| LinkBack | Thread Tools | Search this Thread |
| | #2251 |
| Senior - BHPian Join Date: May 2009 Location: Chennai
Thanked: 327 Times
| | #2252 |
| BHPian Join Date: Jul 2009 Location: Bangalore
Thanked: 20 Times
| Another Q, which may have been answered: Am taking my vista for a 10K service. Am planning to get the synthetic - will look for delvac, if not Mobil 1. Any other brands that you would recommend, given the doubt on the availability of these oils at TASC. Anyone have any previous exp with changing to synthetic at TASC? What was the cost? I know Tata promotes castrol heavily - Are there any castrol synthetics which are good? Any reviews on Magnatec for diesel? |
| | #2253 |
| BHPian Join Date: Nov 2009 Location: Bangalore
| Hi Shell has changed the names of its Helix range. For those who want to know here is the name from old to new in the file attached. Please not, HX5 is premium mineral oil and HX7 is the semi synthetic oil. Talking to shell marketing person I found that HX7 is not yet available in Bangalore and could take another 2 to 3 months to be launched here. |
| | #2254 |
| Senior - BHPian Join Date: Mar 2007 Location: Bangalore
Thanked: 73 Times
| @Vista_Qjd - Mobil 1 is not a Diesel engine oil and is not recommended for MJD/QJD/DDIS engine. You either use Mobile Delvac 1 (Synthetic) or Mobil Delvac MX (Mineral). |
| | #2255 |
| Senior - BHPian | Guru, any idea when "HX7" will be introduced in the market? "HX5" costs 915 bucks, any idea how much HX7 costs? |
| | #2256 | |
| BHPian | Quote:
| | #2257 |
| I Got Hx5 for Rs 685/- for a 3 L can. For some reason, I don't know why the Hx7 semi synthetic has not been launched all over India. I think it is only available in Mumbai and it possibly could be launched in other parts of the country in a few months. However, Hx5 is good . |
| | #2258 |
Thanked: 20 Times
| 1000/- per litre? Isnt that expensive? I have seen others quote lower for delvac. Are those the regular mineral oils nad not synthetic? |
| | #2259 |
| Distinguished - BHPian ![]() | |
| | #2260 |
| Senior - BHPian Join Date: Oct 2008 Location: Punya Nagari
Thanked: 211 Times
| | #2261 | |
| BHPian | Quote:
i then switched on to 10w-30 honda OEM oil and things got back to normal though i still miss that smoothness in the engine . i have a nhc WITH 13000KMS on the odo. my recommendation is you stick with 5w-40 oil it must be good and less thinner than 0w-30 and anyways i dont think it is suitable for our climate. as earlier honda used 20w-50 oil as oem | |
| | #2262 |
| BHPian | Also my father has 2003 model NHC and he has clocked 125000kms on it . he has ALWAYS used OEM oil and his car is super super smooth till now . no problems of sludge at all. |
| | #2263 | |
Thanked: 211 Times
| Quote:
0w is generally recommended for cold weather conditions. Toyota in the US/Canada recommends 5w-20 in the new generation cars. And this is an all weather oil. Of course some parts of the southern US experience tropical temps like we do here. My car is currently on 5w-40 Shell Helix Ultra synthetic. Trying synth after a long time and only because it is the same grade/spec as the mfr recommended synthetic oil. Shell HU is good oil and I think it is reasonably priced compared to Mobil1. Unfortunately Mobil1 does not come in grades recommended by my car mfr (only in 0w-40 and 5w-50) so I keep away from Mobil though it may be better than Shell. Using synthetic + iridium plugs has made a marginal difference to my car's mileage. It now give 16.3 on the highway with A/C on compared with 15.6 previously. Not sure if it is worth all the added expense. But the car runs very smooth. Cheers! Last edited by R2D2 : 9th December 2009 at 21:53. Reason: previous mileage added | |
| | #2264 |
| Senior - BHPian | Fiesta s. What brand of oil? @ how many kms? And which grade? |
| | #2265 |
| Distinguished - BHPian ![]() | @10,000 kms, switch to 5W40. Shell Helix Ultra or Mobil Synt S. Should cost around 2800 for a 4 litre can. |
Similar Threads | ||||
| Synthetic Gear Oil | cyneverdie | Technical Stuff | 21 | 19th June 2013 11:30 |
| Synthetic Oil in Bangalore | epyupc | Modifications & Accessories | 46 | 12th June 2013 13:46 |
| Oil change..Synthetic, where to source | DRC | Technical Stuff | 21 | 2nd December 2007 14:00 |
| Synthetic Oil | karthik247 | Technical Stuff | 10 | 8th November 2005 17:02 |
