Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 28th August 2008, 13:42   #1066
DieselFan's Avatar
Thanked: 234 Times
Can anyone point me to a good source of Mobil Delvac MX in bangalore?
DieselFan is offline   Reply With Quote
Old 28th August 2008, 13:46   #1067
Thanked: 59 Times
Originally Posted by simply_sunny001 View Post
Mobil1 dealer in bombay / mumbai
- minesh adani - 98200 58599 (these guys have godown at wadala)
Mobil Marketing in India 0091-22-404-2255 ext.356 (direct company)
Try them,if they dont have MX,which is very unlikely,tell them to get it for you.
I got it. he had it delivered to my residence. great service.
thanx buddy.
hell_rider is offline   Reply With Quote
Old 12th September 2008, 10:21   #1068
Sudipto-S-Team's Avatar
Thanked: 266 Times
I knew reaching Mobil was difficult but I didn't realise it was this difficult. The phone numbers given on the website do not work. Found a Mobil office number in the city from the net and realised that the lady who was on the other end doesn't know that Mobil sells engine oils. Realised after some ten minutes that the office I reached deals only in polymers!!
Can someone please tell me a reliable Mobil 1 dealer in Calcutta and also whether Mobil 1 is available in 20w40 grade for my Esteem?
Sudipto
Sudipto-S-Team is offline   Reply With Quote
Old 12th September 2008, 10:39   #1069
Thanked: 44 Times
For the Esteem, I would use what I use for my Baleno and Getz - Mobil 1 Supersyn 5W-50. the range of grades is wide enough to be used in most parts of India, except perhaps Ladakh/ Kashmir where temperatures go below zero degrees Celsius.
filcord is offline   Reply With Quote
Old 12th September 2008, 10:54   #1070
Thanked: 266 Times
Maruti recommends 20wx40 mineral for esteem. Is it critical that we maintain the same grade while switching to synth? I know 5x50 is wider and would cover 20wx40, by conventional logic. but i don't want to go wrong here.
Old 12th September 2008, 11:42   #1071
alpha1's Avatar
Thanked: 1,047 Times
One query that I have:
suppose my manufacturer recommends 15 w 40 oil.
If I put 15 w 30, isnt it better (than 15 w 40)?
At higher temp, the engine oil still retains its viscosity.
Old 12th September 2008, 12:03   #1072
Thanked: 266 Times
Alpha
You might want to consult this. Car Bibles : The Engine Oil Bible I felt very confused after reading it a few times. So - "caution speed breaker ahead".
Sudipto
Old 12th September 2008, 12:04   #1073
tsk1979's Avatar
Thanked: 16,465 Times
alpha1, you have it other way round.
15w40 will retain viscosity more than 15W30
So if manufacturer says 15W30, you can go for 15W40, not the opposite
Old 12th September 2008, 12:28   #1074
RAC
RAC's Avatar
Default Recommend oil for Alto
Hi
I have service coming up for my car - Alto STD - done 29000 KMS. I am planning to give for service at 30000KMS. Please advice.
1) Should i switch to Castrol Magnatec (semi-synthetic) or a Synthetic oil (Mobil, etc)
2) For moving from regular mineral oil used by dealers to Synthetic oil, engine flush is recommended. Is it required before using Magnatec?
3) Please recommend brand/dealer for engine flush and Synthetic oil in Bangalore, preferably South Bangalore.
RAC is offline   Reply With Quote
Old 13th September 2008, 12:29   #1075
nitrous's Avatar
Thanked: 285 Times
1) If you plan to keep the car for long,do high mileage and want the engine to be healthy all through its life, you should definitely get the synthetic. If not, run on semi synth too. Magnatec is good.
2) Not absolutely necessary. But, if you do, then well and good.
3) Check the last few pages of this thread, there were addresses and phone numbers in a post.
Old 13th September 2008, 17:07   #1076
amit_mechengg's Avatar
Thanked: 1,556 Times
Thumbs up Petronas Syntium 3000
HELLO guys !! Finally i have done it
my dream of using a fully synthetic oil is fulfilled. i got myself a 4 litre can of petronas SYNTIUM 3000 fully synthetic 5w40 engine oil for my alto.
1.Syntium 3000 - Rs 2100 ( discount 20% on old MRP of Rs 2600)
2.Cyclos motor flush - Rs 170
3. Mico oil filter - Rs 84
4.Castrol coolant- Green -Rs 250
5.Labor -Rs100.
initial impressions- engine noise reduced considerably. idling has improved a lot. harshness of engine is gone.
pick up- not tested, top speed - not tested.
i will update as soon as i make a trip. i couldnt drive much as the mechanic is just 100 mts away from my house.
** please check the specs in the attachment
Old 15th September 2008, 12:12   #1077
reviews : i never thought that synthetic oil will change the engine behavior so drastically. now the engine is revving very freely and idling rpm has increased. i think it will take time for the ECM to correct it again.
now the car is pulling up better in 3rd and 4th gears. overall noise has reduced marginally. also there are no vibrations in the gearknob now.
i dint observe and increase in top speed, though a slight difference in pick up is there. overall i am very much satisfied with Syntium 3000 from petronas.
best value for money.
Old 15th September 2008, 14:39   #1078
Shakensoul's Avatar
Thanked: 223 Times
I went to Marketing Times Workshop in Okhla yesterday to check with the service engineer what type of engine oil is used. They said they use the Mobil regular engine oil or the synthetic Mobil1, but they quoted around 1000 per liter for the Mobil1 .
From what I read in the forum, Mobil1 is around 600/L, I didn't argue or discussed the price difference with him and I left.
What I wanted to know, can I change the engine oil myself if it only requires draining the previous oil from underneath the engine body, or is it a difficult task ?
Shakensoul is offline   Reply With Quote
Old 15th September 2008, 15:06   #1079
Eddy's Avatar
Thanked: 5,169 Times
You can/should get it done from any mechanic. Will cost you 100 bucks in labor. Replacing oil is easier, its the oil filter that needs experience.
Eddy is online now   Reply With Quote
Old 15th September 2008, 15:18   #1080
nitrous's Avatar
Thanked: 285 Times
You read a post from 2004?
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
