| | Thread Tools | Search this Thread |
![]() | #1186 |
BHPian | ![]() Castrol Magnatec is not synthetic! I'm using Petronas Syntium 3000, 5W-40 for my wife's Alto. I'm also using the same in my Civic. Very good results and very good VFM in my opinion Get the engine flushed before the change and of course, change the oil filter |
![]() | #1187 |
Senior - BHPian Join Date: Jul 2008 Location: Bangalore
Thanked: 703 Times
| ![]() My Spark has done a little over 2500kms, and I was wondering whether it is advisable to put in Mobil1 at 5K? I've seen the ads, and it apparently managed to keep a BMW's engine parts within manufacturing tolerance after 100000kms. This was with the car up on a conveyor belt, but still! Chevrolet has oil change listed every 10k kms in the manual so am not sure. |
![]() | #1188 |
Senior - BHPian | ![]() @dsinz:do remember for very 5K oil change you need to replace with syn.oil.it cost you almost double the price of normal change oil. Its just FYI. |
![]() | #1189 |
BHPian Join Date: Aug 2008 Location: Bangalore
Thanked: 31 Times
![]() | #1190 |
Senior - BHPian | ![]() I think 2.5k is too early for synthetic. The engine parts are still virtually new and are just about getting used to rubbing against each other and getting to know each other ![]() |
![]() | #1191 |
Senior - BHPian | ![]() |
![]() | #1192 | |
Senior - BHPian | ![]() Quote:
Mobil1 and other syhtetic oils costs a lot (Rs800 / lit or more) and not required for Alto. Abhi | |
![]() | #1193 |
BHPian Join Date: Aug 2006 Location: Bangalore
| ![]() I went for Castrol Magnatec this time. Lets see how it goes. Thanks a lot |
![]() | #1194 |
BHPian Join Date: Sep 2007 Location: Bangalore
| ![]() hi, go for synthetic. Good lubrication and engine life will be extended. Small carbon particles will be removed. Engine will be smooth. The oil change cycle can be extended. |
![]() | #1195 |
BHPian Join Date: Oct 2008 Location: Pune
| ![]() For Swift Petrol, 0W40 is recommended by Mobil 1. |
![]() | #1196 |
| ![]() The contact person for Mobil1 in Pune is given below: Mr. Kapil = 9371009065 Mr. Manoj = 9373309777 For Swift Petrol, 0w40 = Rs.4000/- |
![]() | #1197 |
![]() | #1198 |
BHPian | ![]() |
![]() | #1199 |
Senior - BHPian Join Date: Jan 2008 Location: Mumbai
Thanked: 151 Times
| ![]() Interesting. I assume you say that because with a higher running, better lubrication and care is needed for the engine. Which fully synthetic can provide, right? However, with higher running and fully synthetic, your costs of replacement would also run up high. e.g. my daily running is around 60 km, so I assume I would need to change oil every ~6 months or so? |
![]() | #1200 | |
| ![]() Quote:
I didn't go for the change to Mobil 1 for mainly 2 reasons; 1). As I was new to Pune, I enquired about Nanapeth with in my friends circle and I was adviced by not to buy anything Nanapeth as it is famous for duplicates. 2). The price quoted was high and so I wanted confirm the price. I have few questions for you: 1). Which car do you have? 2). Which type of Mobil 1 you are using? 3). Since how long you are using Mobil 1? 4). How much you have driven your car with Mobil 1? 5). Do you recommend Gyani Motors in Nanapeth? Thanks | |
Thread | Thread Starter | Forum | Replies | Last Post |
Synthetic Oil in Bangalore | epyupc | Modifications & Accessories | 50 | 8th December 2017 22:23 |
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? | Max | Shifting gears | 27 | 14th June 2015 23:41 |
Oil change..Synthetic, where to source | DRC | Technical Stuff | 21 | 2nd December 2007 15:00 |
Synthetic Oil | karthik247 | Technical Stuff | 10 | 8th November 2005 18:02 |
