Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 29th October 2007, 12:37   #661
razor4077's Avatar
Thanked: 252 Times
Originally Posted by cancerm View Post
Hi JK das
Santro Xing requires 3.5 litres of Engine oild to be precise.
3.3 Litres actually... since we are being precise
razor4077 is offline   Reply With Quote
Old 29th October 2007, 14:46   #662
Hi Razor
In the manuals of Santro it says 3.5 litres BUt I wont argue if you say it requires 3.3 litres Dude
Chao
cancerm is offline   Reply With Quote
Old 29th October 2007, 23:01   #663
rider60's Avatar
Thanked: 47 Times
next time i get my car serviced i want either the 5w50 or the 10w50 oil for my viva crdi can you guys suggest me good brand names and if possible a dealer in hyderabad to get these!
rider60 is offline   Reply With Quote
Old 1st November 2007, 21:32   #664
PatienceWins's Avatar
Thanked: 265 Times
I price of Mobil Super syn 5W-50 in General Automobiles, J.C Road, Bangalore is 780 / litre. Just checked the price and availability when I went to J.C road. Waiting to complete 15000 kms.
PatienceWins is offline   Reply With Quote
Old 2nd November 2007, 11:41   #665
vijit.gangwar's Avatar
Thanked: 65 Times
Originally Posted by BUSA View Post
So that means no syntetic avilable for Swift D?
Just foud out Mobil Delvac 1 5W - 40 is the one which is perfect for the Swift Diesel.
vijit.gangwar is offline   Reply With Quote
Old 6th November 2007, 14:10   #666
Thanked: 9 Times
Default Query on CF-4 versus CF and Castrol Edge
More information about Mobil Delvac 1 (5W 40) which is fully synthetic.
Mobil Delvac 1 5W-40
Question w.r.t link given in one of the earlier posts on API ratings:
API Oil Service Categories
CF-4 Current Introduced in 1990. For high-speed, four-stroke, naturally aspirated and turbocharged engines. Can be used in place of CD and CE oils. CF-2 Current Introduced in 1994. For severe duty, two-stroke cycle engines. Can be used in place of CD-II oils. CF Current Introduced in 1994. For off-road, indirect injected and other diesel engines including those using fuel with over 0.5% weight sulfur. Can be used in place of CD oils.
CF is mentioned as introduced in 1994 where as CF-4 is introduced in 1990. So which is the latter standard ?. CF-4 or CF ?.
Also CF-4 is mentioned as applicable for naturally aspirated and turbo charged engines whereas that is not mentioned for CF.
I am currently using Castrol Edge 5W-40 for my Swift VDI which meets API CF standard (owner's manual mentions that the oil should meet API-CG-4).
Castrol Edge being sold in India is manufactured in South Africa.
They do not mention whether its for petrol or diesel engines.
"For prestige & High performance" is the slogan.
Is it okay to use this engine oil for Swift VDI ?.
Ravi.
iridium is offline   Reply With Quote
Old 25th November 2007, 20:11   #667
gemithomas's Avatar
Thanked: 136 Times
Default Castrol Magnatec or Mobil 1?
My car has done 15K km. Should i go for Castrol Magnatec or Mobil 1 for the FIAT 1.6 Petrol Engine. And is the 15W40 avaiable for these brands. Is there any advantage / disadvantage in going for 10w40.
HELP!
Old 25th November 2007, 20:47   #668
Jaggu's Avatar
Thanked: 7,684 Times
HELP!
Mobil 1 definitely, smoother and silent engine.
Old 25th November 2007, 21:43   #669
tsk1979's Avatar
Thanked: 15,685 Times
Try 15W50. You are in trivandrum, so you don't need 10W. The upper number should be 50 instead of 40 as it will give better protection to engine at higher temperatures.
Old 26th November 2007, 09:19   #670
gemithomas's Avatar
Thanked: 136 Times
Thanks guys. But going through the mobil site i have a feeling that these oils are not 100% synthetic. THe only place they mentin 'fully synthetic is for delvac which is recommended for diesels. ALl other oils they have played safe by just mentioning "performance synthetic engine oil". I guess there should be sme thechicalities in not using the "fully synthetic" tag for the petrol engine oils. I seriously think they should be semi-syntehtic with additives. Please confirm if you have any idea.
Also i find only a 0w40 and 5W50 in the mobil range of synthetics. the recommended oil by fiat is 15w40. dont you think that higher (50) rating could be a issue .
Old 3rd December 2007, 12:12   #671
Hi all,
Wnated to know from 'Oil Gurus' whether it is ok for me to change over to Synthetics for my Indica (Diesel), which has already done 84.5k kms.
I know most of you would advice against it because the 'flushing' procudure removes carbon deposits, which would have otherwise acted as sealant of sorts.
In my case, I have already got the engine flushed at 82.5K, though not with the intention of switching over to synthetics. I have not seen any major change(read decline) in performance after flushing procedure.
So, now that I have already flushed the engine, is it ok to switch to synthetics during my next service at 87.5k Kms?
Thanks in advance
CaAT is offline   Reply With Quote
Old 3rd December 2007, 12:43   #672
tsk1979's Avatar
No need to flush again, you can switch over to synthetic oil at next change.
Old 3rd December 2007, 12:54   #673
Thanks Tsk,
Few more questions
a) Which synthetic oil grade would you recommend for Indica
b) Would I require a special oil filter for synthetic oil, or do I continue with the regular one?
TIA.
Old 3rd December 2007, 13:07   #674
Rtech's Avatar
Thanked: 217 Times
One question. Seeing that you have already completed 85,000 kilometers using mineral oil, why change now? the extra expense of the synthetics will not really make sense at this stage of your engine's life.
Personally, if it were my car, I'd continue using high quality mineral oil.
Old 3rd December 2007, 13:24   #675
tsk1979's Avatar
I agree with rtech here.
I use high quality Mineral oil (Shell super diesel API-CG or Castrol GTX Diesel(API-CI4)
My indica has done almost 89K
Change oil every 6000kms. you don't need to spend that much.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
