Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 10th March 2008, 20:45   #811
DieselFan's Avatar
Thanked: 234 Times
Originally Posted by akshay1234 View Post
no. only when you change from mineral to synthetic or vice versa.
Wrong. One never changes from a synthetic back to mineral. It is a NO-NO. One should always scale to a higher grade else the engine will degenerate pretty quickly.
DieselFan is offline   Reply With Quote
Old 10th March 2008, 20:49   #812
Akshay1234's Avatar
Thanked: 7,287 Times
one shouldnt but what if we have to i.e no synthetic available or something. then its better to flush out the synthetic instead of adding mineral.
also can someone please confirm if mobil1 supersyn 5w50 will be fine on my diesel innova?
Old 10th March 2008, 20:55   #813
Jaggu's Avatar
Thanked: 8,860 Times
Its a good idea to use flush once in 20k to 25k kms on a regular basis but that doesnt mean engine flush is required every oil change (typically 7-12k kms)
Also there is no written rule that engine flush (like OWS) is required while shifting from Mineral to Synthetic, alternatives like regular flushing oil or a proper drain job will also do fine
Old 10th March 2008, 21:36   #814
DieselFan's Avatar
Thanked: 234 Times
Flush out the synthetic? hilarious. You use a flush before switching to synthetic because synthetic have much higher detergent than mineral oil and we use flush as a precaution to remove all the muck in the engine before switching to synthetic. Else one must change the synthetic after 1000 or 2000 km of first fill.
flush is useless when switching from synthetic to mineral. Switching back to mineral oil is always risks. On doing so one risks the degeneration of engine at a rapid pace. Don't ever try it.
Old 10th March 2008, 22:06   #815
Jaggu's Avatar
Coming to think of it, on a sparingly run engine (under 5 k kms) flushing oil does better job in removing the old oil residue.
Old 11th March 2008, 17:16   #816
bluenest99's Avatar
Is Castrol edge also fully synthetic? How is it compared to Mobil 1. Suppose for any reason i change oil from Mobil 1 to castrol edge, do i need to flush again considering that both the brands are synthetic.
bluenest99 is offline   Reply With Quote
Old 12th March 2008, 19:40   #817
Akshay1234's Avatar
gurus.. tsk etc.
mobil1 supersyn 5w50 meets the api cf grade. my diesel innova needs api cf or cf4. what i read is that cf4 is for heavy duty. my question is whether cf will work fine in my car even though it is used alot. more than 50km everyday. also revved to the redline sometimes. will it be safe using mobil1 supersyn api cf?
Old 12th March 2008, 20:33   #818
Akshay1234's Avatar
or would delvac 5w40 be better?
Old 12th March 2008, 21:37   #819
Jaggu's Avatar
@akshay: Both should work fine, Mobil 1 is fully synthetic and delvac is mineral.
Maybe users of Mobil 1 on diesel engines can give a better feedback on the difference. Am sticking to delvac with a more frequent oil change which is working out well in my Swift D
Old 12th March 2008, 23:04   #820
Akshay1234's Avatar
actually on the mobil1 site it says delvac is also synthetic.
Old 12th March 2008, 23:21   #821
Jaggu's Avatar
Thats interesting, could you share the link?
Old 13th March 2008, 00:01   #822
tsk1979's Avatar
Thanked: 16,459 Times
gurus.. tsk etc.
Go for Castrol GTX Diesel. (Not GTD). ITs API-CI4, a good 3 grades higher than API-CF. You will need to change oil every 6000kms or so since its a mineral oil, but the smoothness will be amazing.
But be aware this is a rare oil and you may have to scout many shops before you find it.
As for as synthetics, there are API-CI grade synthetic oils for diesels in the market. Search for those on mobil and Valvoline etc., websites.
Old 13th March 2008, 09:27   #823
Akshay1234's Avatar
from whats given in this
http://www.team-bhp.com/forum/755987-post139.html
it shows that the innova only takes g-dld1, api-cf and cf4. are those minimum and are the the recommended ratings?
jaggu here is the link
Mobil Delvac 1 5W-40
Old 13th March 2008, 09:29   #824
tsk1979's Avatar
API-CF is the minimum recommended. You can always exceed the recommended, no harm in that.
Old 13th March 2008, 09:40   #825
Akshay1234's Avatar
oh cool.. then will delvac be fine if i can find it? otherwise will get castrol gtx diesel.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
