Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 1st April 2008, 20:53   #871
Eddy's Avatar
Thanked: 5,161 Times
Originally Posted by wolfinstein View Post
@ Eddy - Try Batra Auto-next to Ashram Flyover. He did have Delvac last time I was there...Also you can try Khan market Auto Market or Sec-16 Noida.
Thanks Wolfie.. Where is sec 16 Noida ? I mean, will it be on the way if I go from Shoprix mall to great India place and take the DND to delhi ?
Eddy is offline   Reply With Quote
Old 2nd April 2008, 13:55   #872
n_aditya's Avatar
Thanked: 2,782 Times
Originally Posted by nitrous View Post
We have a few hundred guys running 5W oil in Chennai happily. Moreover, these are the same grades used in Dubai and the middle eastern countries. So,stop tripping and relax.
Thanks for the clarification bro. I owe you one. You know how i re-affirm before i take the plunge.
Let me know once you have picked up the oil (4 liters). Thanks again.
Old 2nd April 2008, 21:42   #873
moralfibre's Avatar
Thanked: 6,561 Times
Here's a dyno chart comparison on hp figures of various synthetic oils tested at an rpm range on the same engine.
ARTICLE: Synthetic oil vs Mineral oil-30032008233.jpg
This is off a performance tuning book that I was reading. Sorry about the poor quality.
Old 2nd April 2008, 23:07   #874
wolfinstein's Avatar
sec 16, is just ahead of SEC 18 Noida.
When you come from shoprix, just turn right towards Atta and ask anyone.
wolfinstein is offline   Reply With Quote
Old 4th April 2008, 22:24   #875
PatchyBoy's Avatar
Thanked: 1,398 Times
Guys,
My Palio Stile SLX has done 9300 kms. I am planning on switching to fully synthetic - Mobil 1 or Shell.
Questions:
1. Is it too early for the switch?
2. What engine flush do you guys recommend?
3. The gear shift is a bit rough, especially downshifting from 3rd to 2nd. How do I check the gear oil?
4. Do I need to change the gear oil?
5. If the answer to Q4 is yes, then any recommendations on the brand?
Thanks for the help.
Cheers,
Rajan
PatchyBoy is offline   Reply With Quote
Old 5th April 2008, 15:26   #876
Thanked: 106,516 Times
Nope, around 10K kms would be perfect.
Considering that your Palio is relatively new, no need to use engine flush. If and when you do, try OWS.
Best for you to stick to Fiats service schedule.
Old 14th April 2008, 17:01   #877
n_aditya's Avatar
Finally got the old mineral oil flushed with OWS engine flush.
In went the Shell fully Synthetic oil (approx. 4 liters). The oil had a lovely golden tinge to it which I noticed while filling.
Psychological or not, i feel the car is running smoother now. Revv's smoothly when floored, idle RPM has dropped a bit too, engine is quieter to an extent.
Got the oil change done on Sat near my residence.
Cost :
1. Shell Helix Ultra 4 Ltr can - INR 2830/-
2. OWS Engine Flush - 250ml can - INR 539/- (inclusive of 10% discount)
3. Oil Filter and Labor - INR 195/-
Old 24th April 2008, 01:02   #878
Thanked: 11 Times
Guys,
My Innova's next service is due, Now i want to change mineral oil to synthetic oil and i have 7 Litres of Mobil1 5W 50 fully synthetic oil and winn's engine flush lying with me.
Should i go for Mobil1 5W 50 for Diesel innova ?
Mugen_Power is offline   Reply With Quote
Old 24th April 2008, 09:20   #879
nitrous's Avatar
Thanked: 285 Times
see if you can source mobil delvac 1 .
its the synthetic mobil 1 for diesels.
Old 24th April 2008, 14:31   #880
Thanked: 11 Times
I can source the Mobil delvac, But i have Mobil1 Supersyn 5w 50 7 litres lying with me.
Should i go for this one or is it not advisable for diesel car ?
Old 24th April 2008, 17:12   #881
Akshay1234's Avatar
Thanked: 7,287 Times
it will work but it is the lowest rating that is applicable for the innova whereas delvac is a good 2-3 grades higher than the highest rating for the innova.
Old 27th April 2008, 04:00   #882
BlackPearl's Avatar
Thanked: 5,149 Times
Is anybody using Motul Engine oil? I changed my Baleno's engine oil today to Motul Synergie 6100 series 15W-50.
BlackPearl is offline   Reply With Quote
Old 28th April 2008, 14:40   #883
Proxima's Avatar
Hi guys, need your help on the below please.
  1. How to check if the engine oil in my Safari Tdi needs changing.
  2. How to change the oil.
  3. What brand to buy and how much to buy.
Reason being I dont trust my mechanic with this, told him I will do it myself. Dont want to spend too much either.
Proxima is offline   Reply With Quote
Old 28th April 2008, 14:50   #884
n_aditya's Avatar
Remove the oil dip stick and first check the oil level. The oil should be between the lower and upper markings (usually dots on lower and upper side of the dip stick). Once the level is ascertained, touch the oil and see if the oil is sticky, smudgy or blackish. Old oil generally will be very sticky and lumpy.
Get an old bucket to collect the old oil. Remove oil drain nut (check owners manual for exact location). Take care to see that it does not spill on you. If the engine is hot, oil can scald you seriously and can cause high degree burns. Use thick gloves and protective eye wear. Once the drain nut is removed and the oil is drained out completely, remove the oil filter (check manual for placement). Use the proper wrench to remove the old oil filter, let the oil drain (if not completed) and replace with new oil filter. Replace drain nut too.
Now fill fresh oil (open hood and locate the oil cap) and constantly check level on the dipstick. Discard old oil properly. Please dont pollute the environment.
Which oil and how many liters? Check your manual for grade and quantity. Then buy a similar grade oil from a reputed brand. Hope this helped.
Old 28th April 2008, 15:38   #885
Eddy's Avatar
I think its better to pay 100 bucks to get the oil and filter replaced at a local mechanics place than doing it yourself if you are a newbie. But source your own oil.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
