| LinkBack | Thread Tools | Search this Thread |
| | #3466 | |
| Distinguished - BHPian ![]() Join Date: Dec 2007 Location: Kanpur
Thanked: 1,186 Times
| Quote:
| | #3467 |
| Senior - BHPian Join Date: Nov 2009 Location: India
Thanked: 164 Times
| ^^ Just adding for everyone's information that Castrol Edge is also only available in 0W40, 5W40 & 10W60 grades in India as per the website. |
| | #3468 |
| BHPian Join Date: Apr 2009 Location: bangalore
Thanked: 12 Times
| Hello Friends, I have a 2008 maruti alto done 55000kms,i have a query ,for all these years i have been using 10w 40 oil from shell,but maruti recommended is 20w40 ,should i use 20w 40 since its done 50000 kms or can i use 10w 40 semi synth from shell .thank you ..awaiting replies ![]() |
| | #3469 | |
| BHPian | Quote:
Difference of opinion is solicited. | |
| | (1)
| | #3470 |
| BHPian Join Date: Jul 2011 Location: Pune
Thanked: 43 Times
| Guys any recommendation for Synthetic Oil for i20 Diesel? |
| | #3471 |
| BHPian Join Date: Dec 2006 Location: Kolkata
Thanked: 83 Times
| | (1)
| | #3472 |
| BHPian Join Date: Sep 2010 Location: Bangalore
Thanked: 97 Times
| I was staring at my oil filter today and just realized it is recommended to change every 10K kms. But since I switched to synth, and plan to keep it for 20k kms, should I keep the oil filter for 20k? Can we change an oil filter at 10k without draining the oil? I doubt it but curious if anyone has any novel ideas. --R |
| | #3473 |
| @Ragul; Normally 20k is not recommended. But you may be a high mileage motorist. Change the filter when you change the oil. However, for your information the filter can be unscrewed, and a new one spun on, loss of oil is about 250ml. |
| | (1)
| | #3474 | |
| Senior - BHPian Join Date: May 2010 Location: Bengaluru
Thanked: 293 Times
| Mobil Delvac1 is the best synthetic diesel oil for i20 CRDi. Its worth the money! Quote:
Even if you use synth 20K is way too high. If you do a lot of highway driving,say , if 15K out of this 20K is on highways then its fine.But if your driving is in city bumper to bumper traffic i suggest changing at 10K kms, max at 15K, nothing beyond that for sure!! | |
| | #3475 | |
Thanked: 97 Times
| Quote:
--R | |
| | #3476 |
| @Ragul; Often the car vendors fail to mention the time scale. I will say 12 months (15 max). Oil oxidises just sitting in the sump. Last edited by sgiitk : 6th June 2012 at 15:28. |
| | #3477 | |
Thanked: 293 Times
| Quote:
You can experiment with 20k change interval . Your engine Will go for a toss. If you are sticking to mineral oil then recommended is 5k max sustainable till 7.5 . In case of synthetic 10k max sustainable till 15k. | |
| | #3478 | ||
Thanked: 97 Times
| Quote:
The new fully synth oil did not appear to improve on the peppiness except on the noise slightly - engine is quieter but the Gypsy is not a loud car like a Mahindra diesel in any case. The racy and peppy feel only came back to what was @18K kms - some 1K kms after the 20k kms oil change - it seemed to go away when the oil was fresh. --Rahul Last edited by Ragul : 6th June 2012 at 20:37. | ||
| | #3479 | |
Thanked: 293 Times
| Quote:
| | #3480 |
| My experience is that the engine seems to get run in, at some point in a hurry. So maybe yours got run in around the 18k point. Do not ask me why but I have found this fully done point comes on fast. |
Similar Threads | ||||
| Synthetic Oil in Bangalore | epyupc | Modifications & Accessories | 45 | 3rd April 2013 23:55 |
| Synthetic Gear Oil | cyneverdie | Technical Stuff | 20 | 8th March 2011 14:28 |
| Oil change..Synthetic, where to source | DRC | Technical Stuff | 21 | 2nd December 2007 14:00 |
| Synthetic Oil | karthik247 | Technical Stuff | 10 | 8th November 2005 17:02 |
