Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 20th December 2010, 22:42   #2776
nitrous's Avatar
Thanked: 285 Times
Default Re: ARTICLE: Synthetic oil vs Mineral oil
Originally Posted by Skyline GTR
I have decided to stick to 5W30 till next oil change.....& drive at lower RPMs. What is the opinion about adding some additive? Is it going to help?
1. Good call
2. Don't add any additives and don't stress the engine.
You should do ok.
Old 21st December 2010, 00:12   #2777
khoj's Avatar
Thanked: 1,255 Times
Hey guess what? That principle of learning applies to you too! Not that I want to get into a slanging match here.
Touche, you got me what with the principle indeed being universally applicable. Lesson in manners - check
If you really believe that any oil can be used in any engine...well, please go ahead and follow your own theory! The rest of us will be content to follow sane advice i.e. what a car owners manual recommends.
As for the underlined part above that is not the gist of what I have posted but whatever it is ( the technical bits ) that I have, I stand by it. Thanks again & Regards
Old 21st December 2010, 09:13   #2778
R2D2's Avatar
Thanked: 1,516 Times
No worries...we all have our moments. :-)
Appreciate that.
I can relate to the 'Castor oil' bit having grown up in the 70s with Ambys Standard Heralds and Premier Padminis which could use nearly any engine oil you poured into them. Those engines were ancient tech even in those days. The commonly used oil in those days was SAE 50. The technical bits about flash and pour points are correct but the applicability of any oil in any engine where you say "oil is oil" isn't. Either way...let this rest here. We all have our opinions.
Wishing you a good day.
Cheers!
Old 21st December 2010, 10:46   #2779
Smile Re: ARTICLE: Synthetic oil vs Mineral oil
I have a Hero Honda Pleasure gearless scooter. Am interested in using fully synthetic oil. Pls recommend a good fully synthetic engine oil guys. Can i use Mobil 0-50 or 5-50?
Dr.Abhay Shah
drabhayshah76 is offline   Reply With Quote
Old 21st December 2010, 11:43   #2780
Gansan's Avatar
Thanked: 899 Times
Dr.Abhay Shah
Any oil you use must be two-wheeler specific. Don't use a car oil.
Old 21st December 2010, 12:53   #2781
para_7k's Avatar
Thanked: 63 Times
Dr.Abhay Shah
Shell Advance Ultra or Castrol Power 1 Racing. These are the popular fully synthetics available for 2 wheelers.
Price of both should be around 750 per litre.
para_7k is offline   Reply With Quote
Old 21st December 2010, 21:07   #2782
blackfire_9's Avatar
Thanked: 187 Times
Guys, has anybody tried Eneos engine oils? They are a product of Nippon oil corporation (Japan) & are marketed here in India by the Tide water company (Veedol). I have a few cans lying around but never really got a chance to use them.
I wanted to seek some opinions before opening & putting them to use.
Drive safe.
Old 22nd December 2010, 11:54   #2783
Thank you Gansan & Para 7k. I will enquire abt those oils and get back to ya. Regards.
Old 24th December 2010, 10:45   #2784
Skyline GT-R's Avatar
Thanked: 206 Times
I had a look at Mobil Delvac 15W40 1L pack (Rs 260/-) It is specified for both Diesel & Petrol engines but it is mentioned "for heavy duty use"
The can shows pictures of truck, LCV & Pick up truck. Does it mean it is not for passenger cars & what exactly is "heavy duty"?
Meanwhile i checked the users manual & found that 5W30 is specified for Maruti 800 when used in low temperature weather.
Skyline GT-R is offline   Reply With Quote
Old 24th December 2010, 15:12   #2785
Abeer's Avatar
Thanked: 12 Times
Originally Posted by csateesh View Post
Akshay
1150/L is MRP. Typically the discounted price is around 850/L for the end user.
Push him for a discount.
Sateesh
Got Mobil 1 0W40 for 3000/- (4 Litres) printed price was 4600. This was from Singh Motors in Sector 16 Car Market in Noida
Abeer is offline   Reply With Quote
Old 24th December 2010, 17:10   #2786
Jaggu's Avatar
Thanked: 8,319 Times
It means it can be used for heavy duty usage, long hauls, constant start stop, heavy hauling etc and you might have seen it has excellent detergent characteristics mentioned, since its designed for diesel turbo's with EGR.
Old 24th December 2010, 18:15   #2787
prince85's Avatar
Thanked: 117 Times
hi team, need some help from fellow i10 owners and oil gurus in this thread for my hyundai i10 kappa.
Firstly, please tell me what is the manufacturer's recommendation for oil grades for the 2009 i10? as the oil grade chart given in the manual isn't very clear as it has different oil grades for different temperatures. i stay in mumbai and ambient temperatures are pretty erratic
Well my car has run 5k kms and now i wish to go the synthetic route. Kindly suggest the brand and grade of oil soo that i can pick the right engine oil for my car.
PS - my car is currently running on Shell HX3 API-SG 20w50 since the last 500kms. I know that API-SG is pretty dated but my driver got the oil change done while i was out of town.
gurus, kindly suggest to my above queries
cheers
prince85 is offline   Reply With Quote
Old 27th December 2010, 11:07   #2788
sgiitk's Avatar
Thanked: 3,833 Times
Quite frankly. Just look at the higher end of the grade specified for (unrestricted) ambient. Then get any decent oil with this higher rating. The lower lower point (a in aWb) is not that critical. You can search for my post(s) on this forum (incl. this thread) for a full explanation.
Old 27th December 2010, 19:04   #2789
scarlet.fever's Avatar
Thanked: 25 Times
Could somebody let me know a dealer in Gurgaon/Delhi from where I could buy Castrol 10W40 semi-synthetic with an API-SM rating
scarlet.fever is offline   Reply With Quote
Old 27th December 2010, 19:49   #2790
Thanked: 187 Times
^^ If in Gurgaon, there is one by the name of Jain oil depot at sohna chowk, next to the tvs showroom.
Drive safe.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
