Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 13th April 2011, 10:26   #2971
sgiitk's Avatar
Thanked: 3,903 Times
Default Re: ARTICLE: Synthetic oil vs Mineral oil
.......... detailers ............
Oops, the correct term is blueprinting and not detailing.
Old 13th April 2011, 22:09   #2972
Xehaust's Avatar
Thanked: 74 Times
Alright guys. Thanks for the info. So the oil & oil filter will now be changed at the second service mostly. Will try & find out the engine oil they use & post it here when its changed along with the cost. Perhaps itll help someone.
Xehaust is offline   Reply With Quote
Old 13th April 2011, 22:46   #2973
nitrous's Avatar
Thanked: 285 Times
Running-in is still vital even today.
If not, Why would a piece of technical brilliance that is the 4.4litre BMW V8 revving up to 8000rpm have a run-in process of "5500rpm and no full throttle until 1200miles" specified in the owners manual ?
Old 14th April 2011, 00:24   #2974
Xehaust's Avatar
Thanked: 74 Times
Well, we are discussing the oil & oil filter change during running in & not the running in itself. The car as been adhered to the running in gear ratios & speeds as per the manual.
The question here is, do we still need to change the oil & oil filter in the first thousand kms or miles?
Old 14th April 2011, 07:23   #2975
Gansan's Avatar
Thanked: 917 Times
If your owners' manual does not specify it, you don't have to. Just adhere to whatever it says, and live happily ever after!
Old 15th April 2011, 04:38   #2976
satish_tns's Avatar
Thanked: 112 Times
Hi all. After changing oil in my swift vdi abs, now going to change in my baleno. Bought Mobile 1 0W40 fully synthetic for Rs.4000 (4 litre can).Hope this is the right one. I dont know the oil spec for my baleno as per owners manual as I lost it. Baleno owners and friends of baleno owners please help me in finding the spec as per the owners manual.My Baleno is year 2000 model.
satish_tns is offline   Reply With Quote
Old 15th April 2011, 09:32   #2977
nitrous's Avatar
Thanked: 285 Times
0W40 in Chennai summer?
Exchange it for the Mobil1 5W50.
Old 15th April 2011, 13:46   #2978
sgiitk's Avatar
API-SN Specifications.
Here is what I was able to find. No cards for simple folks like us so far.
@satish_tns: I hope you are talking about Mobil1 and not Mobile1!
Old 22nd April 2011, 04:44   #2979
satish_tns's Avatar
Thanked: 112 Times
Nitrous, before even I tell my brother to get 0W40 exchanged with 5w50, he went in and got the 0w40 filled in my baleno. On riding it after having mobil 1 0w40, i was surprised on the terrific change. In 80kmph on 5th grear, i fell that the engine is turned off and doubt whether it is running as it is so quiet. Also gives out a tearing performance.
Off topic, a quick question while we have experts here in this thread.. Does engine oil, even if it is fully synthetic, will be black in colour in diesel engines, that to a week after engine oil change?? Khivraj maruti says that engine oil will be only black for diesel engines even if oil is changed just now. Just wanted to confirm as it makes logic since diesel engine are oil burners. I wanted to ask as in my swift vdi abs, engine oil is black when I checked and it has done 1000 km since i changed to shell helix ultra 5w40 2 weeks back.
Old 22nd April 2011, 11:07   #2980
Thanked: 113 Times
Please do if the service schedule in the manual specifies it.
--Ragul
Ragul is offline   Reply With Quote
Old 23rd April 2011, 15:41   #2981
Born 2 Be Wild's Avatar
Thanked: 176 Times
After a Lot of seraching couldnt find any oil in delhi in 5W30 for my TDCI fiesta hence went ahead and purchased Mobil Delvac 1 And the results so far are just a quiter engine and its a little free in its revs then before nothing major though, Thanks SAnkar for all your help .
Diesel engine oil will go black within a day of you pouring it in to the car, if not sooner!
Born 2 Be Wild is offline   Reply With Quote
Old 23rd April 2011, 17:16   #2982
msupercool's Avatar
Thanked: 26 Times
Guys i have an Accent GLS 1.5 which has done 72000kms. Its overall engine work was done at 60000kms since then its running on Castrol gtx magnetic with oil change at regular intervals. I want to change it to synthetic. Which one should i go for Shell helix ultra or Mobil 1? and if Mobil1 then what grade? do i need to do an engine flush while changing to synthetic?
msupercool is offline   Reply With Quote
Old 24th April 2011, 02:19   #2983
khoj's Avatar
Thanked: 1,258 Times
Originally Posted by Born 2 Be Wild View Post
went ahead and purchased Mobil Delvac 1 And the results so far are just a quiter engine and its a little free in its revs then before nothing major though!
Hey B2BW,
The poor thing has gone and done what probably an injector flush and a decarbonization would not have been able to achieve ( without the associated side effects that is) and you still believe it is nothing major. Come on! do give the oil credit, where it is due.
Old 24th April 2011, 09:52   #2984
v&v
v&v's Avatar
Thanked: 1,128 Times
I would suggest Mobil 1 5w40. Since its only run 12k after engine work , i would suggest to switch to synthetic after 20k. Do flush the engine before switch to synthetic.
v&v is offline   (1) Thanks Reply With Quote
Old 24th April 2011, 10:59   #2985
Thanked: 113 Times
Fquote=v&v;2324962]Do flush the engine before switch to synthetic.[/quote]
Why? Flushing has negative effects and is risky for engine performance is it not? Is it a MUST/ALWAYS recommendation? What if we dont?
--Ragul
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
