Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
On modifying a car Help articles related to modifying a car
Thread Tools
Old 14th December 2006, 14:13   #106 (permalink)
hellspawn's Avatar
Infractions: 0/1 (10)
What about those members who push their engines to the limits by simple and extreme mods or operating conditions
1. For example chipping, K&N, Free flow etc,. to get additional HP.
well these mods actually make an engine more efficient.k&n and free flow dont strain the engine rather thay help the engine perform better.members with swapped engined cars,turbos,nos etc do require synthetic oils.
but my question is "do you need synthetic oil for your every day commutes to the office".
Moreover no matter whether machinery is old or new, won't better lubrication increase life. Esp during cold starts(5-10degrees at delhi winters) when the 20W40 oil will not be effective. When engine gets warm things are okay, but what about 2 minutes of torture your engine will go through because your oil was designed for minimum 20 degrees temperature?
where did you get the 20 degrees part from???
the 20 in "20w40" means the viscosity of oil at low temperatures and "40" means the viscosity of oil at normal running conditions.so a sae10w40 oil will flow better than 15w40 oil at the same ambient temperature.also the lower the initial number,thinner will be the lubrication film.
and how much life will be increased.do you as a user plan to use the car in that extra life that it gets. mineral oil can make the engine easily cross 150 k but by that time your engine would have lost its compression ratio,piston rings will need to be changed etc etc.
Also Indian driving conditions are very demanding. Lots of heat, cold-heat transformations can lead to sludge buildups. Somebody who changes oils every 6000kms or so will do okay with 15W40, but if you don't(which many people don't) a better oil will stay good for longer periods.
well what i would say is that its best to stick the manufacturer's recommendation and they are the best authority on what is required for runing the engine.after all they built it.
if you have done some serious mods to your cars,go for synthetic oils.
it all depends on what you expect from your vehicle.
whats the point of saying that synthetic oils increase engine life when we indulge in bunny hops from traffic lights,wheel spins,downshifting without blipping the throttle.....you get what im trying to say!!
hellspawn is offline   Reply With Quote
Old 14th December 2006, 14:56   #107 (permalink)
I think to sum up:
1. There is very little or no perceived difference.
2. There is/may be long term benefit.
3. It is 3-4 times more expensive.
4. Still requires to be changed on as frequent basis as mineral oil. (even more if like GTO one drives @>6k rpm - are you always only in 1st gear? - my OHC 1.3 goes to 55km/h in 1st - your vtec would be more - 60 or 63km/h and no can do driving any faster than that even on expressway nowadays)
5. So it may be good for your car but definitely not on your pocket.
sandeep108 is offline   Reply With Quote
Old 15th December 2006, 05:12   #108 (permalink)
mithun's Avatar
My experience with semi-synthetic is quite a pleasant one for my bike although I have never used synthetics for my car yet....
I usually change the engine oil of my bike every 2500 KMS. When I've used mineral oil like Castrol Activ 4T for my Pulsar, I've noticed that the bike loses it's smoothness after about 1500 KMS. But it's not the same case whenever I've used semi-synthetic like Castrol Power 1, the bike will run with the same smoothness even after 2500 KMS and I've never even felt that it's time for the engine oil change.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 16th December 2006, 20:22   #109 (permalink)
2fast4u's Avatar
Originally Posted by ram View Post
How much more does one really want? At the end of the day, should the total amount spent on lubrication exceed the price of a new engine?
Regular oil changes with good mineral oils gives you decades of engine life anyway.
agree with you on this.
here in the gulf my old nissan 92 model is still going strong having done over 1,298K kms and its still on the same block piston enjoying its supply of mineral oil. its on castrol or nissan 20w50.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 16th December 2006, 22:41   #110 (permalink)
nitrous's Avatar
@2fast4u:1.3 million kilometres???
Pls tell me thats a typo!
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Old 17th December 2006, 18:25   #111 (permalink)
2fast4u's Avatar
no nitrous thats right!! when i was leaving uae i met the first owner by chance who was in all surprise when he saw the car and also commented "nicely maintained". during the chat he mentioned that he had got the meter reset from 740k+ to 90k for disposing off. the 2nd owner added around 35 to 40k and now i am 3rd owner.
i too was in surprise when i came to know of how much the engine has actually run with no overhaul at least i have not overhauled it in near to 5 yrs now.
__________________
636
RB20DET NISSAN
Old 7th January 2007, 20:09   #112 (permalink)
goldsun's Avatar
Post Added Synthetic Oil to Swift
I have added OWS Synthetic oil along with OWS Iridium Spark Plugs to my swift, which has done 19k kms. Both along with the engine flush costed me Rs.6.7K. It is just 40+ km since the above changes and there are certain noticeable benefits, which are:
  • The engine is very responsive and starts up very quickly than before.
  • The lower end torque has improved a lot.
  • The engine seems to be smoother, as there is no vibration when the engine is under stress, which used to be there when doing at 35 kmph in 4th gear.
I am not sure whether Synthetic oil or the spark plug that has resulted in the above improvements.
__________________
Have a pleasant and safe driving
goldsun is offline   Reply With Quote
Old 7th January 2007, 23:51   #113 (permalink)
harsh87's Avatar
try veedol semi synthetic for bikes
my friend who repairs superbikes recommends it to all his customers
all his clients busas,r1,r6s etc are running on this oil
retails for 250 bucks a litre
harsh87 is offline   Reply With Quote
Old 8th January 2007, 10:34   #114 (permalink)
sanjaymugur's Avatar
How is Castrol EDGE fully Synthetic oil.. anybody has used it here..
its grade is 5W-40..
sanjaymugur is online now   Reply With Quote
Old 8th January 2007, 10:53   #115 (permalink)
More likely the spark plugs, they were due for change anyway at 20k. But your iridium ones should last maybe the lifetime of the car, if good petrol is used. Also new oil and filter, whether mineral or synthetic and a service - all would help with what you are experiencing.
Old 9th January 2007, 12:36   #116 (permalink)
Simply amazing ride dude. Seen your car pictures and credit to you and the previous owners its simply too well maintained.
Credit also to the Oil companies and Nissan Engineering as i am amazed that you have not done an overhaul in 500+k kms. right!!!
hey since you ar in bahrain lets meet up some time.
Jr Godzilla is offline   Reply With Quote
Old 10th January 2007, 07:15   #117 (permalink)
sgmuser's Avatar
My experience with engine oil :
First I started to use Esso for my kinetic way back in 90s and felt a lots of difference. It was so smoother and felt comfortable at high speeds ie around 80-90kmph.
Then 2 years back I started to use Castrol Magnatec Semi Synthetic for my Nissan Sunny 1997 model which had done 45k then. Now its 125k and its stunner in terms of pickup in the signals. Even the Nissan service center guy is surprised with its smoothness, power and pickup, when he test drove mine for some other problem. Semi-Synth's price almost 2 times, I can extend the change period to almost double that mineral oil. I even tried Shell's Semi-Synth but to me Castrol is the best of the lot. The fully synth costs around double that of semi-synth and the workshop friend adviced Semi Synth is more than enough for sedans like Nissan Sunny.
Even my friend who had driven few models says the car feels very smooth even at 150kmph upwards. I know its because of the semi synth oil :-)
__________________
Confidence is the feeling you have before you understand the situation!
sgmuser is offline   Reply With Quote
Old 18th January 2007, 20:46   #118 (permalink)
sameera's Avatar
I have a Zen Carb 1999 Dec. Two weeks back I got the service done. I put a K&N filter and Mobil1 SuperSyn engine oil. The after effect has been amazingly good.
No more cold starting problem
Engine response has been simply superb and starts up very quickly than before
Lower end torque has improved a lot noticeably
Engine smoothness is excellent and just half crank engine is roaring.
Vibration has reduce remarkably when the engine is under stress
My car has done 66K..and it still rocks....
Sameera
bangalore
sameera is offline   Reply With Quote
Old 19th January 2007, 11:22   #119 (permalink)
moralfibre's Avatar
Can anyone tell me whether any engine flush is available for 4 stroke bikes with a wet multiplate clutch? I want to try this for my Unicorn.
__________________
/F/I/A/T/
Old 2nd February 2007, 10:49   #120 (permalink)
One thing I noticed when giving a pot of synthetic oil along with the car for service is that the manager realises that you are a car buff and will not mess around with you
__________________
Rice is cheaper than German Potato's
Thread Tools
Synthetic Gear Oil cyneverdie Technical Stuff 16 1st October 2009 08:46
Synthetic Oil in Bangalore epyupc Modifications & Accessories 33 29th September 2009 23:19
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
