really there isn't much of a difference between the Shell referred by Gansan and the Magnatec. Use whatever is cheaper, and what you can be sure is authentic and not spurious. Don't overfill, and if you change the oil every 6 months, both oils will give you long and reliable engine life.
As a 10w oil, the Magnatec may give you a little better FE, but I am not sure the difference will be statistically significant.
Old 25th August 2009, 18:14   #1994
funkydude's Avatar
Petronas Mach5!! is it for diesel or for petrol vehicles only. And is it better than the Mobil Delvac 1?
I own a Ikon TDCi, so would this be the best one for my baby?
Someone tell me, where can I get Mobil Delvac1 or Petronas in Delhi/NCR?
Old 25th August 2009, 21:40   #1995
I have a year old Pajero, and it has done very well on Castrol RX Super Plus. That is a CH 4 spec, current tech diesel engine dedicated oil, and since I change the oil every 6 months regardless of kms run, with a 8 litre sump, it makes a lot of sense to me. Obviously I cannot say this conclusively, because I have not lifted the head to see how things look! But the factory service station is ok with the oil too. It is also easily available.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
