Go Back   Team-BHP > Team-BHP > Team-BHP Advice > On modifying a car
Old 29th January 2009, 17:57   #1426
Sludge is everything to do with engine design and nothing to do with oil per se. Notable sludgemeisters are the VW turbo engine used in Skoda Petrol RS and other VW engine as well. Also few Toyotas suffered from this malady but that was fixed soon. Also in cases like this, synthetic oil is the norm and regular oil changes the only way to survive.
Gurkha is offline   Reply With Quote
Old 29th January 2009, 19:31   #1427
Raccoon's Avatar
Thanked: 105 Times
Engine design yes, definitely, but how do you say it has nothing to do with the oil?!? Thats why the detergents are there... some have more, some have less... and will be able to resist sludge formation to a lesser extent.
Old 30th January 2009, 05:28   #1428
Atlblkz06's Avatar
I think your comment is misleading. Oil has a lot to do with sludge. Hell oil IS sludge in some cases!
Oil sludge or black sludge is a solid or gel in motor oil caused by the oil gelling or solidifying, usually at temperatures lower than 100 degrees Celsius. Sludge is usually caused by the presence of water in the oil, and can accumulate with use. Ways to minimize sludge production and accumulation include performing frequent oil changes, using synthetic oil, and following the manufacturer's engine maintenance routine.
(For some reason I'm unable to unbold this text...not kidding!)
(Disclaimer: Wikipedia is NOT always correct. It's just some guy's pinion who took the time to make a detailed post)
Atlblkz06 is offline   Reply With Quote
Old 3rd February 2009, 12:02   #1429
yatinchoubal's Avatar
Guys, M thinkin of using Petronas S, in my santro. But however, I have a confusion. During my next oil change, if I use Mobil 1, would that be a problem.
Would using different brands and grade, would coz a problem?
yatinchoubal is offline   Reply With Quote
Old 3rd February 2009, 15:11   #1430
Raccoon's Avatar
Thanked: 105 Times
Shouldn't cause a major problem. But when you mix different brands, one never knows how "compatable" there are. So the safest thing is not to mix... and if you do, better not to do it often!
Unless you've already read in another thread - if you keen on going fully synth, you could consider Cheveron. Seems they have a fantastic deal on fully synth. Else there is other stuff that Gurkha suggests like Delo 400, etc.
Old 4th February 2009, 14:45   #1431
The problem is availabilty of the syth oils in pune. Mobil 1 is available only at nanapeth. Found a mechanic Tune up plus in Baner, who keeps Petronas S. And trust me there is a huge price diff with almost same performance when it comes to a 1.1 - 1.3 engine car.
Petronas S 1 litre comes around 650, and Mobil 1 goes to 1000 bucks.
Do we get Delo400 or Cheveron in Pune. (I had tried searching for valvoline too, but nobody keeps it)
Old 4th February 2009, 15:50   #1432
Raccoon's Avatar
Thanked: 105 Times
For Delo and other Cheveron products, please find their website, select location India, and write to them. They seem very responsive. I was told not to worry about availability, as they will arrange to deliver the stuff to your place.
I'm sure you can can get Valvoline the same way. If they are intrested in selling, they will tell you where to get it or home deliver. However, I believe I have seen Valvoline products in Nana Peth...
Check the exclusive Delo site also -
Delo: Engine Oil
Old 4th February 2009, 16:15   #1433
vikram18's Avatar
Thanked: 20 Times
I don't think it would cause a major problem. In any case, if you're happy with a lower priced brand, providing equal performance, why would you want to shift back to the more expensive brand anyway? I have been using Petronas Syntium in my Civic since my first 10K oil change to synthetic and I'm absolutely satisfied.
In Pune, a lot of brands are not available, but you can always pick up a can from Mumbai, or even ask someone to pick one up for you. I'm sure a lot of your friends, relatives, you yourself and a host of helpful T-Bhpians do Pune-Mumbai quite regularly.
You can perform a flush during your oil change. That should make things even easier.
vikram18 is offline   Reply With Quote
Old 4th February 2009, 16:58   #1434
Thanked: 100 Times
Yatin,
talk to a person named Anand (+91 9822408221) who is the sales rep. for Chevron in Pune.Give him my ref (ROhit).I have been using Delo-400 in my Safari 2.2 for past one year.You can get Havoline for your petrol car as well.
rb2399 is offline   Reply With Quote
Old 4th February 2009, 17:11   #1435
greenhorn's Avatar
Thanked: 1,516 Times
the contact info appears to be listed here
Asia Pacific: Local Information: India
Old 5th February 2009, 13:51   #1436
abhibh's Avatar
Thanked: 34 Times
Guys I am thinking of shifting from mineral to semi synthetic (mineral synthetic). Is 15W40 good enough for my Alto ?
Also i was looking at Castrol Magnatec and they say that their oil "Uses Synthetic Technology". Is it same as Synthetic Blend ? Whats the cost of Magnatec ?
Old 5th February 2009, 14:33   #1437
Raccoon's Avatar
Thanked: 105 Times
Nopes, Synthetic Technology does not mean synthetic blend or semi-synthetic. Intrestingly, tho Castrol Magnatec says its Synthetic technology, nowhere do they mention its even semi-synthetic. In any case Castrol always gives least technical details about its products, and maximum marketing hype.
And as I'v been saying repeatedly - semi synthetic does not really mean much unless the manufacturers mentions the percentage of synthetic component. So try not to base your buying decision on a label that says semi-synthetic! And dont get carried away by marketing gymmics!!
Vaguely remember that the current price is around Rs. 1,200 - 1,400 for 3 litre can.
Old 5th February 2009, 14:37   #1438
Originally Posted by rb2399 View Post
Yatin,
Thanks buddy, will surely check up with him.
Old 5th February 2009, 14:39   #1439
lohithrao's Avatar
Thanked: 163 Times
Raccon, How are Delo and Cheveron when compared to Mobil..Shell etc? Oil change is due and Mobil is pretty expensive
lohithrao is online now   Reply With Quote
Old 5th February 2009, 15:06   #1440
Raccoon's Avatar
Thanked: 105 Times
^^^Delo is a Cheveron product! As for how they compare with Mobil, Gurkha would be a better person to ask that quetion to. Also you could search for his posts about Delo and other Cheveron products.
Synthetic Oil in Bangalore epyupc Modifications & Accessories 50 8th December 2017 22:23
Where to buy Mobil1 / Castrol Synthetic Oil in Mumbai? Max Shifting gears 27 14th June 2015 23:41
Oil change..Synthetic, where to source DRC Technical Stuff 21 2nd December 2007 15:00
Synthetic Oil karthik247 Technical Stuff 10 8th November 2005 18:02
